XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-19-2009, 12:34 PM   #1
werty316
werty316's Avatar
Cooler Master Fan
One of the following fans below started to vibrate really bad so to fix this problem I was going to apply a few drops of 3-in-1 oil lubricant to the bearing however when I took off the back sticker there wasn't a hole present :?: I thought maybe these fans were designed similar to Noctua branded fans so I tried to pull the fan housing off but no luck.
Here are the fans in question:
I know it looks like you can remove the cover on the backside of the fan like any other generic fan but it cannot be removed because its one solid piece of plastic.
Does anyone who is familiar with these fans know how take off the fan housing?
Model number on the back of the fan says A12025-20RB-3BN-F1.
If possible I would like to refrain from using a power drill.
__________________
An apple a day keeps the doctor away. A Chuck Norris a day kills.
werty316 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
