XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Dry Ice and Liquid Nitrogen
Reply
Old 10-21-2009, 07:20 PM   #1
Sil3ntSnip3a
Sil3ntSnip3a's Avatar
Send a message via Skype™ to Sil3ntSnip3a
Pot Design and Fabrication
Recently I made what I call a "Throw together pot" and it was what I say it was. I found some random copper and had a braze torch that I torched a base on, added dry ice and SHAMWOW! it cooled my cpu down to -78c.
But here is my question... So I have seen many beautiful pots that have been custom designed and fabricated by Duniek etc.. What is the program that people use? Is it free? My dad is pretty familiar with CAD and could help me with creating a pot and fabricating it, I just needed to know where to start.
__________________
Sil3ntSnip3a is offline   Reply With Quote
Old 10-21-2009, 09:21 PM   #2
bartx
bartx's Avatar
Send a message via MSN to bartx
What CAD? Just a drawing on piece of paper (in my case).
bartx is offline   Reply With Quote
Old 10-22-2009, 10:09 AM   #3
Foamy
Banned
google sketchup my son
Foamy is offline   Reply With Quote
Old 10-22-2009, 08:35 PM   #4
Sil3ntSnip3a
Working with google sketchup. I really like this easy to use program!
Here are a few drawings I came up with as to what I would like to do
I do have a question though
So I plan on having a 2.36" diameter aluminum pot w/ a copper base. Here is my question... What is the best size neck for the base, and the design inside the base also?
Thank you
__________________
Old 10-23-2009, 01:03 PM   #5
Foamy
Banned
When designing a pot you want to achieve the following :
1 - temperature controlable to a degree
2 - no temperature swing
3 - keeping load, minimal temp dropping
---->enough mass presence in base that can be touch on lot's of places by the LN2/dryice
How to reach this? Wel it's tricky and i recommend you to make a customload tester. And see what it does when having a different structure base.
By my opinion the best design yet to date is team Japans design, and it's pretty simply a base with drilled holes.
ps, go square
Old 10-23-2009, 11:02 PM   #6
Oj101
Crunching 24/7
Oj101's Avatar
Points 2 and 3 amount to the same thing, ability to hold temperatures. Basically, you need to balance mass with surface area. My favourite design does NOT have holes in the middle but rather solid copper. The added mass gives you a slower responding pot which holds temperature. If you want a much more responsive pot, which won't hold temperatures too well, have a look at Jason's old MousePots.
__________________
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
chilly1 Prometeia Mach 2 GT
PURE
Originally Posted by saaya to Hipro5 View Post
if there will ever be an event where they seriously keep you from smoking i bet your gonna show up with nicotine plasters all over your face
Oj101 is offline   Reply With Quote
Old 10-30-2009, 12:14 PM   #7
Rasmus66
Rasmus66's Avatar
Send a message via MSN to Rasmus66
I use Autodesk Inventor
__________________
Asus P6T Deluxe V2 + MSI Eclipse SLI - Intel Core I7 950 - G.Skill Trident PC3-16000 3*2 gb - 2x Sapphire HD5770 1gb - Nexus RW 1000 watt - Samsung Spinpoint F1 750 gb
Rasmus66 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
