XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-19-2009, 09:55 PM   #1
xREDMAN
best cpu cooler for i5 750
i need to find one that is not too heavy and cools well enough for 4ghz+
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
4GB CORSAIR XMS3 ddr3 1600mhz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
xREDMAN is offline   Reply With Quote
Old 10-20-2009, 03:17 AM   #2
DAK1640
Riptide's Dad
DAK1640's Avatar
Send a message via AIM to DAK1640
Try Zalman CNPS 10X...I am pleased with the results
__________________
Q6600 Farm with nVidia GPU's
DAK1640 is offline   Reply With Quote
Old 10-20-2009, 04:00 AM   #3
OgaiB
buy EVGA's any P55 chipset motherboard, they already have LGA775 holes and choose any Super cooler
__________________
CPU : AMD X2 5200+ @ 3Ghz
Motherboard : EPOX EP-AF590 SLI2 with Thermalright HR-05 IFX SLI
CPU Cooler : Thermalright Ultra 120 Extreme with Noctua NF-P12
Videocard : XFX 8600GT Fatal1ty Edition @ 700/1800Mhz
DDR : Teem Xtreem PC-6400 2X1GB @ 4-4-4-8 / 500Mhz
HDD : Sata II - 2 X Seagate 250GB ST3250410AS 16MB cach in RAID 0 ; IDE - Seagate 160GB, WD 80GB
PSU : Chieftec 600 Watt, +12V Combined 48A - CTF-600-14CS
CASE : Chieftec AEGIS CX-05B-B with 4 X Scythe SLIP STREAM SY1225SL12M controled by
Scythe Kaze Master 5.25 @ 1000RPM; 3 X Noctua NF-B9 @ 1000RPM
Monitor : HP L1740
speacker : Logitech X-230
OgaiB is offline   Reply With Quote
Old 10-20-2009, 04:54 AM   #4
lasty
TRUE, Prolimatech Megalems, Corsair H50 are all available with socket 1156 mounting kits.
Using a Coolermaster Hyper 212+ myself, its very cheap and you get about 90% of the performance of the above mentioned products at roughly 30-40% of their price. (22euros for me, vs 65/70 euros for the others) I can run my i7 860 at 3.8ghz with around 70 degrees celcius with full prime load. The 750 should be around 10 degrees cooler if i read the other reviews correctly.
lasty is offline   Reply With Quote
Old 10-20-2009, 05:11 AM   #5
zsamz_
Xtreme Guru
zsamz_'s Avatar
i have a coolmaster 212 on my 860
and it dont cut it past 4.0
just waitin on Megahalems 1156 mounting kit
__________________
evga p55-ftw+i7 860 @4.1+megahalems
rampage extremeII 920 Batch# 3849B018 4.4@1.38v
gigabut p55-ud4p died after 4 days
e8600@ 510x9 1.38v +thermalright 120X
rampage extreme500x9 1.34v
dominator 1800 cas7
hyperx 2k cas8
northq blackmagic 850
p35c-ds3r bios suks
gigabut x38-d6q dead thank god
ballistix 8500 1240mhz@2.02v 5++sets of d9 downsizin
zsamz_ is online now   Reply With Quote
Old 10-20-2009, 05:15 AM   #6
chuck4456
chuck4456's Avatar
Thermalright works.
__________________
GIGABYTE P55 UD4P-i5 750-Thermalright HR01 Plus-GeIL Ultra-Sapphire HD3870 Xfire-Seagate Drives-Antec 300-22" BenQ-W7
abit IP35 PRO-E8600-Thermalright HR01 Plus-KHX-Sapphire HD4870T-Seagate Drives-Antec 300 w UGuru Panel-22" LG-XP Pro
ASUS P5Q Deluxe-Q6700-TRUE BE-Noctua Fan-Corsair Dominator-Sapphire HD4870 2GB-WD Black Drives-CM690-40" Bravia V-W7
POWERED BY PC POWER & COOLING
chuck4456 is offline   Reply With Quote
Old 10-21-2009, 03:03 PM   #7
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Send a message via MSN to RPGWiZaRD
My CoolerMaster Hyper 212 Plus keeps my i7-860 4.10GHz ~1.4v (CPU-Z) HT off at 68~71C in LinX at 1700rpm with the included fan or 4.0GHz with HT on @ 73~76C. Granted not using a comp case and AC MX-3 thermal paste.
