XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-20-2009, 08:26 AM   #1
sdumper
-100c club
sdumper's Avatar
20 plate versus 30 to 35 HX
What do I gain by going to a 30 or 35 plate HX from a 20 plate?
In reference to cascades...
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is online now   Reply With Quote
Old 10-20-2009, 08:34 AM   #2
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
More heat exchanging as there is a bigger area i would of though. Same for using a bigger condesner, bigger so more cooling!
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 10-20-2009, 08:58 AM   #3
Buckeye
Phantom is here :)
Buckeye's Avatar
Don't you reach a point tho where bigger buys you nothing more and has possible negative effects ?
What are the draw backs to simply putting in larger componets ?
So bigger condensor sounds great, but i am sure there is a balance to things, what the design is, what loads its desigened for, cooling capacity etc.
With a larger condensor you would need more refrigerant, how does that effect tunning and load handling and capacity ?
How does a 35 plate heat exchanger effect the loads, does it become sluggish in responce to loads ?
Simply saying bigger is better is not always true and can have other side effects that may or may not be wanted.
__________________
Jinu 2 Stage Cascade
http://www.youtube.com/watch?v=-zDu-Xgt400
Phantom LN2 Pot - First Encounter
http://www.youtube.com/watch?v=dLo7Dr_kR2U
How I cool my benching lab
http://www.youtube.com/watch?v=PLgwW...eature=related
Buckeye is online now   Reply With Quote
Old 10-20-2009, 09:30 AM   #4
sdumper
-100c club
sdumper's Avatar
Good points and the reason for this thread...
I have used 10 plate and 20 plate HX's successfully before. the 20 plate seems to work better but I noticed Kayl using a 30 plate so it got me wondering...
__________________
Old 10-20-2009, 10:31 AM   #5
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
No use, 10 plate is well enough for a two stage cascade & 300W CPU load. I'd go for 20 plate just to be sure in a three stager, but that's just me.
tiborrr is offline   Reply With Quote
Old 10-20-2009, 11:06 AM   #6
sdumper
-100c club
sdumper's Avatar
Thats good to know because 10plate is a lot cheaper
__________________
Old 10-20-2009, 02:21 PM   #7
teyber
Xtreme Mentor
teyber's Avatar
jinu illustrated some important notes about having too big of a HX, just as having too big of a condenser on the second stage will require MORE ethylene to condense to static/startup and a high high side pressures.
sorry if that doesn't make sense
teyber is offline   Reply With Quote
Old 10-20-2009, 02:54 PM   #8
sdumper
-100c club
sdumper's Avatar
I could use those notes because the desuper im about to use is a lot larger than i normally use:
http://cgi.ebay.com/ws/eBayISAPI.dll...tab%3DWatching
__________________
Old 10-20-2009, 02:57 PM   #9
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
^ this. Your high-side pressures won't be bad on a 3 stager so long as the 1st stage can handle the load but your static pressure will be through the roof. The 2nd stage shouldn't include anything flexible so you can run a little bit high on the static pressure, just keep in mind the maximum rated pressure on the components, especially the oil separator. This is also taking into consideration that the 2nd stage will NEVER be powered on without being chilled. That oil separator starts to think about becoming a hand grenade very quickly with a 300psi static and the compressor spinning up.
Desuperheater size doesn't matter, you cannot condense R1150 at ambient temperatures with the pressures you are using. Your R1150 will be gaseous until it hits the HX. Condenser/DSH sizing only matters when you are condensing refrigerant within it as you start to collect excessive amounts of refrigerant in the coils.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 10-20-2009, 03:47 PM   #10
sdumper
-100c club
sdumper's Avatar
Cool thanks Chris.
Were you talking to me with ^this or Tiborrr ? My build im starting right now is a 2 stage and I dont rebuild the 3 stage until late November.
__________________
Old 10-20-2009, 04:32 PM   #11
[XC] gomeler
Was indicating teyber's post, your post wasn't up when I was composing mine.
