10-19-2009, 05:22 PM
#1
Radiator selection help
Build a 2nd system...more for looks/low noise than performance.
I am looking a rad for 3 120mm fans. Most likely GT-ap-14's 1450 rpm low noise fans. Or even AP-13's if I can get away with it.
The depth limits I have for rad+fan height is 3.25 inches.
I was looking at MCR 320 stackable for two reasons.
The dual inlet outlet, saves me a ton of extra work of routing the tubes; inlet coming from the top, and outlet exiting through the bottom. And its really thin, specs say 1.3" in depth.
The only problem seems to be fin density. at 14 FPI, its not really meant for low RPM applications.
Asking if there is something better suited that may meet my needs.
Thin is good(under 2" thick), low FPI, and finally if it had some flexibility in the routing (but not a deal breaker)
It will cool, either 920 or 860 (little OC, depending on low the temps fare) + 5850 single GPU.
Thanks for any help
10-19-2009, 05:40 PM
#2
Xtreme Fan
The MCR 320 does well with lower RPM fans ...
Check out this recent recent post by Vapor.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
10-19-2009, 05:43 PM
#3
Yah the swiftech is exactly geared at low rpm fans.
Now 30 FPI like the one black Ice rad.. .THAT requires loud fans
Top of heap after all these years is still the thermochill 120.3 And you are still going to pay through the nose for it. (for low speed quiet water cooling. )
10-19-2009, 05:44 PM
#4
wow, thanks
That totally solves all my problems.
And I assume MCR 320 has the 15mm spacing ?
10-19-2009, 05:47 PM
#5
Xtreme Guru
I'm not certain what you mean by top in bottom out. You plan to mount the rad horizontally?
I'm running the MCR320 with GT 1850s without a problem.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-19-2009, 05:48 PM
#6
Xtreme Fan
Yep on the 15mm spacing.
My assumption is the stackable version has the same performance as the regular one, just has the 2-sided barb option - but the barbs are both on the same end of the radiator, so not sure how that helps a lot.
__________________
10-19-2009, 05:51 PM
#7
yeah the mcrw320 is great with low speed fans as it the thermochill pa 120.3
__________________
EVGA P55 FTW::::Ci7-860(1.019 VID)@4000MHZ::::HD4850 ICE-Q4::::4GB CRUCIAL DDR3 1600MHZ::::TUNIW 120XTREME::::ULTRA 1KW 12V SINGLE RAIL PSU::::WIN7 X64
http://ocguru.webs.com/ <<check it out
10-19-2009, 06:01 PM
#8
Yeah, at 1450 rpm the lower fpi radiators perform the same. Great deal as the MCRs are half the price of PAs, RXs and SR1s.
10-19-2009, 06:05 PM
#9
Thanks again for the help.
This is for a steampunk comp build. The reservoir is an old miners lamp, ie the res will live on top of the case and feed the rad from the top side. Then it will exit bottom to the CPU and GPU and loop back up to the res.
I am going to make a worklog will have more detailed drawings on it.
Thanks, all.
10-19-2009, 06:10 PM
#10
Xtreme Fan
Sounds good. Just wanted to make sure you weren't getting the config of the stackable radiator confused with the HW Labs X-flow configuration, where inlet and outlet barbs are on opposite ends of the radiator.
__________________
10-19-2009, 09:39 PM
#11
+1 Mcr320
__________________
upgrading...
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
