XtremeSystems Forums
Reply
Old 10-19-2009, 07:39 PM   #1
ohms
VČ/P
ohms's Avatar
Send a message via AIM to ohms Send a message via MSN to ohms
Is this 5870 reference design?
Can anyone tell me if the DIAMOND 5870PE51G Radeon HD 5870 (Cypress XT) 1GB is using the reference design PCB before I do any purchases?
__________________
My Worklog: Project Raven ATCS 840
Today the guns are silent. A great tragedy has ended. We have known the bitterness of defeat and the exultation of triumph. And from both we have learned, there can be no going back. We must move forward, to preserve in peace what we've won in war." - Douglas MacArthur
ohms is offline   Reply With Quote
Old 10-19-2009, 07:45 PM   #2
NaeKuh
Broken Gainestown
NaeKuh's Avatar
Diamond has almost next to no customer support.
So i would recomend u go another reputable vendor.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 10-19-2009, 07:52 PM   #3
ohms
VČ/P
ohms's Avatar
Well I purchased the card already I was talking about purchases referring to the block.
__________________
Old 10-19-2009, 08:34 PM   #4
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
i don't believe any non-references cards are out yet...... usually takes then a couple months before they come out with non-ref.
Caoder is offline   Reply With Quote
Old 10-19-2009, 08:40 PM   #5
WaterFlex
WaterFlex's Avatar
Caoder
I am of the same mind
__________________
Intel E8400 500x9MHz@1,37V LinX 64bit mode stable
Asus Maximus II Formula 2202 Bios
OCZ Blade Series PC2-9600 4GB 1200MHz/5-5-5-15/PL8/1,8V
Seagate RAID0 2x Barracuda 7200.12 500Gb
Asus Radeon HD5870
Iiyama ProLite E1902S-B1 Black
Thermaltake Xaser VI BWS
Seasonic M12-700 Watts
M-Audio Audiophile 192
Liquid Cooling System :
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
EK Water Blocks EK-FC5870 Acetal+Nickel with EK-FC5850/5870 RAM Backplate
ThermoChill PA120.3, Laing 12V DDC-1Plus, XSPC Laing DDC Reservoir Top
Arctic Cooling MX-3, 3x Scythe S-FLEX "F", 3x Scythe Gentle Typhoon "15", 2x 140mm Noiseblocker NB-BlackSilentPRO PK3, Scythe Kaze Master Ace 5,25''
WaterFlex is offline   Reply With Quote
Old 10-19-2009, 09:25 PM   #6
Baulten
Yes, right now the only 5870s out are reference design. I believe Vapor-X will be coming out from Sapphire soon, and won't be reference design... but right now the only cards are reference design cards.
__________________
The parts:
| MSI 790FX-GD70 | Phenom II 965 140W | Sapphire HD 5870 | 2x2 GB G.Skill Ripjaw DDR3 1600 7-7-7-21 | 3 x 250 GB SATA HDDs | 1 x 1 TB WD MyBook External | Corsair Obsidian 800D |
The cooling:
| PrimoChill Typhoon III Bay Reservoir/Pump | MCR320 | 3x120mm 1450 RPM Scythe GentleTyphoon | HeatKiller REV3.0 LT | EK HD 5870 FC Nickle | ThermoChill PA120.2 | 2x120mm 1900 RPM Scythe S-Flex |
Baulten is offline   Reply With Quote
Old 10-19-2009, 09:25 PM   #7
ohms
VČ/P
ohms's Avatar
Cool, thanks for the info
__________________
Old 10-20-2009, 01:08 AM   #8
W1zzard
Xtreme Legend
Send a message via ICQ to W1zzard Send a message via AIM to W1zzard Send a message via MSN to W1zzard
yes it uses reference, non-ref designs are scheduled for q1
__________________
techPowerUp! | GPU-Z | VGA Bios Collection
W1zzard is offline   Reply With Quote
Old 10-20-2009, 01:38 AM   #9
Salamndar
Salamndar's Avatar
Ya, I remember the days when Diamond MM was the top Dog......
Salamndar is offline   Reply With Quote
Old 10-20-2009, 03:59 AM   #10
Tackleberry
Tackleberry's Avatar
use coolingconfigurator.com
maybe u will find answer there
Tackleberry is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
