XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-26-2009, 12:06 PM   #1
Silaz
Send a message via AIM to Silaz
Best Cooling Solution?
I have an i7 940 and I have been running it at 191 x 21 since i got it. My current cooling setup is a TRUE black edition with two scythes 1600 rpm fans in push pull.
I've often been wondering if the new rev. C + 1366 true would get me more performance? Also, I wondered if I got two ultra kaze 3000 rpm if that would lower my temps? Lastly I just am looking for the best possible way to cool this CPU. Any input would be greatly appreciated!
Silaz is offline   Reply With Quote
Old 10-26-2009, 12:33 PM   #2
iTravis
iTravis's Avatar
Send a message via Yahoo to iTravis
You're not gonna see a big jump in performance since the TRUE is still one of the best cooler out there. But if you wanna see 1 or 2C in temp drop then you might wanna consider the TRUE copper, Megahalem or IFX-14. As for the Ultra Kaze 3krpm, unless you're okay with its noise then go for it since it moves lot of air but the thing is it's loud as heck. I was using 2 Ultra Kaze 2000rpm version and it works for me, performance falls right in between the 1k and 3k but ain't that loud.
__________________
1st Rig
CPU: Core i7 920 @ 4.2Ghz Mobo: eVGA X58 Classified CPU Cooler: Prolimatech Mega Shadow
GPU: Diamond HD4870X2 RAM: 3x2GB Corsair Dominator DDR3 1600 PSU: Corsair HX850W
Sound card: AuzenTech X-Fi Forte 7.1 HDD: OCZ Agility 120GB SSD OS: Windows 7 Ultimate x64
Display:
30" Dell UltraSharp 3007WFP-HC Speakers: Logitech Z-5500
2nd Rig
CPU: QX9650 @ 4.0Ghz Mobo: Asus Maximus Formula SE CPU Cooler: Thermalright Ultra 120 Xtreme
GPU: eVGA GTX 295 Co-op FTW RAM: 2x2GB G.Skill DDR2 1066 PSU: Corsair HX650W
Sound card: X-fi XtremeMusic HDD: 2TB OS: Windows XP
Display: 24" Dell UltraSharp 2407WFP Speakers: Logitech Z-5300
iTravis is offline   Reply With Quote
Old 10-26-2009, 12:55 PM   #3
zalbard
Xtreme Mentor
zalbard's Avatar
Send a message via MSN to zalbard
New heatsink is not necessary. Using 2x Ultra Kaze would certainly lower your temps, but can you stand the noise?
__________________
Donate to XS forums
>> Join Intel 4.5GHz LinX Stable Club <<
Looking for Gulftown / Westmere ES
zalbard is online now   Reply With Quote
Old 10-26-2009, 05:12 PM   #4
Silaz
So better fans are too noisy, and there is no better air cooler.
Is there any way to cool an i7 for 4GHz and above that you guys would suggest?
Old 10-26-2009, 08:39 PM   #5
iTravis
iTravis's Avatar
You trade off noise for performance and there are some that fall between the 2 like Scythe Typhoon, Enermax Magma...if you want the best of the best then take a look at the Delta fans but I'm sure you don't wanna sit next to a vacuum cleaner or hear the sound of the jet taking off. I've been using the Cooler Master R4 and Ultra Kaze 2k and quiet happy with them. Just get a good thermal paste like the Shin Etsu or Indigo Xtreme, slap on that TRUE with 2 good fans and you're good to go. Most people have no problem running a core i7 @ 4.0Ghz 24/7 with air cooling like myself.
__________________
1st Rig
Display:
2nd Rig
Old 11-09-2009, 12:02 PM   #6
BlindFreddie
You won't get much better than your TRUE, with good pressure onto CPU - see washer mod somewhere here on XS.
I assume that you've lapped it. If not, DO IT.
For minimum noise, 2 medium-speed fans should be better than 1 faster noisy one.
On some coolers, I think extra airflow won't help much, as past a certain point the fins are already cool and the heat bottlenecks are somewhere further down in the system - heatpipe capacity, cooler base-to-heatpipe transfer, uneven base or CPU surface, TIM quality, CPU silicon to CPU heatspreader.
If you want to look at other heatsinks, see the test linked from here: RoundUP: 23 SuperCoolers tested (extreme TDP, lapping, moding, 250CFM+)
Meghalems look good, and I just bought one.
