XtremeSystems Forums
Reply
Old 10-20-2009, 12:45 PM   #1
Circaflex
Circaflex's Avatar
Send a message via AIM to Circaflex
Cleaning Guide?
Hey guys I looked around a little, not very much but are there some good cleaning guides for h2o parts?
I just tore apart my loop and i need to clean:
My thermochill radiators
swiftech microres
2 aquaxtreme pumps
is there a guide for certain components and how to clean them?
__________________
Pentium 4 3.2E (SL7PN E0) @ 4246.46 MHz (265.4 * 16) 1.48cvore
Intel Corei7 920 @ Stock (Still testing) - EVGA e760 x58 Classified - 6GB (3 x 2gb) GSkill Tridents @ Stock - BFG Nvidia GTX 295 - Creative X-Fi Elite - 4 x 74GB Raptors (RAID0) - 2 x 400GB WD - Antec TPQ-1200
Phase unit by runmc @ full load -33
H2O Loop - MCRes>AQ50Z>GTX295>PA 120.3>AQ50Z>PA 140.1
Circaflex is offline   Reply With Quote
Old 10-20-2009, 12:48 PM   #2
Neuromancer
Neuromancer's Avatar
Soak them in vinegar? A guide would be great, cleaning used parts is something over looked by a lot of new comers to Watercooling (me for instance )
Neuromancer is offline   Reply With Quote
Old 10-20-2009, 12:54 PM   #3
NaeKuh
Broken Gainestown
NaeKuh's Avatar
depends on what coolant u used and how bad the stains are.
If you used straight distilled and silver, all you really need is just a flush.
If you have funky smell, and you got mystery stuff growing.. time to go see a doctor.. err wrong thread..
But if u used a glycol based coolant, and u got gelly stuff, you would need to use hot water, seeing how that helps.
Vinegar washes are used if you have staining... however i dont like touching vinegar cuz it smells bad.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is online now   Reply With Quote
Old 10-20-2009, 12:58 PM   #4
eponymous
eponymous's Avatar
I hear that!
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 10-20-2009, 12:59 PM   #5
Circaflex
Circaflex's Avatar
Well im replacing all tubing, it was running straight distilled and some pt nuke. From the looks of everything i just see a little white film around the barbs on my rads and in my pumps. Should i just grab some distilled and setup a temp loop to flush it all out? Or just put warm water through the barbs and just keep doing that until its clean?
__________________
Old 10-20-2009, 01:02 PM   #6
NaeKuh
Broken Gainestown
NaeKuh's Avatar
the white flakes is most likely plasticizer or flux.
Just run everything under hot water for about 5 min.
Hook it up to your kitchen sink, tie a tube in the outlet and let the hot water run.
That should take care of everything.
After your done, make sure u rinse with distilled.
If your So Cali like me, you know our public water sucks dookie.
__________________
Old 10-20-2009, 01:11 PM   #7
Wolf132
Wolf132's Avatar
The only way I got all the crap outta a thermochill radiator was to flush with boiling hot water a few times, then a vinegar soak for about 20-30min, then flush again with boiling hot water again a few times, then finally rinse with distilled a few times to clean out all the tap water. Or you can hook up a simple loop with pump and radiators in your sink, and leave it running for a day or 2, and hope most of the flux comes off that way. My loops have been crystal clear for 9 months with just distilled and a silver barb.
__________________
Asus P5Q-Delux, Q6600 @ 3.7
2x 120.2PA Thermochill
MM H2GO
EVGA GTX 260
OCZ vertex 60g w/Win 7 Pro
Corsair 850HX
NEC 20wmgx2
Wolf132 is offline   Reply With Quote
Old 10-20-2009, 01:22 PM   #8
Thewli
I have a co-question!
I use only distilled water in my loop, and I have cleaned all part with vinegar throughly, but the tubing keeps getting all smoky-looking, and I got some green dirt in the corners of the fittings, probably algae. The algae I hadn't noticed before I opened the chassi yesterday, but the smoky-looking tubes got there after only a few weeks I think. I haven't changed tubing for a year or so, so I'll take some time for it in a couple of days, but it would be nice to know what's making the tubing grey and smoky. I want my all nice-looking clear tubing back =(
What have I missed about this, will glycol in the loop fix the algae thing?
__________________
ASUS P5Q E
C2D E6600 currently on 3.25GHz
4GB G.Skill DDR2 PC2-8500
AXle 3D 8800GTS 640 @ stock
X-Fi Xtrememusic
Seasonic 650W
Samsung T166 320GB + SpinPoint F1 750GB + Maxtor MaXLine III 250GB
CoolerMaster Stacker T-01
Thewli is offline   Reply With Quote
Old 10-20-2009, 01:28 PM   #9
Wolf132
Wolf132's Avatar
What kind of tubing?
__________________
MM H2GO
EVGA GTX 260
Corsair 850HX
NEC 20wmgx2
Old 10-20-2009, 01:32 PM   #10
Thewli
Tygon R-3603
__________________
ASUS P5Q E
X-Fi Xtrememusic
Seasonic 650W
Old 10-20-2009, 01:35 PM   #11
NaeKuh
Broken Gainestown
NaeKuh's Avatar
get primochill
Your tygon is undergoing clouding.
Basically the plasticizer.
__________________
Old 10-20-2009, 01:58 PM   #12
Thewli
And the primochill won't? Sounds nice in that case.
You can't stop that procedure with some additive in the water?
