XtremeSystems Forums
Reply
Old 10-21-2009, 04:53 AM   #1
nebj00la
Question Changed water, no more GTX295 :(
So, In an effort to keep my system efficient I changed the distilled water in my loop last night. Unfortunately, as I was reconnecting the tubing I swapped the inlet/outlet on the res, and that caused a big swoooosh of water to come flying out the res.
From what I saw, most of it got on me and the carpet. I thought nothing of it at first. Now, when I boot into Windows, no matter what I try, the two GTX295's show up with exclamation points explaining "Windows disabled these devices because they reported a problem."
Since I can't find my original heatsink, RMA seems out of the question. My waterblock is now just a paperweight! Am I basically out of luck?
__________________
nebj00la is offline   Reply With Quote
Old 10-21-2009, 05:05 AM   #2
slamz
slamz's Avatar
dry them in an airing cupboard for a week or so and try them then? they may not be totally dead just yet
__________________
Originally Posted by nikhsub1 View Post
Unfortunately some think that having uber high flow rates will increase the size of their penis.
slamz is offline   Reply With Quote
Old 10-21-2009, 05:08 AM   #3
eponymous
eponymous's Avatar
Yup and maybe try a hairdryer or heatgun on a very low heat to help dry them out.
I'd definitely give them a week or maybe two weeks to dry out and they will probably work. Electronics can take a fair bit of punishment.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is online now   Reply With Quote
Old 10-21-2009, 05:18 AM   #4
nebj00la
I took the block/cards apart and cleaned the h/s compound with alcohol, and got rid of any other gunk I found. Right now they are sitting on a pile of books. Do you think a cupboard where snacks are stored would be a better location? I've heard rice can help, what are your thoughts on this?
Thanks!
__________________
Old 10-21-2009, 05:57 AM   #5
Presretach
Check SLI cable if you're nice blending. It was to me the problem above is a red light on the card.
__________________
I speaking Tarzan English excellent.
Presretach is offline   Reply With Quote
Old 10-21-2009, 06:02 AM   #6
Kal-EL
Fostering the Fever
Kal-EL's Avatar
Send a message via MSN to Kal-EL
If you have a clothes dryer that has a shoe rack adapter (keeps shoes from tumbling in the dryer), put your cards in the dryer and set to low heat, it'll gently warm you're cards and the dry air will suck whatever moisture is on the cards.
__________________
Kal-EL is offline   Reply With Quote
Old 10-21-2009, 06:03 AM   #7
nebj00la
I checked the cables, they were seated properly. Hopefully the overhaul and drying process solves the problem
__________________
Old 10-21-2009, 06:17 AM   #8
Delemon
I've used rice to absorb excess moisture from my cell phone that took a dive into a glass of water once. It certainly won't hurt the cards any. My cell phone survived it anyway, lol.
__________________
In Progress:
EVGA X58 Classified w/EK-FB full board block | Core i7 920 w/ Enzotech Sapphire | 6GB Gskill Trident F3-16000CL9T-6GBTD | ATI Radeon 4870 1GB | Hitachi 320GB HD x2 | Hitachi 1TB HD x2 | PCP&C Silencer 750W PSU | D5 Vario w/EK-D5 v2 | MCR320-QP w/cheap Yates (for now)
Delemon is offline   Reply With Quote
Old 10-21-2009, 06:30 AM   #9
Tackleberry
Tackleberry's Avatar
even better if you use Silica gel packets.
Tackleberry is offline   Reply With Quote
Old 10-21-2009, 06:41 AM   #10
Asylum1
Asylum1's Avatar
If you just use a hair drier on low heat for a few minutes and let it set in front of a fan all day.
It should be good to go by tomarrow.
__________________
Killer
Core i7 920 @ 4.2Ghz
EVGA X58 758 SLI
2xGTX295's in SLI
3x2Gig Kingston Hyper X 2100mhz
Corsair HX1000 Watt Modular
Water Cooling
3DMark Vantage 41312
Asylum1 is offline   Reply With Quote
Old 10-21-2009, 06:43 AM   #11
voigts
I am Xtreme
voigts's Avatar
what on earth are you people telling this guy to do? Put his video cards in the dryer? Let them sit for 2 weeks? Rice- you have got to be kidding!
What you need to do is give them a good bath in 93% isopropyl alcohol. Literally pour the isopropyl alcohol all over them- it won't hurt them a bit. Obviously you want to remove your heatsinks before you do this. As the alcohol evaporates, it takes any water with it. Then you can just gently blow dry them on low heat (don't get them hot, just a bit warm) and let them sit overnight in front of a fan. If there is any water/gunk on them, this will take care of it.
Then plug them up and keep your fingers crossed. Many a hardware item has survived getting wet.
__________________
Latest Project Log: 1935 Zenith Radio Scratch Build
voigts is offline   Reply With Quote
Old 10-21-2009, 06:45 AM   #12
Diverge
Diverge's Avatar
I wouldn't put my cards in a dryer no matter if they tumbled or not. Static electricity would be a big concern... as there is always gonna be some lint in there.
__________________
[DFI JR X58-T3H6] [i7 920 D0 3849A866] [12GB OCZ OCZ3B2000C9LV6GK] [HIS HD 5970] [SeaSonic X750 Gold ] [Windows 7 (64bit)] [OCZ Vertex 30GB x3 Raid0]
[Swiftech MCW30, Duniek DFI X58 Mosfet Block, D5 w/ Typhoon III] [Swiftech Apogee GTZ] [TFC 360 rad]
Diverge is offline   Reply With Quote
Old 10-21-2009, 06:47 AM   #13
Sadasius
Tygon Warrior
Sadasius's Avatar
Yeah did that to my 3870X2 card. Tried it after a week and it still did not work. Tried it after a month and it worked. Just needs to be thoroughly dried out!
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 10-21-2009, 07:16 AM   #14
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Best advice by far.
Just do that, i'm sure you'll be fine.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 10-21-2009, 08:00 AM   #15
MaByBoI
Xtreme Cable Management Freak
MaByBoI's Avatar
i wouldnt put my card anywhere near a dryer, way too much static possibilty... just do what voigts said, and if worse comes to worse you can buy a replacement stock heatsink...
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air
MaByBoI is offline   Reply With Quote
Old 10-21-2009, 08:51 AM   #16
jim0ne
This.
jim0ne is offline   Reply With Quote
Old 10-25-2009, 07:54 AM   #17
nebj00la
Thanks for the idea! I ordered a 5870 with a water block, hopefully this works and will help pay for it!
__________________
Old 10-25-2009, 08:45 AM   #18
kamieldehond
or buy a 2nd hand gpu cooler and try to get rma?
__________________
e8500 c0 - 4275MHz - 1,344 vCore
DFI UT P45-T2RS
4x1gb D9GMH
Ati HD4870
Modded HAF 932
Watercooled:
Heatkiller v3.0 cu - D-tek Fuzion GFX 2 - PA120.1 - PA120.2 - PA120.4
kamieldehond is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
