XtremeSystems Forums
Reply
Old 10-26-2009, 04:34 PM   #1
SBB
Poor i7 WC temps
D-Tek Fuzion v1 with 1366 mount kit and AS5
Themochill 120.3 rad + Scythe high flow fans
Liang D5 Vario Pump
1/2" hose all round
Getting poor temps .... got an i7 920 with a modest OC, and it idles around 45 and loads up to about 80 ... I tried at stock and the temps hardly change, surely they should be better than this?
Any ideas?
Thanks in advance
Ben
__________________
i7 920 // 6GB G.Skill DDR3 1333 // Gigabyte X58-UD3R-SLI // 2x GTX 280
SBB is offline   Reply With Quote
Old 10-26-2009, 04:45 PM   #2
Weevil
Obsessed Member
Weevil's Avatar
Send a message via ICQ to Weevil
What are you ambient temps, do you have a gpu in the loop, what order are your components in the loop?
__________________
wEeViL
Browser: Intel QX9650 (3.0GHz) @ 3.6 | Water Cooled by Swiftech | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | eVGA GTX 285 SSC | Customized Lian Li B25B | Antec Signature SG850 PSU | Windows 7 64 RTM
Gamer: Intel i7 920 (2.66) @ 4.0 | Water Cooled by Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
Weevil is offline   Reply With Quote
Old 10-26-2009, 04:47 PM   #3
SBB
No GPU in the loop, just CPU, ambient temps are probably about average room temp, 21-23 degrees or so, it's going pump > rad > cpu > res
__________________
Old 10-26-2009, 04:55 PM   #4
Hondacity
remount?
vcore?
__________________
Hondacity is offline   Reply With Quote
Old 10-26-2009, 05:10 PM   #5
dylskee
dylskee's Avatar
I'm in the same situation my friend!! I've got a pretty good water cooling setup and have tried remounting several times to no avail! My Idle temps are in the 40s and load temps are high 80s to low 90s. My Vcore is 1.26875 but even at stock my temps are high.
__________________
i7 920 @4200/1.268V----Classified X58 760
2X BFG GTX 285 2GB SLI /EK Full Coverage Water Blocks
APOGEE GTZ -MCR220- MCR320- XSPC Dual Bay Res/Pump Combo MCP350s
Gentle Typhoon 1850s
12GB 6x2GB Corsair Dominator 1600
2x 750GB Seagates - 1TB External HDD
850W CoolerMaster RS-850-EMBA PSU
Dell 2209WA 22" Chimei 22"
Windows 7 Ultimate 64bit
Heatware 92-0-0
dylskee is offline   Reply With Quote
Old 10-26-2009, 05:35 PM   #6
AzN_plyR
AzN_plyR's Avatar
What cases do you guys have? It makes a huge difference in my experience. My soon to be replaced A05B with the radiator inside loads 91-92, took it out and loads 72ish tops on a Black Ice GT Stealth 240 / GTZ combo. i7 920 4.1ghz 1.280 vcore.
__________________
A+ Black Pearl
GIGABYTE GA-EX58-UD5
Intel i7 920 @ 4.1ghz | Apogee GTZ | Swiftech MCR320 | Liang D5 Vario |
6gb Corsair XMS 1600
Visiontek HD 4870
3x 640gb AAKS Raid-0 Short-stroked 300gb
Corsair TX750
Olevia 42" 242TFHD 1080p
AzN_plyR is offline   Reply With Quote
Old 10-26-2009, 05:41 PM   #7
Weevil
Obsessed Member
Weevil's Avatar
Your idle temps are not to awful bad, but those load temps are pretty crazy. I would try what the other poster said first, remount. Also try disabling HT just to see if it makes a difference. Could just be that ya got a lemon.
My 920 does 4ghz on stock voltage, idles at 33c and loads at 54c. Thats with 2 320's and two GPU's in the loop.
__________________
wEeViL
Old 10-26-2009, 05:59 PM   #8
SBB
I can't remember my clocked vcore off hand, but increasing it from stock volts makes no real difference to temps. I'm going to remount tomorrow if I get chance, will let you know how I get on.
As for case, i've got a Lian LI PC-A70 full tower, with the rad mounted at the top, so it shouldnt be a problem.
