XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-24-2009, 05:09 PM   #1
Thasp
Scythe mugen 2 and AM3, is this good?
My CPU temp at max load is 11c over the mobo temp, at 100% CPU load, with a 1600 RPM fan on the cooler. It's the AMD Athlon II X4 620 quad core AM3 CPU.
The room was pretty warm and the mobo read 28c, cpu 39c. All the fans are the nexus quiet kind, except for the CPU fan which is a 1600 RPM antec. Still a quiet fan.
At night the room gets cooler(high 60s/low 70s). If I turn all the fans in the case down to 5v where they barely spin, the mobo is 25c, and the cpu 40c, at full load.
I ask because it was difficult to install. It doesn't bolt on from the top, it bolts on from the bottom, which makes it very awkward to screw in. I have to hold the mobo to the heatsink while screwing it on, which means there's a chance for it to move around and for the heatsink to get pulled on and off slightly as I screw it on. I remounted it once but the performance didn't change, which means I either messed up both times or this is as good as it gets.
Please let me know if my aforementioned results make any sense for this CPU.
__________________
Originally Posted by asus support
Originally Posted by Asus Support
Hello,
The tech support team, unfortunately, is not 'in the loop' regarding what, if any, changes are planned for any BIOS, for any board, so we can't say what, if anything may be done, or when it's released, nor does our engineering department have a point of contact for this type of query. All we can suggest if you own the board is to check the download page periodically to see what is available.
Regards,
Asus Support Team
Thasp is offline   Reply With Quote
Old 10-25-2009, 10:23 AM   #2
demonkevy666
demonkevy666's Avatar
Send a message via MSN to demonkevy666 Send a message via Yahoo to demonkevy666
I would change the stock fan on the heat sink.
or you could lap the chip my phenom II 940 is lapped.
seems to help a lot. the heat sink is already flat.
__________________
http://www.youtube.com/user/golem720.../0/GKiZtsEVb8I
^ EVIL BUNNY
HTPC coolermaster 690 sempron 140, Gigabyte UD3H, ddr3 1600mhz, 650 ps, 160gb hard drive currently running windows vista 64 bit (30 days)
AMD Green & black dragon GODZILLA get it it's now classic XD
foxconn destroyer revived Thermaltake Xaser IV case (bought)
285gtx 2gbs need to save cash now
demonkevy666 is offline   Reply With Quote
Old 10-25-2009, 11:39 AM   #3
iandh
Zombie Assassin
iandh's Avatar
Pick up a Gentle Typhoon 1450rpm, it's the perfect fan for that heatsink.
I'm running one and never pass 45C in OCCT with CPU at 1.45v 3.8Ghz
__________________
i5 750
Asus Maximus III Gene
Patriot Viper II Sector 5 DDR3-1600 4Gb
XFX 5850 1Gb
Antec NSK3480/Seasonic SS-500HT
iandh is offline   Reply With Quote
Old 10-25-2009, 02:00 PM   #4
Thasp
I don't use the stock fan since it wouldn't run at 5v, I use a 120mm Antec fan that came with the Antec 300 case I bought. Right now the room is semi cool, 28c mobo, 44c CPU at full load, and the thing doesn't make a sound with everything running at 5v. I think I'll try remounting it. I am running the CPU at stock.
The nexus fans are 1000 rpm @ 12v, so I can imagine how little they move at 5.
I am curious, how did you guys install this properly? It bolts from the bottom of the board. So you need one hand to hold the mobo, the other hand to hold the heatsink. Do you screw it in with your foot?
__________________
Hello,
Regards,
Asus Support Team
Old 11-04-2009, 03:35 PM   #5
Rucker
I used a second person This is definitely a three hand installation heatsink.
Rucker is offline   Reply With Quote
Old 11-04-2009, 04:40 PM   #6
shaolin95
shaolin95's Avatar
It is tricky but I did it on my own. Sorry but cannot remember how. Just get into your best MacGyver mode and you can do it.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 11-05-2009, 12:51 AM   #7
richierich
richierich's Avatar
Scythe Mugen 2 is one of the best. Just make sure to have help when installing.
__________________
Phenom II 550 unlocked 3.3GHz @ 1.26v / Scythe Mugen 2 + Gentle Typhoon Push Pull
Gigabyte MA790XT-UD4P / OCZ Gold PC3-8500 @ 1333MHz 6-6-6-17-11 1.75v
SuperTalent UltraDrive ME 64GB SSD / Seagate 1.5TB / 8800GT 512MB
Antec NeoPower HE 550w / Antec 300 / Win 7 HP 64-bit
richierich is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
