XtremeSystems Forums
Reply
Old 10-18-2009, 07:57 PM   #1
Sil3ntSnip3a
Sil3ntSnip3a's Avatar
Send a message via Skype™ to Sil3ntSnip3a
5870 Water Blocks
So of course the new ati radeon 5870 is out and companies have started making the gpu block for them. I was wondering if anyone had the results for the best block out for it yet?
__________________
Sil3ntSnip3a is offline   Reply With Quote
Old 10-18-2009, 08:19 PM   #2
JaD
JaD's Avatar
Send a message via ICQ to JaD Send a message via MSN to JaD Send a message via Skype™ to JaD
What about checking the other first page threads first?
http://www.xtremesystems.org/forums/...d.php?t=232879
JaD is offline   Reply With Quote
Old 10-18-2009, 08:25 PM   #3
Utnorris
Utnorris's Avatar
At the end of the day you will find that FC blocks all perform around the same. I would suggest one that cools the VRM's as well if you will be trying for a high overclock. Look at the EK, Swiftech and Koolance, those are currently out and cool the VRM's with water flow. BP will have one out soon as well as Aquacomputer, both will probably also have the water flowing over the VRM's.
__________________
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Corsair 800D
I7 920 (3849B028)/Classified/ EVGA GTX 295/ 6Gb (3x2Gb) OCZ 1866 Ram @ 1600 6-6-6-16-1t timings / Inte M-25 80Gb SSD x 2 RAID 0
W/C System
(CPU) EK Supreme Classified (NB) EK Water Block / Typhoon III with XSPC RX360 / B*P/Koolance Compression Fittings and Quick Disconnects.
Utnorris is offline   Reply With Quote
Old 10-18-2009, 10:19 PM   #4
punkrockpolak
DangerDen also has a block coming out for the 5870, but the water path looked like it was the smallest by far. I'm expecting it's going to be the worst performer of the bunch based solely on that fact, but can't say for certain that it won't compete until all of the blocks can be tested.
punkrockpolak is offline   Reply With Quote
Old 10-19-2009, 05:40 AM   #5
Razrback16
So far, just from my reading through the 12 page 5870 waterblock thread on the first page, it looks like Gabe's Swiftech full cover block has the best temps so far. Like norris said, I would make sure to focus on VRM cooling. This will mean the difference between a successful voltmod and being stuck at stock voltage.
__________________
MSI K9A2 Platinum
AMD Phenom II X4 955 Black Edition @ 3.6GHz
Cooling: [Swiftech Apogee GT Waterblock]
G.Skill 4GB (2GBx2) DDR2 1066
Radeon 4890/1GB Crossfire
Cooling: [Koolance VID-487 FC Waterblock / Koolance VID-487 FC Waterblock]
Core Clock: 975MHz / 975MHz
Mem Clock: 4320MHz / 4320MHz
Razrback16 is offline   Reply With Quote
Old 10-19-2009, 08:06 AM   #6
Utnorris
Utnorris's Avatar
Do not take what Gabe posted as being fact though, it's just what he has experienced so far, until we get more user reviews or a full blown review I wouldn't declare a winner just yet. I would still stick with Swiftech, EK or Koolance due to them actively cooling the VRM's. As I stated before, wait a few weeks and the BP and Aqua Computer will be available also.
__________________
Corsair 800D
W/C System
Old 10-20-2009, 05:23 AM   #7
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
personally I would go EK it seems to get the water closer to the VRM's then the others so far :/
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
