10-21-2009, 12:35 AM
#1
New Vacuum Pump - need your advice
Hi guys ,
I have an opportunity to buy this Vacuum Pump.
It is a Two Stage , 1.5CFM (50Hz) , 25 Microns , 1/4HP .
Is this a good pump for Vacuuming my Phase ???
Here is the Picture:
Here's the Link:
http://www.worldvalue.cn/Products_item_big.asp?id=24
IS this pump will be good enough for Vacuuming a Phase change ???
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
GigaByte X58 Xtreme,
10-21-2009, 02:26 AM
#2
Hi, I can't give much advice on that pump have never used them, but if it's for light phase work I'm sure it will do the trick, better than a compressor!
I would suspect it's more than capable of sucking the life out of a small phase system.
__________________
Go placidly amid the noise and the haste, and remember what peace there may be in silence.
Avoid loud and aggressive persons, they are vexatious to the spirit.
With all its sham, drudgery, and broken dreams, it is still a beautiful world.
Be cheerful. Strive to be happy.
10-21-2009, 05:17 AM
#3
OCTeamDenmark Staff
I cant say how strong a vacume you need to pull.
I found these threads for you..
http://www.under-the-ice.com/forums/...7&t=138&hilit=
http://www.xtremesystems.org/forums/...d.php?t=104454
maybe that will give you the information you need.
because I dont know if that pump is cabable of pulling 25 microns as in max.
Or if that is how strong it is and then over time builds up more.
Hope it helps.
__________________
OCTeamDenmark.com Staff
Cooled and sponsored by Coolerkit.dk
Gigabyte EP45 Extreme | QX9770
2x1 Gb G.skill DDR3 PC3-16000
2xFoxconn 3870, Vcore,Vmem,OCP,Cap mods.
22" Samsung 225BW | Antec 1000 Watt
Mach 2 GT (moddet by t!m) | MX510 - Func F10s
10-21-2009, 05:51 AM
#4
-100c Club
This one will do it's job very well!
10-21-2009, 08:06 AM
#6
I can get ONLY the Same Vacuum Pump but with 3CFM (85 l/min , 1/3 HP , 25 Microns )
Here is the Link:
http://www.worldvalue.cn/Products_item_big.asp?id=25
(the Difference Between the 1.5CFM to the 3CFM is about $100 .
1. What will the 3CFM Model give me Besides Less Vacuum time ??
2. Do i need a Better Vacuum Pump for a Cascade ??
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
10-21-2009, 09:16 AM
#7
-100c club
Here is the Link:
It just saves some time but you are ok with 1.5cfm
10-21-2009, 11:35 AM
#8
Needs more time
That vac pump is fine. In fact a normal fridge compressor works. A couple of hundred micron works. There is a good deal of sentiment here that you need a crazy low vaccum for many hours and triple purge vacuum cycles to make things work. It's just not needed.
10-21-2009, 12:19 PM
#9
BUT is this 1.5CFM (25Microns/ 1/4HP) Vacuum Pump is enough for Cascade ??
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
10-21-2009, 12:20 PM
#10
-100c club
BUT is this Vacuum Pumpis enough for Cascade ??
Yes
10-21-2009, 02:11 PM
#11
oh ya it will work for all y want it to as i have a 1.5cfm that i bought when i first started building and it is still running good but i did buy a better one after i started to build system for customers
10-21-2009, 07:55 PM
#12
The purpose of a deep and long vacuum is to make them last, not only to work. The deep vacuum is to remove as much moisture as possible. Moisture in the oil leads to acid, acid leads to winding failures.
The purpose of the triple nitrogen sweep is three fold
1: reduce moisture
2: speed vacuum times
3: let the water that has frozen thaw so it can be vacuumed out
To understand number 3 you need to place a cup of water ina bell jar and pull a vacuum on it. You will see that as it boils off ice crystals form around the cup. Once the pressure is brought back up in the jar they will thaw more easily.
__________________
Quoted from SoddemFX:
"I frankly have no idea what you are trying to do. I have received more comprehensible correspondence from Mr Obuwonga Mwahahu, who i believe wishes to give me a 10% share of his $12M fortune held in the royal bank of Nigeria."
10-21-2009, 09:23 PM
#13
Diablo 3! Who's Excited?
Let's use our heads real quick. How much internal volume do our systems typically have? Maybe a cubic foot for a casacde? Compare that to a typical home HVAC system which must have at least a cubic foot of condenser if not more. Those 3 cuft/min vacuum pumps are great if you are vacuuming down something HUGE. I have a 1.5cuft single stage vacuum pump and I've never had moisture problems outside of tainted POE oil. Just change out the vacuum pump oil frequently and it'll keep on purring away.
1: reduce moisture
QFT.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
10-22-2009, 01:20 AM
#14
Needs more time
1: reduce moisture
Not to be trite but our systems are never employed long enough to worry about acid eating windings.
A filter/dryer will take out the tiny amount of moisture in a DIY system.
Most people just stick a hair dryer on the compressor to heat it up during vacuuming and shake it around a bit.
I started out using two freezer compressors in series. Never used nitrogen and only ever vacuum once.
My rigs worked fine.
10-24-2009, 08:33 AM
#15
I am sure they do your are a good builder, I was just letting you know what he crazy, long deep vacuums are for Technically.
Dont know what it means.
__________________
10-24-2009, 01:51 PM
#16
I am Xtreme
Vacuum pumps CFM ar rated @ free air,, ,,,,,,,,so a system that has 1.5 cfm volume ,a 1.5 cfm pump will get most (98%)of the non-condensables out in the first minuite. If the sytem has 3 CFM it takes 2 minuite to remove 98%. Once the vacuum gets deeper the CFM rating plummets. When you start to get below 2000 microns things slow down. This is where breaking the vacuum with dry nitrogen helps, so does removing valve cores, and large diameter short hose work best. At very low absolute pressures restriction are very critical on how fast non-condesables are removed. Mainly air which is mostly nitrogen 78%,20.9 oxygen,and little CO2.
One thing if you understand the correct procedures ,have the proper tools, and you want to get into this field to earn a living,you sould do very well.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ????????  I forgot "you must"
10-24-2009, 02:17 PM
#17
Finally i bought the 3CFM / 25Microns , 1/3HP 85L/min .
I paid an extra of $25 over the 1.5CFM and i took it .
Here is the Vacuum Pump i bougth(50 Hz Version):
__________________
i7 920, HD4870X2
Corsair 6GB 1800MHZ
10-24-2009, 03:35 PM
#18
I am Xtreme
A 2 stage pump is good.  ........I can't commet on that brand but a 1/3hp thats rated down to 25 microns sould work nicely.
__________________
Register today .
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
