10-25-2009, 01:42 PM
#1
Bench Singlestage 300watts @ -40°C
10-25-2009, 01:50 PM
#2
-100c Club
Totally awesome unit!  Great temps for such a heat load!
10-25-2009, 03:05 PM
#3
Nice work. Really fine build.
10-26-2009, 01:10 AM
#4
hey but is in a Ec unrockstar work shop ?!!
10-26-2009, 01:29 AM
#5
Beautiful pipework
__________________
Originally Posted by [XC] Hicks121
Ahhh keep it CD. You can never have enough pussy.
נְפִילִים
10-26-2009, 01:53 AM
#6
good work patrick
__________________
10-26-2009, 01:58 AM
#7
Very, very strong SS! Also, very clean work. Can't wait to see it doing work
__________________
Heatware
filmbot
10-26-2009, 05:05 AM
#8
Thanks guys
@ tanguintel
You´re right. My oxygen was empty and I had to shorten the capillary tube so I took the unit to the company where Unrockstar works and asked his boss if I can use the brazing tool.
10-26-2009, 11:27 AM
#9
-100c Club Member
beautifully done patrick
a pleasure to look at
__________________
1. The first rule of Bench Club is, you do not talk about Bench Club
2. The second rule of Bench Club is, you do not talk about Bench Club
3. If someone says stop, goes limp, taps out, the the benching is over
4. No bummers in the batcave, apart from unkie dave
5. One Bench at a time
6. No air, no water
7. Benching will go on as long as they have to
8. If this is your first night at Bench Club, you have to Bench
10-26-2009, 11:35 AM
#10
HEY HEY
thats an awesome looking unit man
keep building it
10-26-2009, 01:14 PM
#11
Looks Real Nice Can't Wait To See Some Numbers
#12
Really decent unit  German precision
10-26-2009, 06:42 PM
#13
Very nice, Well done
__________________
I would have replied sooner but the compression explosion device in my motion traction system needed to be replenished with distillation fractionation of fossilisation extraction....
(a SoddemFX original)
10-27-2009, 06:08 AM
#14
very nice temps and unit
10-27-2009, 03:44 PM
#15
-100c Club Member
Why You've mounted condensor and fans in such, bit non standart way ?
Unit looks very good
Regards
10-27-2009, 03:54 PM
#16
this mounting method reduces the high pressure. i´ve tested that on a small condenser in a water chiller, so i did it the same way on this unit.
i think that pushing / blowing the air through the condenser fins pushes the hot air better out of the condenser than the sucking mounting.
10-27-2009, 05:58 PM
#17
You are right, you create positive presure on the condenser by pushing air thru, and negative by sucking. Offcourse the first is the best.
Isn't the desuperheater a litle too tight?
The insulation is lovely
10-28-2009, 04:00 AM
#18
it´s not a desuperheater it´s more a vibration damper.
I think the condenser is big enough.
10-28-2009, 12:59 PM
#19
I know that we misuse the desuperheater word around here, I was pointing out that the coils are so tight togheter
11-02-2009, 11:13 AM
#20
Banned
wow nice work bro
11-06-2009, 01:41 AM
#21
Great
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
