Vario D5, louder as it gets slower...
I bought a T3 with a vario D5, but when I start to turn it down it will get louder (high pitch) with a lot of vibration. At level 1 there isnt much high pitch but a lot of vibration, lvl 2 more high pitch little less vibration, lvl 3 a lot of high pitch lots of vibration, lvl 4 less high pitch than any other setting,medium amount of vibration (my setting since it is the quietest), lvl 5 tons and tons of vibration, medium amount of high pitch.
I noticed a little squeal when hand turning the pump when not installed, but thought it would go away once it had liquid running through it.
Is this all normal or did I get a rotten apple?
thanks
