XtremeSystems Forums
Reply
Old 10-26-2009, 08:33 PM   #1
Odai
Compression fittings - have I overtightened them?
hello,
I recently finished a water cooling setup. However, at first I got a leak. I therefore had to drain the system to sort it out.
In doing so, I had to take the tubing off the fittings. I noticed at the time that there were indentations on the tubing from where the "screwy bit" makes contact. First time round, once I had tightened as much as possible, there was a small gap between the screw bit, and the base of the fitting. However, second time round, after fixing the leak problem (caused by Swiftech design, standard third party o-rings don't create a seal), the screw bit went much further. I had the fitting screwed into the block, put the tubing on, and screwed the "screwy bit" down. Without using pliers, the screw bit went almost all the way, leaving practically no gap at all. It was easier to tighten too. Could I have overtightened it?
And should I be worried it was a lot easier to tighten the second time round? I'm afraid the tubing could be cut into.
I'm using Tygon 7/16" ID 5/8" OD tubing and bitspower compression fittings (same size, 7/16, 5/8)
I've included some photo's, incase my barely understandable description doesn't make any sense
EDIT: The extent to which I tightened the fittings on the blocks is pretty much the same as how much I've tightened the one shown above, at the bottom. (reservoir).
EDIT 2: First post by the way on a great forum.
Odai is offline   Reply With Quote
Old 10-26-2009, 08:39 PM   #2
cstkl1
cstkl1's Avatar
holy crap
yes u have if thats bits compression.
and u might have torn the tubing at the top
suppose to leave that non threaded area on the compression empty.
cstkl1 is offline   Reply With Quote
Old 10-26-2009, 08:47 PM   #3
Hondacity
its good
__________________
Hondacity is online now   Reply With Quote
Old 10-26-2009, 10:02 PM   #4
Fafeifa
Fafeifa's Avatar
You need some rotary adapters or an extender because the base of the 3/4"OD compression fittings are wider than the machined spot for the fittings. It will leak no matter how tight you go.
__________________
Fafeifa is offline   Reply With Quote
Old 10-27-2009, 04:22 AM   #5
Odai
hello,
Fafeifa, sorry I wasn't clear, but the fittings are 5/8" OD, not 3/4".
I've leak tested it randomly for about 12 hours, I haven't had any leaks so far. I'll assume the tubing hasn't been torn then. So would that mean it will stay that way?
Old 10-27-2009, 05:42 AM   #6
ChielScape
you cant overtighten compression fittings..
ChielScape is offline   Reply With Quote
Old 10-27-2009, 06:41 AM   #7
jim0ne
Thats what i thought also.
jim0ne is offline   Reply With Quote
Old 10-27-2009, 07:46 AM   #8
pwolfe
pwolfe's Avatar
I was under the impression if you over tightened CP's you could actually cut into the tubing. At least on my tfc compressions, I could see the tubing being cut into when I over torqued them.
pwolfe is offline   Reply With Quote
Old 10-27-2009, 07:50 AM   #9
Baulten
I did some tests on spare tubing (PrimoFlex 1/2" ID 3/4" OD) and I was unable to cut or tear the tubing by tightening the compressions all the way down. I don't do it in the computer case simply because it's HARD to get the compressions that tight, but even if I did, it wouldn't sheer the tubing.
__________________
The parts:
| MSI 790FX-GD70 | Phenom II 965 140W | Sapphire HD 5870 | 2x2 GB G.Skill Ripjaw DDR3 1600 7-7-7-21 | 3 x 250 GB SATA HDDs | 1 x 1 TB WD MyBook External | Corsair Obsidian 800D |
The cooling:
| PrimoChill Typhoon III Bay Reservoir/Pump | MCR320 | 3x120mm 1450 RPM Scythe GentleTyphoon | HeatKiller REV3.0 LT | EK HD 5870 FC Nickle | ThermoChill PA120.2 | 2x120mm 1900 RPM Scythe S-Flex |
Baulten is online now   Reply With Quote
Old 10-27-2009, 08:47 AM   #10
quattro_
I am Xtreme
quattro_'s Avatar
^^ +1 there is no way a comp. fitting can do any harm to tubing, tested on 7/16 and 1/2, it will only leave a mark on the tube .
i also will not recommend doing this simply because by tightening the compression you are also forcing/screwing the fitting itself into block/res/pump etc etc .
