10-18-2009, 04:33 AM
#1
How much Ln2 would you say is used during a session?
Me and a friend is having some ideas of taking the step into Ln2 land... But the prices are quite steep for us here in sweden since we don't have those "special connections" most do.
For example how much Ln2 would you say a Phenom II x4 or Core i7 w/HT uses during a session of say an hour or 2 under some semi-heavy utilization (Super Pi, wPrime, 3Dmark06 etc.)?
__________________
Nvidia GT300 yields are under 2%
Originally Posted by Chickenfeed
I am adding awesomeness funtionallity to life and your name must be Chickenfeed for it to function.
CPU: Phenom II X2 550BE @ X4 B50
Clock: 3600MHz 1.4v 24/7 crunching stable
Memory: 2x2GB 1333MHz 6-6-6-18-24-1T
Motherboard: MSI 790FX-GD70
GPU: ASUS HD5850 1GB
AMD Forum
10-18-2009, 10:18 AM
#2
Diablo 3! Who's Excited?
2 hours for a brief SuperPi, wPrime and 3D06 run would be maybe 6-8 liters of LN2. It is always best to get more than you will need though, there is nothing worse than running out right at the end of a benchmark.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
10-18-2009, 11:14 AM
#3
From what I've read a good estimate is 1L per 10 minutes roughly.
10-18-2009, 11:32 AM
#4
No rest for the weary
Heh I have a video of me suicide bencing 06 on a cpu of ln2, hilarious even made it through and grabbed screen and submission.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
10-18-2009, 12:22 PM
#5
Ok thanks, that's abit better than expected to be honest... I've heard 6L for each 3Dmark06 I was like  but he must've meent CPU and a few GPUs on Ln2 at the same time I suppose?
6-8L an 2 hour isn't that bad it's even something I could afford to do every now and then.
__________________
AMD Forum
10-18-2009, 01:22 PM
#6
2h isn't enough for me to get most optimal cpu settings for benching and you want to run spi, wprime and 3mark in this time :O
__________________
Q6600 ▪ P5K-E ▪ 8800GT ▪ G.Skill HZ 2x1GB ▪ Barracuda 7200.10 ▪ Corsair 520HX ▪ TT Tsunami
10-20-2009, 04:27 PM
#7
-100c Club
If you know your chip (pretested with cascade) and ofcourse the rest of the setup, 10-15L is enough for all benchmark. But I would rather advise doing it this way:
1) Get 10L, bench mostly CPU-Z suicide shot, at the end try some simple Pi1M, PiFast and Wprime to get a rough estimate on what frequencies you can expect
2) Get 20-30L, bench all 2D. With what's left try benching some simple 3D, e.g. 3DMark06/Vantage CPU tests.
3) Get 20-30L, bench 3D
Divide your overclocking into stages, it's waaaay more fun.  After a couple of sessions you will be able to do everything (2D/3D) in a single session. Start easy & learn as you advance.
10-20-2009, 04:59 PM
#8
Well said
Testing Chips with LN2 can get quite expensive though. In general i also pretest my chips under cascade (expect Phenoms) and only do the real benching stuff und "maxing out" with Ln2. Before you buy Ln2 it would be good to know an approximate frequency your CPU is capable of. But 10l will do the job in most cases like tiborr said if your benching with Ln2 only.
CPU`s dont need that much LN2. But if it comes to GPU´s it´s another story..
__________________
System #1:
i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6T 0603, 3x2048 Corsair Dominator 2000CL7, Sapphire 4870X2 @ 825/1000 (Asus TOP Bios), Corsair HX1000, 1x150GB Velociraptor, 1x1TB WD Green, 1x500GB WD Caviar
Cooled by:
Loop 1: D-Tek Fuzion rev1, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Scythe Ultra Kate 2kRmp Pull
Loop 2: XSPC 4870X2 Acetal, Laing DDC-1T /w XSPC Res Top, Thermochill PA120.2 /w Medium Yates Push/Pull
4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
http://img402.imageshack.us/img402/1251/83962063.jpg
AMD @ testing
X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
10-21-2009, 02:30 AM
#9
Thermo-Bear
Yeah can just agree on this
I mostly use ~50l for 2 days. Fits for 2D Benches and 3D (including GPU cooling)
__________________
10-21-2009, 06:12 PM
#10
tiborrr, thanks for the advice, works out well for my 80L dewar  The only thing holding me back from LN2 right now is a truck, and it's driving me nuts :O And you know the poorer benchers out there can test under single stage to get a good idea how to own the board and cpu by using lower multipliers. Or maybe my cascade envy is showing *covers it up*
__________________
Cooling:
Custom SS made by RunMC of under-the-ice.com
80L Cryofab CL80 Dewar
Otternase EEAL.CU
Tried: e8400,q6600,qx9650
Subzero queue: AMD Athlon 64 3000+,3200+,3500+ winchester, 3500+ newcastle, 3500+ Orleans, 3700+, 4000+, 4200x2+ & DFI LP Ultra
Intel P4: 520, 631
w3550+Bloodrage GTI,
asus commando
Inbound: sdumper SS
10-31-2009, 02:18 AM
#11
My Q6600 went through about 10L in about 1 hour  Didn't even get any good scores too  (the mobo's fault).
11-04-2009, 10:41 AM
#12
70L for two people and becnhing two days is ok.
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