__________________
ASUS P5Q E
X-Fi Xtrememusic
Seasonic 650W
Old 10-20-2009, 02:57 PM   #13
NaeKuh
Broken Gainestown
NaeKuh's Avatar
it has better resistance.
been using Primo tubing for a while now, and still no clouding. Well even if it did cloud, you wouldnt be able to see it.
The clear one u see is feser.
Another great tubing with clouding resistance.
__________________
Old 10-20-2009, 03:29 PM   #14
Thewli
Nice looking, maybe I also should go with some coloured tubing, then maybe the clouding won't be such a problem anymore
It sure seems like it's a dream bending the primochill also! heard about 2" turns, THAT would be nice!
Just gonna find a store who ships to Sweden. Think frozencpu will, but I would've preferred a shop in Europe!
Thanks for your input!
__________________
ASUS P5Q E
X-Fi Xtrememusic
Seasonic 650W
Old 10-20-2009, 03:53 PM   #15
NaeKuh
Broken Gainestown
NaeKuh's Avatar
as great of a bending arc it has, sometimes it still wont be enough.
Otherwise i wouldnt be using a 44 dollar L.
__________________
Old 10-20-2009, 09:44 PM   #16
skinnee
Addicted to Pie!
skinnee's Avatar
how can you post that dust bunny breeding ground pic in a cleaning thread, that doesn't set of your irony radar at all?
__________________
skinnee labs test schedule:
In Testing: Too much to list.
Writing Reviews: finally getting my backlog cleaned up too.
Planned Tests: Plan, what the heck is a plan.
skinnee is offline   Reply With Quote
Old 10-20-2009, 10:51 PM   #17
Newblar
Newblar's Avatar
Send a message via MSN to Newblar
hey he lives in southern california
the dust is absolutely insane... i dont even think its possible to keep dust out of a case here
id actually be sick if i went to an area with cleaner air
__________________
Seti@Home Optimized Apps
Heat
240x2 3.7ghz, 2750nb
1.475v, 1.425 cpu-nb
1100 ocz lv plat 1.9v
790gx ds4h, 1.3v nb
Originally Posted by aNoN_ View Post
pretty low score, why not higher? kingpin gets 40k in 3dmark05 and 33k in 06 and 32k in vantage performance...
Newblar is offline   Reply With Quote
Old 10-20-2009, 11:47 PM   #18
NaeKuh
Broken Gainestown
NaeKuh's Avatar
ahhh someone who knows my pain... LOL...
Mid town whilshire area here. :P
__________________
Old 10-21-2009, 06:53 AM   #19
voigts
I am Xtreme
voigts's Avatar
Skinnee does have a good point! I wouldn't let my setup look like that much less take a big pic of it and plaster it up here for all to see...
As for the rads, you can just fill them with hot soapy water (dishsoap) a few times and shake them good, drain, rinse with tap, and rinse with distilled. That should be plenty good enough. For the blocks, just take them apart and use a toothbrush and more soapy water. For the res, you use a small piece of soapy cloth (small enough that it will come back out of a barb hole with a pair of tweezers) and some water and shake it around good.
BTW, you can keep southern California. Nice place to visit, but I'll take the hills of Tennessee any day.
__________________
Latest Project Log: 1935 Zenith Radio Scratch Build
voigts is offline   Reply With Quote
Old 10-21-2009, 09:30 AM   #20
Waterlogged
I am Xtreme
Waterlogged's Avatar
Here's your Official NaeKuh soapbox smashing hammer.
__________________
Waterlogged is offline   Reply With Quote
Old 11-21-2009, 11:24 AM   #21
Bladesinger7x
Bladesinger7x's Avatar
Hi fellow watercoolers, I need some help. Few months ago I purchased the Heatkiller 3.0 LC block
and have not used it yet. Last week I took the block out of storage and found out it is all stained.
I have tried cleaning it with coke (about 30 minutes), vinegar (1 hour) and even lemon juice (about 30 minutes)
...but the stains remain (much to my delight).
New block (had only one stain on the side):
Block base few days ago (after the cleaning):
What else can I use to remove the f**kers?
__________________
Gigabyte 790XT-UD4P / X3 720 BE / 4GB OCZ Reaper HPC / Sapphire HD 4770 / Samsung F3 500GB & F1 640GB / Corsair HX750 / CPU / GPU H2O / Sharkoon Seraphim rev.ATX
Bladesinger7x is offline   Reply With Quote
Old 11-21-2009, 11:32 AM   #22
Stewie007
Stewie007's Avatar
Scotchbrite, and a slight abrasive like comet. What you have is some tarnishing. This happens when copper is exposed to atmosphere. Next time if you're going to let copper blocks sit, cover the inlet and outlets.
__________________
Proud of my Pontiac G8.
...Yes, I know that its a Holden...
If you hate it, you haven't driven it.
Stewie007 is online now   Reply With Quote
Old 11-21-2009, 11:58 AM   #23
Bladesinger7x
The block was in the bubble wrap and boxed the whole time.
Will the tarnishing affect the performance of the block?
Would cilit bang remove the tarnishing?
__________________
Old 11-21-2009, 12:05 PM   #24
eponymous
eponymous's Avatar
Try using acetone or Isopropanol.
__________________
Hardware
Old 11-21-2009, 11:54 PM   #25
Bladesinger7x
Thanks I will try this.
One question: will tarnishing decrease the performance of the block
...I don't want to go extreme cleaning on the block
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
