XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-26-2009, 04:54 PM   #1
Danny54
AC Ryan fans
Hi, new here.
I've got a few AC Ryan blackfire 4 120mm fans in various led colours. I really like them, they look good and they all have 77.70cfm. My temps are low for cpu and gpu, and the ac ryan dropped my gpu temp considerably more than an enermax everest I had on it before. So anyway, I'm only posting this to ask what the general thoughts are on ac ryan, out of curiousity really. Did vapor ever test them and have a good or bad word to say on them?
Danny54 is offline   Reply With Quote
Old 10-27-2009, 01:27 AM   #2
Ar3s
Ar3s's Avatar
Send a message via Skype™ to Ar3s
No vapor doesn't test uv led fans. they aren't bad in general for cooling but they aren't silent/quiet either. Start ordering some replacement LEDs cause they burn out after a while
__________________
Everyday is a NiceDay
Ar3s is offline   Reply With Quote
Old 10-27-2009, 05:24 AM   #3
Danny54
AC Ryan leds specifically burn out, or all led fans? Tbh, people always say fans are noisy yet I don't find this, even with all fans on full blast.
__________________
**Phenom II x2 550BE @3.1GHz**HIS 4870 1GB**WD RE3 1TB sata II**Coolermaster Dominator CM690**OCZ ModXStream Pro 700w**Patriot Viper 2x2GB DDR2 6400 @EPP 4-4-4-12**GA-MA770-UD3 rev 2.0**TRUE Rev C + AC MX-2**Thermalright HR-03-GT vga cooler + AC MX-2**120m fans: Enermax UCEV12 Everest TWISTER blue LED/Xigmatek XLF-F1253 orange-white LED/ 4 x AC Ryan Blackfire 4 UV-LED blue, blue-green & blue-orange/Sharkoon 'golfball' silent eagle2000**Windows 7 x64
Old 10-27-2009, 05:28 AM   #4
Ar3s
Ar3s's Avatar
yeah most led fans but ac ryan did try updating the fans a little. bigger hub and better leds but once you replace them with good quality uv leds like i have did for most of them, they last and they are great fans. i just find them noisy but noise is a personal.
__________________
Old 10-27-2009, 07:22 AM   #5
iTravis
iTravis's Avatar
Send a message via Yahoo to iTravis
I like AC Ryan even though I never have experience with the 120mm versions. I got 2x92mm blue LED one and they work great for me, as for the noise if you concern about it that much then just get a fan controller.
__________________
1st Rig
CPU: Core i7 920 @ 4.2Ghz Mobo: eVGA X58 Classified CPU Cooler: Prolimatech Mega Shadow
GPU: Diamond HD4870X2 RAM: 3x2GB Corsair Dominator DDR3 1600 PSU: Corsair HX850W
Sound card: AuzenTech X-Fi Forte 7.1 HDD: OCZ Agility 120GB SSD OS: Windows 7 Ultimate x64
Display:
30" Dell UltraSharp 3007WFP-HC Speakers: Logitech Z-5500
2nd Rig
CPU: QX9650 @ 4.0Ghz Mobo: Asus Maximus Formula SE CPU Cooler: Thermalright Ultra 120 Xtreme
GPU: eVGA GTX 295 Co-op FTW RAM: 2x2GB G.Skill DDR2 1066 PSU: Corsair HX650W
Sound card: X-fi XtremeMusic HDD: 2TB OS: Windows XP
Display: 24" Dell UltraSharp 2407WFP Speakers: Logitech Z-5300
iTravis is offline   Reply With Quote
Old 10-27-2009, 09:27 AM   #6
al-
A.C. Ryan is OK
I don't think AC Ryans' are the quietest, nor the loudest...and I've had no problems with the led's burning-out...my pc runs everyday, almost all day long, for over a year (& with fan controller)
__________________
Maximus II Formula | Lancool K62 | E8400 | Yate Loon 120mm/2200RPM Exhaust | Thermalright Ultra 120 Extreme/Yate Loon 120mm/2200RPM(2) Push-Pull | Corsair Dominator 4GB (2x2GB) PC2-8500 | WDCBlack/1T RaptorX/150 | HD4870 | ASUS Xonar D1 | Lite-On 20X | Scythe Kaze Master | Corsair TX750
al- is offline   Reply With Quote
Old 10-27-2009, 09:43 AM   #7
Danny54
Nice
Here's 2 more fans I have to install.
__________________
Old 10-27-2009, 05:01 PM   #8
al-
Originally Posted by Danny54 View Post
Nice
I use it to cool my TRUE120...
__________________
Old 10-27-2009, 07:20 PM   #9
Danny54
Nice picture!
I was thinking of swapping my sharkoon on my TRUE for one of my ac ryans. The sharkoon is 76cfm, so nothing in it really, but might be nice to have the LED on it. I also have a blue/green ac ryan on my HR 03 GT now, but was the enermax before that
__________________
Old 10-27-2009, 08:59 PM   #10
al-
To Danny54-
Nice VGA Cooler! How's your 4870 run with the HR-03?
__________________
Old 10-28-2009, 11:58 AM   #11
Danny54
To Danny54-
Thanks! Absolutely brilliantly. And the cpu cooler seems to contribute indirectly to the vga cooling I've found. Using furmark stability test, with stock coolers on cpu and gpu, I was getting 53c idle and 85c load. Currently, with the HR 03 GT and some MX-2 TIM, I'm getting 32c idle and 45c load, sometimes 43c load when it's really cold in here.
Before the HR 03 GT, I bought the akasa neo vortexx, but it wouldn't fit, even after I sawed off some of it, the black oblong heatsink at front of card was blocking it from seating. Mine is a non reference 4870. The only one that fits is the thermalright. And to be honest, I somehow doubt I would have gotten as good temps with the akasa.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
