XtremeSystems Forums
Reply
Old 10-20-2009, 09:18 PM   #1
Equinediver
Equinediver's Avatar
Unhappy Gunk....Feser 1, algae or worse?
Last night I thought I would check on the internals of my 2 blocks for my video cards. They have been sitting waiting patiently for Doris, so not been used in a couple of months. Before I put them away I rinsed them well with distilled water.
When I opened the 1st one I was greeted by this
The o-ring was pretty badly crudded up also, but hard to get a decent shot of it.
On the 2nd card the block wasn't so bad, more on the top though and quite a bit on the left side
Tonight I stripped down my HK and this is what I found
The little plate was pretty yucky also
The HK and plate were easy to clean as they had stayed damp, just not too sure how to go about the video blocks, wondering if to pour some DW on them and hope it will soften the crud.
Hoping this is just the result of having used Feser 1 and not something more serious. The video cards were on a totally separate loop from the HK. I broke down my mosfet block and that seemed fine.
These loops had been running for about 6 months, the openly visible side - tubes and res's were both completely clear, also just checked the pumps and they look good.
Changing to DW + coil for Doris
__________________
i7 975 EVGA X58 Classified 6Gb Corsair Dominator GT 2 x EVGA 285 FTW 2x 300Gb Velociraptor in RAID 0 WD Black 500Gb
WC loop 1: HK 3.0 Fesser 360 BP VREG BP NB D5 pump
loop 2: 2 x EVGA HC's Fesser 240 D5 pump
Equinediver is offline   Reply With Quote
Old 10-20-2009, 09:29 PM   #2
rmorse27
rmorse27's Avatar
hot water and vineger is what i use to clean my blocks and loops.
__________________
Antec 1200 Case
E8500
Asus Rampage Formula
8 Gigs Mushkin 1066 Ram
2 x 640 Black WD Drives Raid 0
2 x Lightscribe Dvd Burners
2 x Ati 5870 xfire
EK 5870 Water Blocks
Corsair HX 1000 Watt Pws
Heatkiller 3.0 775 Water Block
Bitspower Nb/Sb Block
2 Xspc Dual Bay Pump/Res Combo
Xfi Sound Card
Black Ice 240mm Radiator
Antec 200mm Radiator
180mm Fan
rmorse27 is offline   Reply With Quote
Old 10-21-2009, 03:38 AM   #3
eternal_fantasy
eternal_fantasy's Avatar
The stuff inside your Heatkiller is just dust and debrie that somehow got into your waterloop, and the HK acted as a filter, trapping them on the nozzle plate. It has nothing to do with your coolant. I got the same thing after a few months with distilled and silver coil.. it is just the necessary evil that comes with a modern fine min matrix/micro channel design waterblocks. I now have a steel mesh filter inside the loop which I can check on and clean easily, so my Heatkiller does not serve that purpose.
__________________
EVGA Classified E760 - EK Full Board Block
Intel Core i7 965 - HeatKiller Water Block
ATi HD 4870X2 - EK Full Cover
Corsair Dominator TR3X6G1600C8D
3 x Intel 80GB SSD 34nm Gen. 2 on -
Areca 1231DML SATAII RAID Controller 2GB Cache
Drobo controlled: 2x1GB Western Digital RE3
Antec Signature 850W
HeatKiller CPU Block - EK 4870X2 Full Cover Block - EK Classified Full Board Block - ThermalChill PA120.3 - 3 x Noctua NF-P12 - Laing DDC Ultra 18W - Aquaero Controlled
Current Functional Motherboards selection:
ASUS P5B Deluxe - ASUS P5K Premium - ASUS Maximus Formula - ASUS Maximus Extreme
ASUS Striker II Extreme - EVGA nForce 790i Ultra - FOXCONN BlackOps - ASUS Rampage Extreme
ASUS P6T Deluxe - EVGA Classified E760
eternal_fantasy is offline   Reply With Quote
Old 10-21-2009, 04:35 AM   #4
Coldon
Coldon's Avatar
Send a message via MSN to Coldon
ugh, when will people learn to stop using feser crap!
seriously colored tubing + distilled water!
__________________
Inside: i5 750, ASUS P7P55D Deluxe, 8GB G.Skill Ripjaws DDR3 2000, EVGA GTX260 C216, 3x1TB Seagate 7200.12 HDDs
Case & Cooling: CM ATCS 840, Corsair HX620 PSU, Swiftech Apogee GTZ, MCW60-R2, Swiftech MCR320 Rad + XSPC RS240 rad, DDC 3.2 with XSPC Bay Res One.
Coldon is offline   Reply With Quote
Old 10-21-2009, 04:55 AM   #5
NaMcO
NaMcO's Avatar
Never. Been using it for years literally and not a single problem like this. Feser all the way. Something else must have caused it, i seriously doubt feser will cause that.
__________________
Rampage 2 Extreme · GTX295 SLI 1792MB FTW · Core i7 920 4.2GHz · Corsair HX 850W · SupremeFX X-Fi
6GB GSKill Trident PC3-16000 · Intel SSD 80GB RAID0 & Samsung F3 1TB RAID0 · Silverstone TJ07 · Samsung 24"
NaMcO is offline   Reply With Quote
Old 10-21-2009, 06:58 AM   #6
Equinediver
I've just cropped and enlarged the plate, which hopefully shows more clearly what looks like either algae or Feser gunk.
Yes, definately no more colored fluids for me!
The only places it has built up is in the CPU and VC blocks, all the fittings, tubes, pumps etc are totally clear. The one thing I had noticed was the bottom card had started running quite a bit hotter, so I guess that was probably the one worst affected.
__________________
Old 10-22-2009, 02:11 AM   #7
ChielScape
doesnt look like typical coolant gunk. which usually looks more slimy.
that said, premade coolants are basically overpriced water with a color. just get some distilled from your local supermarket, some food coloring and a piece of silver. alternatively, you can use some copper sulphate instead of the silver.
ChielScape is offline   Reply With Quote
Old 10-22-2009, 05:16 AM   #8
Anemic
Anemic's Avatar
I had faser gung, very slimy just like you say ChielScape. Colord tubing for me next time!
__________________
Loonym...You are missed.
The element of one
Breathe me in
Breathe me in
I disbelieve in separation. I close my eyes to see you.
This is for you, everything I am. This is for you, take it from me.
I, I disbelieve separation. I close my eyes
there's no escaping me
In your heart in your soul. I perceive rejuvenation
Breathe me in. I am forever. Deep within I am eternal.
I will return to you. I am with you always. I will never turn away from you.
Anemic is offline   Reply With Quote
Old 10-22-2009, 04:09 PM   #9
Aedubber
Aedubber's Avatar
Send a message via AIM to Aedubber Send a message via MSN to Aedubber
Whats the difference between copper sulphate or silver? Sorry for the newb ? lol
Aedubber is offline   Reply With Quote
Old 10-22-2009, 05:34 PM   #10
ChielScape
silver, you use it as a solid. a ring, coin, etc. (just make sure it doesnt clog anything)
copper sulphate you add as a powder (sometimes white, but generally blue) or as a solution, like PT Nuke. you need just a tiny bit. in powder form, a teaspoon of it is enough for 50L of coolant, at least.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
