XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-23-2009, 02:49 PM   #1
hkfeet
Anyone know where to buy kits for Prometeia Mach I
I have the Prometeia Mach I, and its basically sitting in storage and not in use. Since I have no where to sell it, Im thinking of using it, but unsure where to buy the cpu kits. Anyone know where I can find some for the black Mach I
hkfeet is offline   Reply With Quote
Old 10-24-2009, 12:55 AM   #2
hkfeet
Can the Mach II kits work with the Mach I ?
Old 10-24-2009, 01:10 PM   #3
ruffus
yes they can there all the same evap as well i have the mountings for 775 and am2 just have to look for them got a lot of that seal string as well
ruffus is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
