XtremeSystems Forums
Reply
Old 10-20-2009, 10:47 AM   #1
Camaroz06
How much tubing do you guys buy? (including extra)
Hi All,
Just wondering how much tubing you guys buy on average for a project? I was thinking 10 feet should be enough with extra to spare. I am doing Res-> pump -> MCR220 -> MCR220 -> CPU -> MB -> GTX360 -> Res. Imaginary measurements @ the longest routes I think took it to 6 ft or so, is 4 ft too much extra?
All in all I am pretty much interested in how much extra tubing you guys usually buy for your projects.
Thanks,
Eddie
Camaroz06 is offline   Reply With Quote
Old 10-20-2009, 10:57 AM   #2
Baulten
I bought 10 for my CPU only loop, still got 5 left over for when I add my video card.
__________________
The parts:
| MSI 790FX-GD70 | Phenom II 965 140W | Sapphire HD 5870 | 2x2 GB G.Skill Ripjaw DDR3 1600 7-7-7-21 | 3 x 250 GB SATA HDDs | 1 x 1 TB WD MyBook External | Corsair Obsidian 800D |
The cooling:
| PrimoChill Typhoon III Bay Reservoir/Pump | MCR320 | 3x120mm 1450 RPM Scythe GentleTyphoon | HeatKiller REV3.0 LT | EK HD 5870 FC Nickle | ThermoChill PA120.2 | 2x120mm 1900 RPM Scythe S-Flex |
Baulten is offline   Reply With Quote
Old 10-20-2009, 11:05 AM   #3
Locke
Locke's Avatar
I would say 8 to 12 feet. I tend to cut and recut though to get the best lengths from component to component.
__________________
i5 750 @ 4200 on Apogee GTX
Gigabyte p55a-ud4p
2 x 2gb GSkill Trident pc1600
HD5850 on mcw60
PA120.3
Custom Built Case
My Blog:
http://www.destructoid.com/blogs/Locke
Locke is offline   Reply With Quote
Old 10-20-2009, 11:06 AM   #4
VOID WARRANTY
VOID WARRANTY's Avatar
i buy my tubing from home depot its 10 foot of 1/2-id 3/4-od for like $2.50 ..some snobs would rather me pay $20 online for it
__________________
i7 920 4.2ghz..6gb 1600mhz cas 7 memory..Windows 7 Ultimate Edition..Windows XP..650 watt PS..Water..3DFX Voodoo 3
VOID WARRANTY is offline   Reply With Quote
Old 10-20-2009, 11:11 AM   #5
Kanzy
I bought 15 for my dual loop set up. I think 10 is enough for u
Kanzy is online now   Reply With Quote
Old 10-20-2009, 11:23 AM   #6
overclocking101
overclocking101's Avatar
i normally buy 25 feet because i change my tubing everytime i flush my loop. plus its always good to have extra just in case
__________________
EVGA P55 FTW::::Ci7-860(1.019 VID)@4000MHZ::::HD4850 ICE-Q4::::4GB CRUCIAL DDR3 1600MHZ::::TUNIW 120XTREME::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/ <<check it out
overclocking101 is offline   Reply With Quote
Old 10-20-2009, 11:45 AM   #7
Salamndar
Salamndar's Avatar
For my first water cooling loop, I'm ordering 10.
Salamndar is offline   Reply With Quote
Old 10-20-2009, 11:56 AM   #8
cstkl1
cstkl1's Avatar
same as overclocking
normally buy 20-30feet for extra's
incase need to recut or change casing etc etc.
that being said
lol just cleaned some stuff from comp room
had like 6 boxes full of accessories and junk that i dont need anymore.
cstkl1 is offline   Reply With Quote
Old 10-20-2009, 12:19 PM   #9
eponymous
eponymous's Avatar
24 feet, 12 feet of one colour, 12 of another. This is plenty extra to allow for wrong cuts, fill lines, drains etc.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 10-20-2009, 12:32 PM   #10
Circaflex
Circaflex's Avatar
Send a message via AIM to Circaflex
10 feet.