__________________
rig1
q9650@4.3 ~ EK Supreme
Asus RE ~ BP chipset block
4GB OCZ PC3-14400 Reaper@1600Mhz
HD 4870x2 ~ DD waterblock
DELL 3007HC
rig2:
i7 920@4 ~ HK3 CU
EVGA Classified 760 ~ EK chipset block
6GB Dominator GT@1866MHz, 7-8-7-20
HD 5870 ~ EK waterblock
quattro_ is offline   Reply With Quote
Old 10-27-2009, 08:56 AM   #11
shazza
Xtreme Fan
shazza's Avatar
I've experienced the same thing where the fittings went on much easier after undoing them a time or two and using the same tubing. Haven't had any issues so far, and a number of mine have been running for months.
shazza is offline   Reply With Quote
Old 10-27-2009, 12:51 PM   #12
Wolf132
Wolf132's Avatar
Looks like to me that the o-ring under the horizontal compression fitting isnt even being compressed.
__________________
Asus P5Q-Delux, Q6600 @ 3.7
2x 120.2PA Thermochill
MM H2GO
EVGA GTX 260
OCZ vertex 60g w/Win 7 Pro
Corsair 850HX
NEC 20wmgx2
Wolf132 is offline   Reply With Quote
Old 10-27-2009, 02:18 PM   #13
NaeKuh
Broken Gainestown
NaeKuh's Avatar
no ur never suposed to overtighten compressions on both the threads and the actually tube compression.
yup.
The pinch eventually cuts into the tubing, and leads to the barb failing.
Waterlogged showed us a great cut view on how and why.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 10-27-2009, 03:51 PM   #14
millertime359
Xtreme Guru
millertime359's Avatar
yup.
You just tighten the ring down enough to put pressure onto the tubing so it can't be pulled off. There is no reason to tighten the nut all the way down. (Well outside of it looking a little better.)
Maybe Waterlogged can post those photos again as i forgot where they are.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-27-2009, 03:57 PM   #15
ChielScape
its practically impossible to tighten it all the way down anyway...
Old 10-27-2009, 03:59 PM   #16
millertime359
Xtreme Guru
Wrenches?
yea, 1/2" 3/4" by hand is impossible to tight all the way down. 7/16" 5/8" is much easier.
__________________
Old 10-27-2009, 04:50 PM   #17
ChielScape
wrench... dude.. seriously? you use a wrench?
Old 10-27-2009, 05:01 PM   #18
millertime359
Xtreme Guru
I don't, but it has happened, I think it has happened too much actually.
I've read a few threads on here and even Dean from Koolance has commented about how many RMA requests are due to overtightening fittings with wrenches.
__________________
Old 10-27-2009, 05:15 PM   #19
dengyong
dengyong's Avatar
How does one put a wrench on a knurled fitting with no flats ?
__________________
i7 920 BATCH 3838B079 4.2GHZ on 1.312v HT on, CFO off
FOXCONN BLOODRAGE
6G CORSAIR Dominator TR3X6G1600C8D
1x GTX 285 w/ heavily ported AquagraFX fc block
ULTRA X3 1000w
Windows 7 pro 64
SWIFTECH GTZ
2x DDC3.2 EK tops 2x PA120.3
WESTINGHOUSE LVM-37w3
Donate to XtremeSystems
dengyong is offline   Reply With Quote
Old 10-27-2009, 05:22 PM   #20
millertime359
Xtreme Guru
Vise grips or pliers if we want to get specific.
A box-end wrench can be used on a few different barbs as there is a hex shape there.
__________________
Old 10-27-2009, 05:58 PM   #21
Noisy
Instead of risking over tighten, I just use this.
http://www.sidewindercomputers.com/bishsimatoma1.html
works great
__________________
i7 920(3.811G, ), Intel DX58SO, Nvidia 260, Crucial Triple Kit 1600, Areca ARC-1231ML,
MCP655-B, Heatkiller 3.0, SilverCoil, distill, EK RES 250,
Norprene 1/2ID, 8x Silenx iXtrema Pro 120mm.
AS5, Case intake: 21; Case output: 23.
No load: Coolant: 25, Core: 35
Case intake: 22, Case output: 24.
Prime 95: Coolant 28, Core: 57
Noisy is offline   Reply With Quote
Old 10-27-2009, 06:34 PM   #22
ChielScape
works great
and exactly how does that prevent you from overtightening anything?
Old 10-27-2009, 06:46 PM   #23
Waterlogged
I am Xtreme
Waterlogged's Avatar
Ask and ye shall receive.
__________________
Waterlogged is offline   Reply With Quote
Old 10-27-2009, 07:02 PM   #24
millertime359
Xtreme Guru
+1
I'm a bit lost on that too.
Thanks Waterlogged.
__________________
Old 10-27-2009, 07:42 PM   #25
dengyong
dengyong's Avatar
works great
__________________
FOXCONN BLOODRAGE
ULTRA X3 1000w
Windows 7 pro 64
SWIFTECH GTZ
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
