XtremeSystems Forums
Reply
Old 10-21-2009, 07:00 AM   #1
DVL73
Do I need Corrosion Inhibitor (G11) ?
Hi there
I've just finished cleaning my water cooling loop. I've rewired the new Tygon tubing too (luckily enough I had some spare). Honestly, this was the first and last time I was using the pre-mixed coolant (I was using Primochill UV Blue). Sticky/stinky residue, *much lower flow rate, temps slightly higher ... messy in one word.
Loop is now running on de-inozied water only + silvercoil in the reservoir. I've purchased some G11 Coolant ... but now I'm in dillema do I need this at all. Loop is based on Thermochill PA120.2 + EK5850 + DTEK Fuzion + Tygon R3603 (with mixture of EK/DD barbs and they are all nickel-plated brass I believe) + DDC/Plexi top. I would say it's all cooper with those nice blocks.
So, any hints what to do with G11 ?
DVL73 is offline   Reply With Quote
Old 10-21-2009, 07:50 AM   #2
eponymous
eponymous's Avatar
Originally Posted by DVL73 View Post
Hi there
If you aren't running mixed metals then you won't need it.
Generally this is needed if you are using Aluminium in your loops.
Check out the Galvanic Series on wiki.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 10-21-2009, 08:21 AM   #3
millertime359
Xtreme Guru
millertime359's Avatar
I don't see a need for it with what you listed.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