__________________
Old 10-20-2009, 04:38 PM   #12
yngndrw
yngndrw's Avatar
Send a message via MSN to yngndrw
Question, does the compression not heat the gas to a higher temperature than the ambient regardless of if it is condensing at that point or not ?
__________________
yngndrw is offline   Reply With Quote
Old 10-20-2009, 05:11 PM   #13
teyber
Xtreme Mentor
teyber's Avatar
Cool thanks Chris.
ill try to find it for ya mate. And by condenser i mean the hx not dsh..
Old 10-20-2009, 05:15 PM   #14
Ozzfest05
Ozzfest05's Avatar
Yes but that heat is removed or transfered into the copper piping in the condenser then the fans removed the heat from the piping/fins, rifled condensers transfer more heat.
__________________
Case: CM HAF
PSU: Corsair HX1000W
mobo: Rampage Extreme!
CPU:E8600 @ 4.4ghz 1.23 volts (Batch Q820aA405)
RAM: G Skill 1600 mhz DDR3 @ 7-7-7-18-1T stock OC'ed to 1960 mhz 8-8-8-26-1T
Graphics:4870x2
Cooling:H20 Apogee Gtz+Black Ice Tripple Rad
OS: XP 32
Bench Rig
Case: Antec 1200
Mobo: DFI LP DK P45 T2rs+
Ram: OCZ 800 mhz @1100+
CPU:E8500
PSU: Ultra 700w
CPU Cooling: Single Stage
Video Card: 9800gtx
Ozzfest05 is offline   Reply With Quote
Old 10-20-2009, 05:57 PM   #15
sdumper
-100c club
sdumper's Avatar
Gotcha ... I was dazed and confused for a few minutes
__________________
Old 10-21-2009, 04:24 AM   #16
yngndrw
yngndrw's Avatar
Now I'm confused.
They were saying that desuperheater size doesn't matter at all, I.e. It doesn't make a difference. The condenser in the second and third stages is the same as the desuperheater.
The point that I was making is that the compression generates heat regardless of if the gas is condensing or not. This means that the gas leaving the compressor is above ambient and can be cooled to (... close to ...) ambient by the condenser / desuperheater, hence it does make a difference and the size does matter.
Or am I getting something wrong here ?
__________________
Old 10-21-2009, 04:48 AM   #17
sdumper
-100c club
sdumper's Avatar
Now I'm confused.
No your not getting anything wrong. A Desuper is needed but it does not need to be very large so long as the gas leaving the condenser is close to room temp so that it doesnt enter the HX excessively warm/hot.
__________________
Old 10-21-2009, 04:52 AM   #18
yngndrw
yngndrw's Avatar
Okay that makes more sense thanks for clearing that up.
__________________
Old 10-21-2009, 09:50 AM   #19
Ozzfest05
Ozzfest05's Avatar
Now I'm confused.
The main thing here is were talking about cascade so yes the condenser is used as a desuperheater and it does not need to be very large
The main purpose is by lowering the heat of the gas which enters the HX
Your putting less load on your first stage less load equals lower pressures and better temps on your final stage.
__________________
Case: CM HAF
Graphics:4870x2
OS: XP 32
Bench Rig
Case: Antec 1200
CPU:E8500
PSU: Ultra 700w
Video Card: 9800gtx
Old 10-21-2009, 02:18 PM   #20
DonNiger
DonNiger's Avatar
20 plate HX should be able to handle 2 - 5kw of heat (a lot of inflected factors), 35 plate up to 8kw - thats a lot I think.
DonNiger is offline   Reply With Quote
Old 10-21-2009, 04:03 PM   #21
EvoCarlos
-110c club
EvoCarlos's Avatar
jsut thro a spanner in the works
i have a 24plate on outdoorcade and found it to be no diffrent form the 12plate just larger in size the diffrence in running porformance is minimal
but with more gas in the system = more capasty so larger hx more liquid -more capasity -to that sort of effect
i do think that a dsh is not needed on the 2nd stage but can take 5-10c off the gas temp (as alrady said) making it less load for the 1st satge
__________________
I LOVE LAMP!
EvoCarlos is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
