XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Chilled Liquid Cooling
Reply
Old 10-22-2009, 11:57 AM   #1
lior307
Send a message via AIM to lior307
New Chiller - Questions for Pro's
Hi guys ,
I'm building a Chiller for VGA loop and i need your help on a few Parts:
I had a Mini Fridge and i took from it the Compressor:
i Have ZEM GL 45 AG Compressor which is Equals to Danfos TLES4F / TLS4F .
Here are my questions:
1. Which Capillar Size and Length i need ?
2. Which Oil do i need ?
3. how much ml to buy ?
Thanks ,
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
GigaByte X58 Xtreme,
lior307 is offline   Reply With Quote
Old 10-22-2009, 02:54 PM   #2
repsol_23
repsol_23's Avatar
I don't think that you are going to see the results that you are looking for with mini-fridge compressor. Those compressors are not made to run for extended periods of time and can burn out if run for too long. I you are wanting a compressor for this kind of use I would suggest to take one from a window AC unit or something along those lines. Hope this helps!!
__________________
Primary Rig: DFI Lan Party LT x48 (@500 FSB) // X6800 @ 4 Ghz (1.47V) // Geil Evo One (2x1Gb) DDR2 800 @ 1000 Mhz (2.2V) // Sapphire 1Gb 4870 // WD Raptor 160 GB (XP) // Seagate Barracuda 500 GB (Vista) // Creative X-Fi Xtreme Gamer Edition // Thermaltake ToughPower 700W // LG 23" @ 1920x1080
repsol_23 is online now   Reply With Quote
Old 10-23-2009, 12:53 AM   #3
lior307
This Chiller is just for Benchies - not for 24/7 .
It's a 1/8HP and should be enough for VGA Card .
I just need to know which Capillar to use and type and quanity of OIL to put .
I'll be using R507 with this compressor.
The Danfoss TLES4F is the equvivalent to my compressor -but can't find which oil and capilar .
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
Old 10-23-2009, 01:55 AM   #4
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
Here's the PDF on TLES4F: http://www.ra.danfoss.com/TechnicalI...1_Cg42d302.pdf
1) TLES4F uses POE oil, you need to put 180ccm in it.
2) Start with 1.5m TC-31 cap tube
tiborrr is offline   Reply With Quote
Old 10-24-2009, 02:07 PM   #5
lior307
Thanks - Great help as Always from you .
"TLES4F uses POE oil"
Is this OIL is good also for the Danfoss NL11F Compressor ??
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
Old 10-26-2009, 06:15 AM   #6
lior307
Bump !!!
Is the OIL for Danfos NL11F is the Same Oil for Danfoss TLES4F
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
Old 10-26-2009, 10:37 AM   #7
Naja002
I am Xtreme
Naja002's Avatar
The NL11F uses POE
R507 uses POE--page 6
HTH
Naja002 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
