10-19-2009, 03:14 AM
#1
Will these heatsinks be enough to couple with a gpu only 5850 block?
http://www.chilledpc.co.uk/shop/prod...roducts_id=578
I intend to have a fan blowing towards them and already have heatsinks for the RAM.
Also, just to clarify, which areas, other than the RAM, will need cooling if I go for a GPU only waterblock? Sorry for my lack of technical knowledge, but I know that the three chips behind the silver rectangle on the right need cooling, and possibly the one between the two holes on the top right. Is that correct?
sorry, this is in the wrong forum, i thought that i was posting in Liquid Cooling. would a mod mind moving this for me? thanks.
Reason: wrong forum
10-19-2009, 04:26 AM
#2
Xtreme Mentor
Should be enough I believe.
Also, as an alternative, you could mod your stock heatsink - cut a hole for your GPU waterblock leaving the remaining part to cool the rest of your card.
10-19-2009, 06:05 AM
#3
cool, fingers crossed my maze4 will fit, i've seen it on a few 4870's so it should fit.
10-19-2009, 06:34 AM
#4
what is the main reason for not taking full cover solution?
10-19-2009, 06:37 AM
#5
I already have a maze 4 and don't want to spend the money on a full cover block, they are too expensive.
10-19-2009, 09:13 AM
#6
Xtreme Enthusiast from EK
I think you will have problems with securing these to so small chips.
__________________
Originally Posted by creidiki
EKs are like waterblock pr0n
10-19-2009, 10:20 AM
#7
Good point. What would be the best way to do so if I don't want to have to buy a full cover block?
10-21-2009, 08:42 AM
#8
anyone else think that this is a bad decision? I really need a new GPU and would like a 5850, but the price of that plus a full block is just too much money to spend imo.
10-21-2009, 08:46 AM
#9
Xtreme Mentor
5850 you dont have to cut anything stock heatsink fits anyways with gpu only block
only 5870 you need to cut out...
anyway imo use that with the upcoming swiftech heatsink unisink block thing next month which is like £20/25 cooling everythign then  much better idea
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
10-21-2009, 04:22 PM
#11
Zombie Assassin
You could by one of those Zalman 48xx VRM sinks and use thermal tape... would work great and cost the same.
I planned on releasing a 58xx VRM kit but haven't gotten around to it.
__________________
i5 750
Asus Maximus III Gene
Patriot Viper II Sector 5 DDR3-1600 4Gb
XFX 5850 1Gb
Antec NSK3480/Seasonic SS-500HT
10-22-2009, 08:30 AM
#12
thanks again for the replies everyone
I'm confused. Doesn't the swiftech heatsink replace the stock heatsink? how would you use both? Or when you said 'use that' did you mean use the Maze4 with the swiftech unisink?
That looks really good, I wasn't aware of them. Do the 5850's not need cooling on the chip towards the top left that I pointed out in the first post. I could have sworn that I read somewhere that it did, but I can't find it now and it may have been talking about the 5870.
10-25-2009, 03:27 AM
#13
does anyone know if the chip that i circled needs cooling too?
10-25-2009, 06:45 AM
#14
Xtreme Guru
You can either use the stock heatsink and just install the Maze 4 on the GPU, or you can try the Swiftech unisink. I'm not certain if the Maze 4 is compatible with Swiftech's heatsink.
If it isn't, a Swiftech MCW60 and the unisink are normally a good 30-40 dollars under the full cover options.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-25-2009, 08:04 AM
#15
Xtreme Mentor
yes but the swiftech looks nicer and acts as a proper heatsink etc a lot of surface area and stuff
http://www.swiftnets.com/assets/imag...20ASSEMBLY.jpg
__________________
//James
10-29-2009, 08:32 AM
#16
As far as my budget will allow, the only options are to buy a 5850, use the stock heatsink and put the maze 4 on the gpu.... ( is this even possible and is it hit and miss as to whether or not the maze 4 will fit with the heatsink? )
or
To install the maze 4 with heatsinks for the ram and a Zalman 48xx VRM heatsink... in which case I still need to know if the chip that I circled below also needs cooling.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
