XtremeSystems Forums
Reply
Old 10-19-2009, 01:41 AM   #1
M.Beier
"HW addict"
M.Beier's Avatar
Send a message via MSN to M.Beier Send a message via Skype™ to M.Beier
HK rev.2.5 vs. 3
Hi guys, I havent been using watercooling for ages, but would like to do so again, maybe chilled water... (have all the stuff)
I used to use rev 2.5 HeatKiller on LGA775...
Question is; is rev.3 better, and if yes, how much better????
Bonus question is; will mount from rev3 work on rev2.5 ?? I want to use LGA1156
Thanks,
Marc
__________________
Competition ranking;
AOCM II 2008: #2(01SE,AM3,8M), AMD-OC 2009 DK: #2(max freq), Gigabyte TweaKING 2009: #4(32M, 01SE)
Highest freq for Ras to CAS; 5(?),7 (1000,1275)
HWB hunt on gfx classics to be initialized soon!
M.Beier is offline   Reply With Quote
Old 10-19-2009, 02:55 AM   #2
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Hey Marc,
Don't how much the difference is but the rev 3 is really hot here atm while nobody really cared for the former revisions of the Heatkiller.
It's supposed to be about 2ºC better than the FuZion rev 2 to give you an idea.
I think rev3 has it's own mounting and there are backplates available for socket 1336, don't know about 1156 but a little google search will help you out.
By the looks of it i'd say it's the same as socket 1336:
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 10-19-2009, 03:38 AM   #3
M.Beier
"HW addict"
M.Beier's Avatar
Design appears identical on the inside, difference is that this one has some metal with heatkiller 3.0 in steel on top... :-P
__________________
Old 10-19-2009, 04:31 AM   #4
cx-ray
V
They're very different (no bow, no distributer plate, not very fine cooling channels, much smaller size). The HK 2.5 was one of the worst blocks for quad cores.
cx-ray is offline   Reply With Quote
Old 10-19-2009, 04:45 AM   #5
Zeus
Xtreme kickass
Zeus's Avatar
Looks can be decieving my friend.
__________________
Old 10-19-2009, 08:05 AM   #6
M.Beier
"HW addict"
M.Beier's Avatar
I just looked at the inner design, ok, I admit, huge difference, seems I will order a new block =) (and a regas for the mach II while Im at it)
__________________
Old 10-20-2009, 03:05 AM   #7
cx-ray
V
A correction to my previous post. The HK 2.5 does have a distributor plate. It's integrated into the mounting "wings". The block consists of two halves. One upper and one lower with the mount sandwiched in between.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