For the price I'm very satisfied but damn I wish I would get some nice CPU samples for once so I don't have to push them to the very limits for aircooling to reach some satisfying clocks. Good samples would allow 4.25~4.3GHz at 1.4v. :s
__________________
Intel® Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
RPGWiZaRD is offline   Reply With Quote
Old 10-23-2009, 08:32 PM   #8
xREDMAN
is all these heatsinks mention can keep it 24/7 stable?
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 10-24-2009, 03:03 AM   #9
DAK1640
Riptide's Dad
DAK1640's Avatar
Yepper
__________________
Old 10-25-2009, 07:46 AM   #10
bubata
Went trough the ArcticFreeze, CoolerMaster and finally got Zalman CNPS 10X works very nice holds i5 750 at 4ghz and 1.4v at 60-62c full load. And it's quite enough
bubata is offline   Reply With Quote
Old 11-02-2009, 10:59 AM   #11
sandy
sandy's Avatar
TRUE
sandy is offline   Reply With Quote
Old 11-02-2009, 10:47 PM   #12
Computurd
Computurd's Avatar
4+ only true or megalhem can handle that heat
__________________
"Lurking" Since 1977
Computurd is online now   Reply With Quote
Old 11-03-2009, 01:16 AM   #13
mäggäri
mäggäri's Avatar
EKL Brocken is a gift from God. Doesn't need so high airflow. Idk where u guys live, and is it available there. But in Europe it is. Costs around 30-33euros.
6mm heatpipes against 8mm... last one is only 1.33x bigger (6mm vs. 8mm) - But, when we compare the capacity, it's something to mention about;
6mm thick x 155mm lenght
vs.
8mm thick x 155mm lenght
I think I count right, the 8mm pipe is ~1.78x BIGGER in the capacity than 6mm !! This is mostly the reason why 4x6mm basic air-coolers cost so much less than 8mm. :P I mean, in theory 4x8mm heatpipe cooler is ~1.78x better than 4x6mm =D
In other words, you need 7x4mm heatpipes in your cooler that it could transfer as much heat as 4x8mm.
mäggäri is offline   Reply With Quote
Old 11-03-2009, 07:10 AM   #14
dro
dro's Avatar
Whats the temperature range you're trying to achieve?
__________________
dro is offline   Reply With Quote
Old 11-03-2009, 04:28 PM   #15
xREDMAN
umm 70 at max load or less :/
__________________
Red Addiction:
EVGA P55 FTW
i5 750 @ 4ghz
HD5850 stock
300gb VelociRaptor
1tb WD Caviar Green
Topower 900w
Old 11-03-2009, 05:08 PM   #16
Ezekiell
How does the Corsair H50 holds against the Zalman CNPS 10X, TRUE and Mega
Ezekiell is offline   Reply With Quote
Old 11-03-2009, 05:38 PM   #17
Ar3s
Ar3s's Avatar
Send a message via Skype™ to Ar3s
Corsair H50 with better fans would be definitely better. TRUE's i5 mounting does seem to have an issue. Prolimatech Megashadow / Megahalem Rev B are awesome. Noctua has some new Heatsinks too. NH-D14 as well as the popular U12P SE2 are great for i5.
__________________
Everyday is a NiceDay
Ar3s is offline   Reply With Quote
Old 11-03-2009, 08:29 PM   #18
dysgenics
dysgenics's Avatar
my i5 is at 4ghz (1.38 vcore) with u12p se2 push/pull @ 1300rpm, after several hours of occt linpack i only hit 76c max, idle is around mid 30's.
dysgenics is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
