10-24-2009, 10:22 AM
#1
High vcore i7 Megahalem/TRUE Owners
Basically i'm pushing my old c0 i7 920 to the max (24/7) till i switch to i9 in March/April.
I've been using an Akasa Nero since i got the i7 a yr ago at:
4ghz (191x21) 1.46v, two 70cfm fans (push-pull).
Idles 40's
loads 95's
I've discovered just recently i can get it to 4137 (197x21) but to do this i'm requiring 1.51v and my poor old Akasa Nero just can't handle it..
So my question to you Megahalem/TRUE Owners is;
Anyone else using this level of RIDICULOUS voltage, cause i would love to know the temps, or even if the cooler can handle it at all?
I really don't want to switch to Water as i don't trust the concept of it.
10-24-2009, 11:25 AM
#2
true black + push pull of enermax magma and solve it
my voltage is 1.232v oc 4ghz.
max temp on core is 75-80° but is a d0.
10-24-2009, 11:31 AM
#3
That's all well and good, but some temps and voltages would be nice..
10-24-2009, 11:58 AM
#4
1.50v 24/7 on air cooling is way too much for even a lapped, pressure-modded TRUE Copper + 2x120x120x38 high cfm fans.
You'll see electromigration/degradation issues in a week at most.
__________________
|| X58 rev.B3 | SLBEJ 3916B093 | 3x2GB Elpida MNH-E Hyper | Cypress XT | Postville | 4x7K2000 R5 | X-FI HTHD | 24" 16:10 H-IPS ||
10-24-2009, 12:28 PM
#5
doesn't matter i'm getting i9 in March/April.
I''ve been running 1.46v for over a yr now without any issues/trouble so i doubt its going to do much more..
If either of these heatsinks can hold 90-95 degrees @ 1.50v i'd be happy with that!
10-24-2009, 05:21 PM
#6
Certainly I wouldnīt recommend more than 1.45v and preferably 1.4v for 24/7.
You will have lower temps of course but I canīt think that being good enough.
10-24-2009, 10:59 PM
#7
Prolimatech Megashadow
__________________
- Core i5 750
- ASUS Maximus III Gene
- Kingston HyperX 4GB/1600
- ASUS ENGTX275
- WD1500HLFS, 2500AAKS, 2500YS, 2x 5000AADS
- Thermaltake Toughpower 750W
- Lian Li PC-V1110B
- Dell 2208WFP
- X-Fi Xtreme Music
- Klipsch ProMedia 2.1 THX
- Prolimatech Mega Shadow
- SilverStone FM123
10-25-2009, 12:31 AM
#8
The un-extreme XIP
I've been playing around with a megahalem on a 975xe this week. 1.4v at around 4.3GHz hits 85C (realtemp) using intelburntool. At that point, the system is less stable given more voltage because of the high temps.
fan=120mm at ~2500rpm.
__________________
Q6600@3.6ghz 1.45V ----- 8gb ocz ddr2-1000
XFX 5850@900/1200 1.15V
1TB hitachi+2x30gb OCZ Vertex v1.41 raid 0
520HX corsair power supply ----- half-size shuttle!!
30" 3007wfp-hc 2560*1600 lcd
unicomp clicky keyboard+logitech trackball
10-25-2009, 05:31 AM
#9
Thankyou! that's what i was after.
"Cirthix" Is that just one fan? And inside a case?
It looks like it might be close, my CPU load is never over 85% normally so hopefully (taking your results) it will be around 90-95 degree mark for me.
10-25-2009, 01:55 PM
#10
The un-extreme XIP
No case, air conditioned room (~77f), one fan. Fan is a 1.3A 38mm thick one, don't remember exactly which. TIM=ceramique.
__________________
10-25-2009, 03:54 PM
#11
Xtreme Cruncher
why are you trying to push for the extra 137mhz if your load is never over 85%? seems like a waste of money to get a new heatsink that may or may not help you,the fact that your running the chip at 95C is absurd IMHO. are you trying to cook food with your computer? i don't have an i7 but i've never seen my x3330 over 50C at load at 3.8ghz running Orthos.
__________________
XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.9ghz @1.32v under load, corsair dominator ddr2 1066 4gigs, evga gtx260 core 216, pc p&c 750W, TRUE Black, Lian Li v1200b
silverstone tj07 build log
10-25-2009, 06:03 PM
#12
Dunno tbh, if it can be done.. why not?
Normally i get the CPU bellow the extreme edition, but went for a i7 920 instead of the 940.
As mines a terrible c0 and i'm getting i9.. I cannot honestly care if it goes bang.
Anyway, cheers "cirthix" just ordered one, and two Yate Loon D12SH-12 2200RPM fans. (88cfm) Oh, and some AS5 of course.
Lets see if it does the job.
10-25-2009, 07:22 PM
#13
Xtreme Cruncher
Dude, you need water.. or a better CPU xD
I9 is a long way off, even if some people already have some
10-25-2009, 07:39 PM
#14
Two yate high speeds aren't going to hold up to that load. You will need 38mm fans Panaflos or Delta or something.
10-29-2009, 05:24 PM
#15
I have a D0 chip sitting at 4ghz, with 1.36v LLC disabled (1.28v on load). Max temps are usually around 75c with my Megahalems, with spikes up to 78c, but it doesn't linger there very long.