__________________
Pentium 4 3.2E (SL7PN E0) @ 4246.46 MHz (265.4 * 16) 1.48cvore
Intel Corei7 920 @ Stock (Still testing) - EVGA e760 x58 Classified - 6GB (3 x 2gb) GSkill Tridents @ Stock - BFG Nvidia GTX 295 - Creative X-Fi Elite - 4 x 74GB Raptors (RAID0) - 2 x 400GB WD - Antec TPQ-1200
Phase unit by runmc @ full load -33
H2O Loop - MCRes>AQ50Z>GTX295>PA 120.3>AQ50Z>PA 140.1
Circaflex is offline   Reply With Quote
Old 10-20-2009, 12:40 PM   #11
Camaroz06
If only Home Depot had white tubing I would be a lot happier in the wallet!
Old 10-20-2009, 12:51 PM   #12
NaeKuh
Broken Gainestown
NaeKuh's Avatar
and home depot tubing is second to dookie.
Its stiff as faq.
Wont bend for dookie compared to the other brands.
Clouds up like crazy fast.
Id rather pay 15 cents more per feet and get masterkleer.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 10-20-2009, 01:14 PM   #13
MoMo_RT
Because I can!
MoMo_RT's Avatar
I bought 10 then I bought another 20 later because I needed more.
__________________
i7-920
EVGA X58 SLI Classified E760
6gb G.SKILL Perfect Storm PC3 16000 8-8-8-21
EVGA GTX-285 x2 SLI
X25-M G2 80gb
CORSAIR 850HX PSU
SilverStone TJ07
Windows 7
HK Rev3 LT / EK-FC285 x2 / EK-FB Classified / MCP355 + EK X-Top x2 / Magicool Elegant 360 / XSPC RX240 / EK 250 Res / Swiftech MCRES / PrimoFlex 3/8 tubing
MoMo_RT is offline   Reply With Quote
Old 10-20-2009, 01:50 PM   #14
meanmoe
12 feet. I bought less once and I ran out so I bought some garbage from lowes. home depot has the same garbage. Tubing is the cheapest part of a build, why skimp?
__________________
upgrading...
meanmoe is offline   Reply With Quote
Old 10-20-2009, 02:18 PM   #15
RoadconeTuning
i bought 30 and used about 10 on my first build in a COSMOS S w/ 2 mosfet blocks, nb block, cpu block and hoses going every which way.
__________________
SYSTEM
Q6600 @ 3.6GHz - EVGA 780i - 1GBx4 GeIL EVO ONE - HIS 5850 - 1.6TB across 4 drives
Water Cooling
Swiftech Apogee GTZ - ViperJohn 780i - BitsPower 780i MOSFET coolers - DDC-3.2 - XSPC Top - Swiftech MCR320-QP - EK Multioption 150
EK 5850 block in the mail...
RoadconeTuning is offline   Reply With Quote
Old 10-20-2009, 02:21 PM   #16
Dark Bishop
10 feet of regular home depot clear tubing, though next time ill be picking up some thinner black 1/2" ID stuff.
Dark Bishop is offline   Reply With Quote
Old 10-20-2009, 02:55 PM   #17
MpG
MpG's Avatar
And what did you pay for the rest of your system parts?
Going from stiff, poorly coloured, oval-shaped, pre-bent (prolly the wrong way) tubing to flexible, nicely coloured, anti-microbial tubing only cost me $20. I only wish I could get that kind of improvement in the other components for that cost.
My rule of thumb has always been do a worst-case scenario estimate, then double that, to decide how much to order. Of course, now that I've stockpiled a bunch of tubing, I can cut back on future orders.
__________________
i7 920 | Foxconn Bloodrage | GTX280 | Corsair DDR3-1600 2x3GB
MpG is offline   Reply With Quote
Old 10-20-2009, 03:04 PM   #18
Jokester_wild
Jokester_wild's Avatar
10-12 feet for an average loop cpu + gpu.