__________________
Old 10-26-2009, 06:01 PM   #9
Hessen
Hessen's Avatar
There are definitely some dodgy 920s on the market, have seen some wildly different performances in similar chips recently. Hope you haven't got a duff
__________________
CPU: i7 950 (currently running at 4.00GHz on air)
Mobo: Asus Rampage II Extreme
RAM: Corsair XMS3 6GB (3x2GB)
GFX: 2 x BFG GeForce GTX 285 OCX 1024MB GDDR3
HDD: 2 x Crucial M225 64GB Solid State Hard Drive (Raid 0)
Hessen is offline   Reply With Quote
Old 10-26-2009, 06:38 PM   #10
overclocking101
overclocking101's Avatar
check VAPOR's I7 waterblock review revisited it shows the Dtek blocks need a mount mod to run i7 the right way that or you need a heat killer or apogee XT
__________________
EVGA P55 FTW::::Ci7-860(1.019 VID)@4000MHZ::::HD4850 ICE-Q4::::4GB CRUCIAL DDR3 1600MHZ::::TUNIW 120XTREME::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/ <<check it out
overclocking101 is offline   Reply With Quote
Old 10-26-2009, 06:57 PM   #11
millertime359
Xtreme Guru
millertime359's Avatar
I would upgrade your block to the Swiftech XT. I would think you would see a few degrees on improvement off of it.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-26-2009, 07:00 PM   #12
Hondacity
vcore affects the temps alot... unless your vcore is under 1.5v i wouldn't worry about the vcore...
there are some corei7 with high current leakage..those run hot..like my core 920
__________________
Old 10-26-2009, 07:07 PM   #13
Waterlogged
I am Xtreme
Waterlogged's Avatar
Even though it's actually for the FuZion V2.
+1
http://www.xtremesystems.org/forums/...d.php?t=233968
__________________
Waterlogged is offline   Reply With Quote
Old 10-27-2009, 04:23 PM   #14
dylskee
dylskee's Avatar
I've got a TJ07 with great airflow and nice fans so I'm certain I wouldn't see much of a difference with the rads outside the case. I'm actually still in the fine tuning stage of this build so I don't even have the sides on the case yet.
I'm looking for a lot more than a few degrees! I actually just ordered another 920 so I'll see if it's just a hot chip or my waterblock.
__________________
Heatware 92-0-0
Old 10-27-2009, 04:29 PM   #15
millertime359
Xtreme Guru
I was more refering to the OP.
The GTZ should be performing better than the fuzion V1, but if you are looking for lowest temps you can get, a HK or Swiftech XT might not be a bad idea.
Your buying a new 920 looking for lower temps, so a block upgrade doesn't seem unreasonable.
__________________
Old 10-27-2009, 04:30 PM   #16
Weevil
Obsessed Member
Weevil's Avatar
Please let us know how the new chip works out, I'm curious if this is a trend as of late, seeing a lot of these posts lately.
Edit, that goes for the OP too. ; )
__________________
wEeViL
Old 10-27-2009, 04:45 PM   #17
dylskee
dylskee's Avatar
It's a great clocking chip, just a hot SOB and it's driving me nuts not knowing why. I'm out of things to sell to buy another block but I would love to grab a Nickel HK!!
Will do, should have it by the end of the week I would think.
__________________
Heatware 92-0-0
Old 10-27-2009, 05:04 PM   #18
millertime359
Xtreme Guru
I'm actually a bit surprised that I haven't seen any on the FS section. I would of expected to see at least one with the release of the XT.
__________________
Old 10-27-2009, 05:49 PM   #19
dylskee
dylskee's Avatar
Is the XT supposed to perform better than the HK?
__________________
Heatware 92-0-0
Old 10-27-2009, 05:55 PM   #20
millertime359
Xtreme Guru
Vapor has it by a degree on a regular 920. Another review I guess shows the HK by a degree on a lapped 920.
Not huge gains, but there still was a lot of talk here about swapping out HKs for them. NTM, it seems a few guys around here buy CPU blocks like certain woman buy shoes.
__________________
Old 10-27-2009, 05:58 PM   #21
earthwormjim
Are you sure about your ambients? You should actually take a thermometer and put it right where your radiators take in air.
I have my computer underneath my desk. The ambient temperature of my room is usually around 25c. However the air right by my computer, the air my radiators are taking in is often 35c.
If you have high ambient temperatures that could be a big factor in your high CPU temperatures.
earthwormjim is offline   Reply With Quote
Old 10-28-2009, 06:26 AM   #22
nipper575
nipper575's Avatar
+1, depending on where your case is, it is probably intaking warmer than ambient air due to the heat not being able to escape from the case, this happened to me when I used to keep my tower under the desk. I could always feel hot air rising from under my desk. Also have to take the internal case temp into consideration if your internal rad exhausts air out of the case.
It really helps to know your ambient room temperature and the actual temperature of the air entering your radiator as they are not always the same.
__________________
~ Core i7 940 @ 4.00 ~ Gigabyte EX58-Extreme ~ Patriot Viper Series DDR3 6GB 1600 ~ Gigabyte GTX 260 SLi ~ Swiftech Apogee XT ~
nipper575 is offline   Reply With Quote
Old 10-30-2009, 01:42 PM   #23
dylskee
dylskee's Avatar
Got the new chip today and this one runs hotter so I think I have a cooling issue here. Not to threadjack the OP's thread I put my results in my original thread found HERE.
Have you had any luck with your temps Ben?
__________________
Heatware 92-0-0
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