Forget the IFX-14. The TRUE is better.
BlindFreddie is offline   Reply With Quote
Old 11-09-2009, 04:18 PM   #7
Kain XS
Kain XS's Avatar
Send a message via MSN to Kain XS
Megahalems looks good, but really, don´t expect that much coming from a TRUE. It still works like a charm.
Kain XS is offline   Reply With Quote
Old 11-09-2009, 10:56 PM   #8
Computurd
Computurd's Avatar
Copper True FTMFW~!
__________________
"Lurking" Since 1977
Computurd is online now   Reply With Quote
Old 11-21-2009, 01:33 PM   #9
BababooeyHTJ
I am Xtreme
BababooeyHTJ's Avatar
A good lap job and pressure mod would give him better temps without the extra noise.
__________________
Asus P5Q Deluxe bios 2001m, Intel q9650, True black, 8gb G.Skill 4x2gb PC8500, Evga GTX280 SSC, HR-03 GTX, Pc Power and Cooling 750w silencer, Antec 1200
Originally Posted by LiberalElephant View Post
ASUS actually hates you and wants you to die by way of freak south bridge chipset fire than eventually englufs your entire house while you sleep. The kicker is that ASUS installs a program on your computer that causes it to download gay porn while you are idle until the south bridge over-heats and you die in a gay-porn fireball. Your relatives find your hard drive full of gay porn and the evil empire of ASUS has struck again.
Disclaimer: Being gay is okay. ASUS is not actually trying to kill you in a fireball of gay-porn.
This post was worthless and I am very very bored.
BababooeyHTJ is offline   Reply With Quote
Old 11-22-2009, 01:26 AM   #10
pr@$r1g
pr@$r1g's Avatar
^^ thats a good option ,i lapped my Megahalem & saw a 5`c drop across allmy cores my core i7 920 @ 192x21 it rocks & mem @ 1820 888 24 1.74v
__________________
|~Prolima Megahalems~|Lapped & temps were -8 compared to non lapped
|~Core i7 920 C0~|186*21=3900MHz@1.168v 24x7
|~Gigabyte EX58UD5~|EX F9R bios DVID rocks !
|~SuperTalent WB200UX6G9~|1860MHz 7-8-7-23 1t @ 1.65v
|~Sapphire HD5770~|flashed to ASUS
|~CM Storm SCOUT~|
|~Seasonic M12D 850W~|
|~BenQ E2200HD~|
pr@$r1g is offline   Reply With Quote
Old 11-22-2009, 04:32 AM   #11
dan7777
+1 the megahelems in push pull with delta fans will take some beating and thats what i have with 2000rpm can go up to 4000rpm get the ear plugs out though lol
dan7777 is offline   Reply With Quote
Old 11-22-2009, 04:12 PM   #12
vengance_01
If you have a Fry's near The corsair H50 is a good buy at 55$.
__________________
Desktop:
Antec 300
Foxcon A7AD-S 790GX
8GB Gskill PC-1066@5/5/5/12
PII X940 BE @3.6GHZ
Sunbeam Core Contact
2x 640GB in Raid 0+1
4870 512MB@800/1000
Vista Business 64bit W/ SP1
vengance_01 is offline   Reply With Quote
Old 11-22-2009, 08:57 PM   #13
Computurd
Computurd's Avatar
corsair h50 gets good performance for what it is. actually surprisingly good performance.
__________________
Old 11-22-2009, 09:21 PM   #14
Darkboss
With the TRUE rev. B, does one still have to lap it? I have the rev. B and my temps are still about 40-42C idle and around 72-74C load in my Cosmos 1000 case. I have two scythe ULTRA KAZE 120mm Case Fan 2000rpm in push/pull on it and am very disappointed in the cooling. I'm at 1.23V or so on vcore in bios and I am at 181x20 with turbo and ht on. I'm thinking I need better case fans or need to reseat the hsf and reapply the TIM again on this thing. I don't think this rev needs a pressure mod and I was hoping I don't have to lap it but I might have to give that a try. I've never lapped anything before so I don't want to have to take the time to do that.
__________________
920 @3.8GHz(181x20) CO/C1 @1.23-1.25V, Turbo on, HT-on, giga UD4P, 3x2GB Gskill, EVGA GTX 295, TRUE rev.B
Darkboss is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
