XtremeSystems Forums
Reply
Old 10-19-2009, 02:00 PM   #1
mariop
New topping for my block
Hi guys,
this week im gonna make a new topping for my block (actually it has a 939 socket acrylic topping with a thin acrylic bracket over it to fit am2 socket)
the project:
exploded view:
It will be a metal topping over an acrylic one. I want to give the metal that chromed looking (like this: http://www.extremerigs.com.au/images/apogee_gtzse.jpg)
Wich metal should i use? Wich metals get chrome coating?
Thanks,
Mario.
mariop is offline   Reply With Quote
Old 10-19-2009, 02:27 PM   #2
ChielScape
they usually copper plate before they chrome plate it anyway, since chrome doesnt "stick" well to other metals (not even copper but its the least bad one i guess)
but afaik that one you linked to is just polished stainless steel. (not sure though)
ChielScape is offline   Reply With Quote
Old 10-21-2009, 05:21 PM   #3
mariop
Hmm, thats okay. I think i'll use a piece of steel do make it.
Im thinking on making the middle part in acetal instead of acrylic. I've also modified a bit the steel top.
bye.
Old 10-22-2009, 02:13 AM   #4
ChielScape
smart choice on the delrin. a lot more resilient to cracks than acrylic. not worth it if you're not going to be able to look into it anyway.
Old 10-22-2009, 02:37 AM   #5
Tackleberry
Tackleberry's Avatar
yes but it also limits option with LED's.
which in this case would be just glowing from the side....
still, good argument.
Tackleberry is offline   Reply With Quote
Old 10-22-2009, 01:16 PM   #6
ChielScape
well, you could do a thin acrylic plate the exact same shape as the steel one, and put it under that steel one.
Old 10-23-2009, 01:20 PM   #7
mariop
Hi guys,
unfortunately i couldnt find yet the acetal. So, by now i'll make it using acrylic and when i find acetal i'll do it again.
Old 10-23-2009, 01:34 PM   #8
Waterlogged
I am Xtreme
Waterlogged's Avatar
Try asking for some of it's other names as well. Some ppl may never have heard of acetal but may have heard of POM or Delrin among others.
http://en.wikipedia.org/wiki/Polyoxymethylene_plastic
__________________
Waterlogged is offline   Reply With Quote
Old 10-25-2009, 07:05 PM   #9
mariop
Thanks for the tip, i'll try to find it under these other names.
Old 11-03-2009, 05:17 PM   #10
mariop
The acrylic part:
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
