XtremeSystems Forums
Reply
Old 10-19-2009, 10:58 PM   #1
Salamndar
Salamndar's Avatar
onre MCR320 or 2 MCR220 ?
OK I'm having a space issue, so which is better an MCR320 or 2x MCR220 ?
The 2 MCR 220 will be mounted inside my case pulling air from outside to inside the case then other fan will pull the hot air outside the case.
The MCR320 will be mounted outside the case but due to this issue :
http://www.xtremesystems.org/forums/...d.php?t=237036
The MCR320 will make my system look really ugly because it will be sticking higher than the case!
So what do you think?
Salamndar is offline   Reply With Quote
Old 10-19-2009, 11:13 PM   #2
punkrockpolak
You'd get better cooling performance with the two MCR220s since you'll be able to dissipate more heat easier. Also you'll be able to avoid mounting the triple in front of your graphics cards. To top it off you said your rig will look much nicer with the two 220s.
punkrockpolak is offline   Reply With Quote
Old 10-19-2009, 11:22 PM   #3
Salamndar
Salamndar's Avatar
Ya with the 2 MCRs I'll mount on at the top of the case and one at the back side of the case so all rads will be inside the case, nothing external.
Old 10-19-2009, 11:42 PM   #4
shazza
Xtreme Fan
shazza's Avatar
What are you planning to put on your radiator ... CPU, GPU?,
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Old 10-19-2009, 11:50 PM   #5
Salamndar
Salamndar's Avatar
Right now, only the CPU and might later on add a water block for the graphics card and split the loop with another MCP 355.
here is the list I made to replace my old order, I need to send it to Gary ASAP.
check it out and tell me what u think?
Old 10-20-2009, 12:10 AM   #6
shazza
Xtreme Fan
shazza's Avatar
I assume an i7? or is this an i5 build?
Since you can't get the 320 in your case, I'd definitely go with the 220 for now, and add another later if you need it. Just my personal bias, but I prefer the radiators inside the case. Looks like you've picked some good fans that should do a good job on the radiator.
I see you've picked 3/8" x 1/2" tubing ... that's fine, just know that the thinner walls may be more likely to give you kinking problems if you have any tight bends.
__________________
Old 10-20-2009, 12:17 AM   #7
Salamndar
Salamndar's Avatar
I wanted to go with 1/2ID 3/4OD tubes but can't find 45dgree fittings with compression for it @ Sidewinder Computers.
The reason for the 2nd 220 is to connect it in the future with the graphics card.
Yes I have a Core i7 CPU and was testing it last night and found out that my R2E hits a wall at Bclk 209 which means the highest overclocking I can get from that CPU is less than 4.4GHz, so I think the 220 should be enough.
Old 10-20-2009, 12:27 AM   #8
shazza
Xtreme Fan
shazza's Avatar
The 220 should work ... but you'll be pushing it a bit at that OC (not saying it won't work, just don't expect super low temps). Again, you've picked good fans to go with it.
I see these 7/16"x5/8" 45 degree fittings in stock at Sidewinders
Also, this 45 degree rotary works with all sizes of compression fittings.
Please don't take my comments as gospel ... I've only used the 3/8"x1/2" tubing on one build - I like the way it looks, but as I said, it is a bit easier to kink. So go with whatever you want
__________________
Old 10-20-2009, 12:38 AM   #9
Salamndar
Salamndar's Avatar
The problem with the these 7/16"x5/8" fittings is that I'll have to go with clear Tubes, I want colored tubes
Old 10-20-2009, 01:02 AM   #10
UNIXgod
UNIXgod's Avatar
y? ton of 7/16 colored tubing out there
__________________
CPU: Intel Core 2 Extreme QX9650 Yorkfield
Motherboard: Foxconn Blackops X48
Memory: 4G 2x2 OCZ Reaper DDR3 1800 (PC3 14400) 8-8-8-27 1.9v
Hard Drives: 2 x W.D Raptor 150GB (OS, games, apps) RAID0
Video Card: XFX Black Edition 9800GTX @ stock frequency (760 core / 2280 memory / 1900 shader)
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Optical Drives: Nec 3550 dvd burner
OS: Gentoo GNU/Linux amd64 | Windows Vista Ultimate 64-bit
Odds/Ends: Razer Diamondback Mouse - Happy Hacking Keyboad Pro2 - RME pro audio card. FreeBSD UNIX servers and laptop when I'm not gaming!
UNIXgod is offline   Reply With Quote
Old 10-20-2009, 01:09 AM   #11
Salamndar
Salamndar's Avatar
Not on Sidewinder !
Old 10-20-2009, 01:19 AM   #12
Salamndar
Salamndar's Avatar
Ok what do you think with the list bellow?
I might add some Dye to color the D. water though I really hate to mix the water with any thing other than PT_Nuke !
Old 10-20-2009, 01:42 AM   #13
shazza
Xtreme Fan
shazza's Avatar
Looks good. Go with the clear tubing for now with just distilled and your PT-Nuke. If this is your first build, it's good to work with clear tubing - generally easier to see if you've got any air bubbles in your system. Down the road, if you want colored tubing, you can get it from somewhere else. I assume there's a reason everything needs to come from Sidewinders in one order.
__________________
Old 10-20-2009, 02:06 AM   #14
Salamndar
Salamndar's Avatar
Ya I have a Credit card issue as it is refusing to work online and my Bank can't decide why, Gary is helping me by doing it manually with a picture of my credit card.
Old 10-20-2009, 06:28 PM   #15
UNIXgod
UNIXgod's Avatar
Not on Sidewinder !
I didn't realize you couldn't shop anywhere else. To bad. colored tubing looks hot
__________________
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
