10-20-2009, 11:06 AM
#1
Push and pull fan speed?
Does the push fan and the pull fan need to be the same speed? I am trying to use the typhon on the bottom and some led ones on the top to have the light but they are not gonna be same rpm would that be fine?
10-20-2009, 11:08 AM
#2
dont understand the question...what r u doing with the fans?
__________________
 i7 920 4.2ghz..6gb 1600mhz cas 7 memory..Windows 7 Ultimate Edition..Windows XP..650 watt PS..Water..3DFX Voodoo 3
10-20-2009, 11:13 AM
#3
As long as the fans are about the same you will be fine.
I would not try 3000 rpm Delta on one sida and 500 rpm on the other side.
Think there is some old thread with some actual tests. Try the search function
__________________
"I don't have a masters degree, but even I know that mixing water and electronics is a stupid thing to do."
My girlfriend.
"It's easy to get sideways at first thinking there is ONE BEST product for each area of water cooling. But, that's not always the case - depends on your exact setup and needs."
shazza
10-20-2009, 11:15 AM
#4
I mean for those fans on the rad. One set of them on the bottom of the rad and one set of them on the top of the rad. Do those fans on the top an bottom need to be same speed?
10-20-2009, 11:17 AM
#5
what!! yea it should be fine
__________________
10-20-2009, 11:49 AM
#6
They need to be relatively close to the same fan speed, otherwise you can damage the slower one (the airflow will force it to spin faster, which will damage the motor). But if they are within a 100 or so RPM it should be fine.
__________________
The parts:
| MSI 790FX-GD70 | Phenom II 965 140W | Sapphire HD 5870 | 2x2 GB G.Skill Ripjaw DDR3 1600 7-7-7-21 | 3 x 250 GB SATA HDDs | 1 x 1 TB WD MyBook External | Corsair Obsidian 800D |
The cooling:
| PrimoChill Typhoon III Bay Reservoir/Pump | MCR320 | 3x120mm 1450 RPM Scythe GentleTyphoon | HeatKiller REV3.0 LT | EK HD 5870 FC Nickle | ThermoChill PA120.2 | 2x120mm 1900 RPM Scythe S-Flex |
10-20-2009, 12:05 PM
#7
what if I put the slower one before the fast one? Will that solve the issue?
10-20-2009, 06:25 PM
#8
Maybe someone over here can help you or you can find a good answer there.
http://www.silentpcreview.com/
__________________
Motherboard: ASUS Rampage Extreme//Processor:E8600 //Cooling:Corsair CWCH50-1//Memory:Patriot DDR3 PVS34G1600LLK 8GB//Video Card: Sapphire VAPOR-X HD 4890 OC Edition //HDD/Intel X25-M G2 80 GB & WD 74 GB VelociRaptor//Sound Card & Nic Card: PCI-e X-Fi Titanium Fatal1ty/EVGA Killer Xeno Pro //Case:SilverStone Raven RV02//Power Supply: Corsair HX 850 //Monitor:Samsung P2770H 27"
10-20-2009, 06:38 PM
#9
The whole idea behind push pull is to minimize the air flow resistance.
So if one side is slower then the other side, the slow side would actually create resistance. I could be wrong, just my 2c
__________________
i7 920(3.811G, ), Intel DX58SO, Nvidia 260, Crucial Triple Kit 1600, Areca ARC-1231ML,
MCP655-B, Heatkiller 3.0, SilverCoil, distill, EK RES 250,
Norprene 1/2ID, 8x Silenx iXtrema Pro 120mm.
AS5, Case intake: 21; Case output: 23.
No load: Coolant: 25, Core: 35
Case intake: 22, Case output: 24.
Prime 95: Coolant 28, Core: 57
10-20-2009, 08:54 PM
#10
Xtreme Guru
No matter what, the fans need to be matched. The faster one will overpower the slower one.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-20-2009, 11:53 PM
#11
Meh, now i got curious and had to go dig up the old thread I was thinking about.
http://www.xtremesystems.org/forums/...d.php?t=189402 Vapor did some actual tests in the end.
http://www.xtremesystems.org/forums/...&highlight=fan and a little more.
My interpretation of the mechanics involved is that as you can compress air, water is for all practical purposes incompressible, you get kind of an air dampener in between the fans so you don't need to match the power of the fans as closely as with pumps. Add to that a much flatter pump (flow/pressure) curve and you got a much more tolerant system. You need some serious unbalance in power to damage or lose all the effect from the weaker fan.
Yea I know just rambling. If anyone actually have an idea on how it works feel free to inform me
__________________
My girlfriend.
shazza
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
