XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Chilled Liquid Cooling
Reply
Old 10-26-2009, 07:10 PM   #1
Stewie007
Stewie007's Avatar
Plastics in the cold
I'm still not able to build because of lack of finances, however I'm always busy designing.
I've decided that not only am I going to chill the cpu, but 3 GPUs too. I've decided that with the size and complexity of the system, it will be more efficient to take as much load as possible. I believe that 500W at -10 to -15F is pretty doable.
So the question is, I don't see any GPU blocks that are made out of much other than POM or Acetal. What kind of experience do you guys have with this stuff? Keep in mind that not only do I need some decent chill resistance, my pumps are putting out a lot of head pressure. 20GPM through your typical VGA block might decrease tolerance of the block.
I suppose I could have a machine shop cut a copper piece for me that is just like the plastic piece....
__________________
Proud of my Pontiac G8.
...Yes, I know that its a Holden...
If you hate it, you haven't driven it.
Stewie007 is online now   Reply With Quote
Old 10-27-2009, 12:32 PM   #2
TheGreenFoX
Bump... I have the same question... Im doing a dry ice cooled setup so would like to know if anybody know how the plastic part will handle the cold
__________________
TheGreenFoX is offline   Reply With Quote
Old 10-27-2009, 01:39 PM   #3
Plan.B
Xtreme Cruncher
At this coolant temp a delrin block (apogee gt) developed numerous hairline cracks around the barbs which resulted in coolant seepage after about 2-3 weeks of almost 24/7.
Plan.B is offline   Reply With Quote
Old 10-27-2009, 02:13 PM   #4
TheGreenFoX
I guess acetal is a no go... What coolant did you use?
Stewie007, FYI: I think ill go for this GPU cooler: http://www.ybris-cooling.it/product_...2d630837babb7d
__________________
Old 10-27-2009, 03:48 PM   #5
Plan.B
Xtreme Cruncher
I used a mix of denatured alcohol and distilled water. Been looking at gpu blocks also, I'm starting to think that a machine shop is the way to go
Old 10-27-2009, 08:45 PM   #6
Utnorris
Utnorris's Avatar
You will also need to braze the block together instead of using a o-ring to seal it if you are going into the negative range. Standard o-rings will not handle the cold very well.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Corsair 800D
I7 920 (3849B028)/Classified/ EVGA GTX 295/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) EK Supreme Classified (NB) EK Water Block / Typhoon III with XSPC RX360 / B*P/Koolance Compression Fittings and Quick Disconnects.
Utnorris is offline   Reply With Quote
Old 10-27-2009, 11:13 PM   #7
flak-spammer
Hmm I thought that was a known issue with alcohol and acetal. Pretty sure it's pretty well documented that alcohol and plastic don't seem to mix well. Should be other threads around here mentioning that (unless I'm just dreaming).
Edit: Okay nevermind I was dreaming, I'm thinking of Acrylic can't say why you'd have problems with acetal then.
flak-spammer is offline   Reply With Quote
Old 10-28-2009, 06:37 AM   #8
ChielScape
alcohol and acrylic is a no-go, acetal is weak against cold. so you cant really use either.
you'll want to look at full metal blocks. or use antifreeze isntead of alcohol and use acrylic if you have to.
ChielScape is offline   Reply With Quote
Old 10-28-2009, 06:58 AM   #9
TheGreenFoX
Okay...
Last question
What pump to use at those temperatures?
__________________
Old 10-28-2009, 02:20 PM   #10
Stewie007
Stewie007's Avatar
Brazing is not a problem for me . I do it for Carrier corporation every day. Whatever I use I'm going to be brazing.
The problem with the machine shop option is that it will be expensive for multiple cards.
__________________
Old 10-28-2009, 02:38 PM   #11
TheGreenFoX
Did you consider the block that i linked to?
If not please tell why
__________________
Old 10-29-2009, 03:50 PM   #12
Stewie007
Stewie007's Avatar
If they make them for the 5000 HD series then I may indeed.
__________________
Old 10-30-2009, 02:06 AM   #13
TheGreenFoX
It matches the 58xx series mounting holes AFAIK.
I had coolerkit.dk (danish reseller of EK bloks) doing some research for me, regarding the aceal in EKs products:
http://solutions-in-plastics.info/nl...ACETAL%20C.pdf
So -50 is the lowest temperature for the acetal in EK blocks according to that datasheet, but i might check it with Eddy before buying the blocks i need
__________________
Old 10-30-2009, 06:56 AM   #14
Stewie007
Stewie007's Avatar
Unfortunately, though, all of the data sheets I have read state that the lower limits are short term. I believe even as much is so for Delrin. So I think I might not be using the plastics. Seems too risky.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
