XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > T.E.C. Cooling
Reply
Old 10-26-2009, 10:41 AM   #1
gadgeteer123
What should i use my peltier for?
So i have posted a few threads asking about methods for my 177watt qmax peltier, and you guys have ruled out using it on my cpu, graphics card, and also as a pc case cooler(even though i have seen factory built tec coolers that where only 40watts for pc cases). so could you guys just throw some ideas at me for what i should use my peltier for besides a fridge or drink cooler?
gadgeteer123 is offline   Reply With Quote
Old 10-26-2009, 11:11 AM   #2
gadgeteer123
I was wondering, i have always wanted to build a old gaming system that could run windows 98 for all of my old games, and i have a 933mhz pentium 3 with 256k cache and a 733mhz pentium 3 with 512k cache, so if turned the power down a little bit to this peltier would this kind of setup work?? with that 145 watt heatsink i have if i put a much higher flow fan on it?? i'm just bored and i was going to built that system stock anyways so why not peltier cool it, right?
Old 10-28-2009, 10:55 AM   #3
Serra
Xtreme CCIE
Serra's Avatar
^ While I'm sure you could do it, I would like to toss in that you can accomplish the same objective (a Win 98 system to play DOS-based games on) via VMWare and save yourself the time/space/power of running a second box for it.
No idea what you can do with a pelt of that wattage otherwise, sorry.
__________________
CPU: Dual Xeon E5520
MB: Supermicro X8DTi
Mem: 12GB (6x 2GB) Corsair ECC DDR3-13333
Storage: 4x WD640AALS on PERC 6/i
Case: Sitting on top of motherboard box.
PSU: Cooler Master UPS900
OS: VMWare ESXi 4.0... so... "various"
GPU: N/A
Display: N/A - Accessed via network
Serra is offline   Reply With Quote
Old 10-28-2009, 12:03 PM   #4
zipdogso
I am Xtreme
Yep VMWARE would be a good route if you had the money, it is a seriously good bit of kit and in my view cheap for what it does.
But as I am sure you may be finally realizing now your TEC isn't much use on it's own.
__________________
Upgrade your XS account with a subcription
http://www.xtremesystems.org/forums/....php?f=94&a=66
zipdogso is offline   Reply With Quote
Old 11-11-2009, 03:43 AM   #5
lalPOOO
XS - Extra Strong
lalPOOO's Avatar
All depends how much work you're willing to put in. You could definitely throw it on a north bridge, or build a block(s) to cool either your ram or your videocard ram with it. Also works as a load testing device should you ever need one.
__________________
-OPT 165@2860mhz
-DFI Lanparty Ultra D + 2x512 OCZ PC4000EL gold
-Geforce 7900Gt 745/1863 1.562v vgpu
-OCZ Powerstream 520w
lalPOOO is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