I just ordered 2 Noctua NF-P12 fans though, which I hope will reduce temps closer to 70c, which means I can lower the voltage a bit more.
If you got a Megahalems, you probably wouldn't need that much voltage, and your load temps would drop by 10 degrees I'd wager..
95c on load is insane!
__________________
Intel Core i7 920 SLBEJ D0 @ 4.2ghz
Prolimatech Megahalems w/ Scythe Kaze-Jyuni
GIGABYTE GA-EX58-UD5 Extreme Mode F9e bios
6GB G.Skill Trident DDR3 @ 1600 6-7-6-16 1T
EVGA Geforce GTX 285 @ 756/1620/1455 (waiting for GTX 380)
EVGA Geforce GTS 250 for dedicated PhysX @ 800/1900/1200
Creative X-Fi Titanium Fatal1ty Champion
Sennheiser HD-555
Western Digital Caviar Black 640GB x 3 RAID 0
Sony Optiarc 24x DVD Burner with NEC chipset
Kingwin Mach 1 1000W SLI Active PFC Modular Power Supply
Samsung 305t Plus 30 inch LCD monitor
Coolermaster HAF 932
Microsoft Sidewinder w/Razer Exact Mat
Microsoft X6 keyboard
Windows 7 Professional x64
CyberPower 1500VA/900W UPS back up
10-29-2009, 06:15 PM
#16
The un-extreme XIP
I don't recommend it either, I was just giving him the info he wanted. My test was done specifically to load the vcore regulator as hard as it could be without crashing intelburntool, not something I'd run every day.
__________________
10-31-2009, 07:50 AM
#17
I think that thread writer just need to "level up" to liquid cooling.  This is bit too much for air cooling.. at least conventional.
__________________
i7 920 C0 - 3,4 GHz /HT on + Megashadow
3x2GB CSX 1600MHz CL8
Foxconn Bloodrage rev. 1.1 - G32
XFX HD 4770 (slight OC)
IBM 74GB 15k SAS
Seagate Barracuda 7200.11 640GB + 1TB External
Corsair HX 850W (its GOLD man!)
Auzentech X-Fi Forte 7.1 + Sennheiser 555 (595 mod)
No cam - temporary I hope. My Flickr
11-03-2009, 12:59 PM
#18
Long time since reply due to illness.
But a little update..
The Megahalem temps are about 5-7 degrees less than my old Akasa Nero, which is pretty good!
At the moment i'm using 194x21 / 4075mhz @ 1.49v
temps are around 95 again.
I'll keep pushing come the weekend.
11-03-2009, 01:03 PM
#19
The un-extreme XIP
sorry, but that is retarded. drop your voltage to something around 1.35 and you'll get a better overclock. voltage isn't limiting you right now, it's the core temperature.
__________________
11-03-2009, 02:19 PM
#20
I have ran some high temps with my CO when i was first playing with it and a copper true, but no where near those volts! IF it is taking you 1.49v to get to 4.1 then you have a really sorry chip, even for a CO. I agree with cirthrix, you should lower your vcore, you push it too high you are gonna be unstable just because of over-voltage. Somewhere along the lines your OC on that chip must be being affected by something else like yer pll or NB volts. if you tweak those, it will probably help. I have a hard time seeing that your oc is very good at all with those volts.
__________________
"Lurking" Since 1977
11-04-2009, 09:01 AM
#21
It's just a terrible c0.
It's not like i run 100% usage 95 degrees all the time.
Its usually 85% usage MAX 85-90 degrees.
Like i said i don't mind if it goes bang (i'd just perfer it doesn't take out the mobo in the process).
11-04-2009, 04:01 PM
#22
Are you serious? 95 degrees is insane. Either lower your voltage or don't push your clock speed this far, it's ridiculous.
11-07-2009, 08:31 AM
#23
Its not that "insane" .. its just "not recommanded".
I have Megashadow now (nickel-plated Megahalem) - 69°C - 1.31V - hottest core .. at OCCT it reached max 72°C I think.. yea and HT enabled.
So, yes its ok, but not much better than Xigmatek Thorīs Hammer (3°C difference? ergh)
I can test 4GHz at your setting later.
__________________
IBM 74GB 15k SAS
11-08-2009, 12:37 AM
#24
I added a second Scythe Kaze-Jyumi fan to my Megahalems and now my max temp is 74c @ 4ghz where before it was 78/79c.
The noise is killing me though! I also tried 2 Noctua NF-P12 fans in push pull config and although they were virtually silent, my temps climbed to 83c under full load, so I took them off.
Might put them back on again though, because the noise with the 2 Scythes is annoying me.
__________________
Sennheiser HD-555
11-08-2009, 04:36 AM
#25
Soo.. OCCT says 75°C top.. which ainīt bad, plus its very unlikely to reach that load in normal circumstances - Megashadow with 2x Yate Loon 120mm - 1300 RPM .. its almost whisper silent + Coolaboratory Liquid pad as TIM.
Btw. Megashadow or Megahalem donīt profit much from higher RPM fans, thats more TRUE part, which can benefit from higher RPM (eg. higher CFM).
Hmps, I can make 4GHz stable.. not bad.
__________________
IBM 74GB 15k SAS
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
