XtremeSystems Forums
Reply
Old 10-21-2009, 09:47 AM   #1
quattro_
I am Xtreme
quattro_'s Avatar
small question regarding AC aquatube
will this:
http://shop.aquacomputer.de/product_...oducts_id=1265
let me mount the aquatube on a pre-drilled 120mm fan hole ?
__________________
rig1
q9650@4.3 ~ EK Supreme
Asus RE ~ BP chipset block
4GB OCZ PC3-14400 Reaper@1600Mhz
HD 4870x2 ~ DD waterblock
DELL 3007HC
rig2:
i7 920@4 ~ HK3 CU
EVGA Classified 760 ~ EK chipset block
6GB Dominator GT@1866MHz, 7-8-7-20
HD 5870 ~ EK waterblock
quattro_ is offline   Reply With Quote
Old 10-21-2009, 10:04 AM   #2
quattro_
I am Xtreme
quattro_'s Avatar
found the answer, 100x100x2mm
sorry mods please delete
__________________
rig1
DELL 3007HC
rig2:
i7 920@4 ~ HK3 CU
Old 10-21-2009, 10:05 AM   #3
Shoggy
Aqua Computer Rep
Shoggy's Avatar
No, that will not work since this cover has other dimensions.
__________________
Got a question or having a problem with your Aqua Computer product?
Contact us via PM, E-Mail or use our English Sub-Forum.
Shoggy is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