__________________
Lian Dream: Intel Q6600 @ 3.6ghz 455mhz, Asus Formula Maximus Evga GTX 280, Mushkin 8500 2x2GB @ 540mhz, Seagate 500g, Plextor PX-755SA, PC P&C Silencer 750 Quad, Lian-li
HTPC: E5300, Asus P5Q Pro Turbo, Gigabyte 7600GT, Crucial Ballistix 1GBx2, 2x 500gb Maxtor Raid 1, 300gb Seagate, 74gb Raptor, PC P&C 510, Silverstone LC16m
Nikon D90 ~ Nikkor 18-200mm VR ~ Nikkor 50mm F1.8 ~ Sigma 10-20mm
Lian Dream Work Log
Heatware
Jokester_wild is offline   Reply With Quote
Old 10-20-2009, 03:14 PM   #19
millertime359
Xtreme Guru
millertime359's Avatar
+1
12 ft is a good number.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-20-2009, 04:54 PM   #20
JoeBar
Xtreme Mentor
JoeBar's Avatar
I wouldn't want to know the reason...
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 10-20-2009, 05:10 PM   #21
Bravoexo
10ft per loop.
Bravoexo is offline   Reply With Quote
Old 10-20-2009, 05:20 PM   #22
safan80
Xtreme Guru
safan80's Avatar
usually I grab 12ft of tubing. When it doubt break out the measuring tape, you may have heard about this useful tool.
__________________
Watercooling parts:
Pa120.3 rad (CPU)|PA120.3 (for video card)|GTZ on CPU
|stock cooling on chipset|Laing DDC w/ Petra'sTech DDCT-01s Top on cpu loop|aqua extreme 50z pump on gpu l
cpu i7 960 @???
old cpui7 920 3836A762 @ 3.7Ghz
Gigabyte EX58-UD5 F9e bios
12GB of G.skill (6 x 2GB)DDR3 perfect storm F3-16000CL8-2GBPS 7-7-7-21
2x bfg 285
new Dell 30"LCD 3008wfp oh the colors!
LG GGW-H20L
COOLER MASTER Real Power Pro RS-C50-EMBA-D2 1250watt for the cpu/mobo & video
OCZ600MXSP 600W for the hard drives
areca 1280ML with 2GB ecc of cache running in other 16x pci-e slot with battery backup running two raid 10 arrays 2TB boot array 6TB storage
sound card: Auzentech Forte 7.1 | Gigaworks S750 7.1 speakers
OSes: debian Linux unstable, and Windows XP pro x64 w/sp2| testing windows 7 x64 ultimate
safan80 is offline   Reply With Quote
Old 10-20-2009, 06:44 PM   #23
zeropluszero
zeropluszero's Avatar
Send a message via MSN to zeropluszero
6 ft is heaps i reckon. and i'm running dual loops.
__________________
Watercooling Worklog
Q9550/Cel 347/E6500K : Rampage Formula : GTX280 : 4GB Dom 8500/2GB Gskill HZ 1000 : Enermax 1050 : HSPC Top Deck Station
Originally Posted by ryan92084 View Post
i dunno man that pussy doesn't look too thrilled
zeropluszero is online now   Reply With Quote
Old 10-20-2009, 06:51 PM   #24
Stealth42o
Stealth42o's Avatar
Stealth42o is offline   Reply With Quote
Old 10-20-2009, 10:57 PM   #25
Newblar
Newblar's Avatar
Send a message via MSN to Newblar
Originally Posted by millertime359 View Post
+1
12ft
__________________
Seti@Home Optimized Apps
Heat
240x2 3.7ghz, 2750nb
1.475v, 1.425 cpu-nb
1100 ocz lv plat 1.9v
790gx ds4h, 1.3v nb
Originally Posted by aNoN_ View Post
pretty low score, why not higher? kingpin gets 40k in 3dmark05 and 33k in 06 and 32k in vantage performance...
Newblar is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
