XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-25-2009, 02:33 PM   #1
blinker0
UMM Yeah
Send a message via Yahoo to blinker0
Drier Filter ?
I'm getting stuff together for My first Phase in a long time.. Since Socket A AMD'S if that gives it away.
In my first unit I built I didn't use a filter drier on the high side. But used a suction line drier. Like I said my first one and I made a lot of mistakes
My question is , Is a drier necessary on the hight side?
blinker0 is offline   Reply With Quote
Old 10-25-2009, 02:44 PM   #2
sdumper
-100c club
sdumper's Avatar
yes...and come on they only cost like what $4.50 for a spun copper filter drier at your local united refrigeration
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 10-25-2009, 03:00 PM   #3
blinker0
UMM Yeah
It wasn't a cost issue. just curious. Besides filtration. Exactly whats the importance on which side the drier is on? Not trying to argue would just like to Know?
BTW I do already have one. was just debating to use one or not
Old 10-25-2009, 03:50 PM   #4
sdumper
-100c club
sdumper's Avatar
Captubes get clogged so you want it on your liquid side before your captube....
__________________
Old 10-25-2009, 04:21 PM   #5
blinker0
UMM Yeah
ok thanks
Old 10-25-2009, 07:02 PM   #6
wdrzal
I am Xtreme
wdrzal's Avatar
You need to be carful on those spun filters or fiter/dryers. Many are only a filter to protect the cap tube but have no Desiccant for moisture removeal.
Especially on ebay, most don't know the difference. Check part #'s
If you not using new tube,didn't purge or there may be foreign material in the low side, a suction line filter will help protect the compressor
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 10-25-2009, 09:10 PM   #7
sjg0
sjg0's Avatar
wdrzal, are you saying just using a filter/drier on the suction line can be substituted for purging lines?
Of course im sure it's not recommended and would decrease performance a bit, but it would work?
__________________
#1
Pentium D805 @ 3.4Ghz on GA-945P-S3
2Gb OCZ Gold 800 with XP Professional SP3
Ati X1800XT
550W Antec TruPower in Antec Sonata II
#2
Core 2 Quad Q9550 on GA-EP45-UD3P
4Gb Corsair Dominator 1066 with Vista Ultimate SP1
Asus 4850 TOP
750W PC Power & Cooling in ????
There is not enough electrical oulets in my room.
Best TF2 Quote:
"tomtom92 : wtf the enemy has a base IN our base"
sjg0 is offline   Reply With Quote
Old 10-25-2009, 09:15 PM   #8
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Never know how fine the filter is and you could end up with minute quantities of abrasive oxidized copper floating around in your oil.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 10-25-2009, 10:14 PM   #9
wdrzal
I am Xtreme
wdrzal's Avatar
No I didn't say that........
__________________
Register today .
Old 10-25-2009, 11:21 PM   #10
sjg0
sjg0's Avatar
Okay, although not explicitly stated, i thought that is what you were suggesting here...
I was kinda hoping just buying an extra filter for the low side would be possible... I really hate purging... biggest pain in the ass of my life...
__________________
#1
Ati X1800XT
#2
Asus 4850 TOP
Best TF2 Quote:
Old 10-26-2009, 05:22 AM   #11
blinker0
UMM Yeah
thanks guys... Even though I didnt use one on my first SS ( it did last years) till it was just too small. I Just wanted clarification on the importance on SS. I always purge At work.. So thats not a problem.
Old 10-26-2009, 03:23 PM   #12
wdrzal
I am Xtreme
wdrzal's Avatar
Thats because you guys make it difficult...........every time you guys hook up a joint or 2 ,you braze it.Don't do that
Complete the entire stage at least before you even light the torch.
The only exception maybe is a difficult evap.
__________________
Register today .
Old 10-26-2009, 04:20 PM   #13
blinker0
UMM Yeah
The practice i always use (AT work) is atleast two access ports .I start brazing the farthest joint away from the access i am purging from, When i start to get close the the access i am purging from , I stop let my joints cool. then connect to the access I first started brazing at and finish my joints
May be the wrong way.. but it thats what i was taught to do
Old 10-26-2009, 04:22 PM   #14
sjg0
sjg0's Avatar
Then how would the shielding gas pass through the compressor to low/high side if you had the entire loop closed off?
__________________
#1
Ati X1800XT
#2
Asus 4850 TOP
Best TF2 Quote:
Old 10-26-2009, 04:53 PM   #15
blinker0
UMM Yeah
through the condenser
Old 10-26-2009, 07:22 PM   #16
ultralo1
ultralo1's Avatar
X100. It is one of the hardest things to get people to do, even "expeirenced" HVAC techs.
I start were the N2 comes in at and follow the flow of gas.
__________________
Quoted from SoddemFX:
"I frankly have no idea what you are trying to do. I have received more comprehensible correspondence from Mr Obuwonga Mwahahu, who i believe wishes to give me a 10% share of his $12M fortune held in the royal bank of Nigeria."
ultralo1 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
