XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-26-2009, 06:14 AM   #1
sdumper
-100c club
sdumper's Avatar
Re Flare or loctite
Flare looks good and it doesnt leak from the flare end. Instead its leaking from the thread should I reflare or just use Loctite?
Im leaning heavily towards loctite because it has never failed me but i wanted a second opinion.
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 10-26-2009, 08:07 AM   #2
wdrzal
I am Xtreme
wdrzal's Avatar
Doesn't matter what end leaks.......The Flare/shoulder are leaking.
The only place a flare seals is on the front of the flare face to the matting shoulder.
The Threads only apply pressue to form a metal to metal seal.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 10-26-2009, 09:45 AM   #3
sdumper
-100c club
sdumper's Avatar
Thanks Walt I will cut and repeat
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
