10-17-2009, 10:37 PM
#1
Water cooled vs Air cooled on the CPU ?
This might be a dumb question for you guys but i would like to try watercooling and wanna know if water cooling the cpu is a major difference in temps rather then having a fan on the cpu? Im not an extreme over clocker or anything like that but i do have a good setup i would like to adjust a little bit and tweak out. Would u say water cooling is worth the setup on temps over air cooled? Thanks
10-17-2009, 10:39 PM
#2
not really worth the upgrade...if you minor overclocks..like 4ghz on an e8600...or 3.6ghz on an i920
silent push pull air coolers are good for minor overclocks...
__________________
10-17-2009, 11:57 PM
#3
There is no comparison between a good water setup and a air cooler. Water will have MUCH lower temps vs a air cooler. If you plan on not overclocking too much then yes a air cooler will be fine, BUT if you want to get into water cooling , it is FAR superior to air and in my opinion is worth every penny...not only for the cooling performance but also the low noise factor
__________________
Intel i7 920@3.6 , Asus Rampage 2 Extreme , 6gb Corsair Dominator @1600mhz , Sapphire 5870 x2 @ 900/1300 (for now), Win 7 RC1
10-18-2009, 12:38 AM
#4
I went WC because i needed less noise
__________________
Intel E8400 500x9MHz@1,37V LinX 64bit mode stable
Asus Maximus II Formula 2202 Bios
OCZ Blade Series PC2-9600 4GB 1200MHz/5-5-5-15/PL8/1,8V
Seagate RAID0 2x Barracuda 7200.12 500Gb
Asus Radeon HD5870
Iiyama ProLite E1902S-B1 Black
Thermaltake Xaser VI BWS
Seasonic M12-700 Watts
M-Audio Audiophile 192
Liquid Cooling System :
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
EK Water Blocks EK-FC5870 Acetal+Nickel with EK-FC5850/5870 RAM Backplate
ThermoChill PA120.3, Laing 12V DDC-1Plus, XSPC Laing DDC Reservoir Top
Arctic Cooling MX-3, 3x Scythe S-FLEX "F", 3x Scythe Gentle Typhoon "15", 2x 140mm Noiseblocker NB-BlackSilentPRO PK3, Scythe Kaze Master Ace 5,25''
10-18-2009, 12:51 AM
#5
Water cooling, when done right, is superior to air cooling in terms of just thermal performance. You will see dramatically lower temps than what you are accustomed to seeing. Water cooling has other features over air, not just for thermals. Noise is can be lower because fans can be set at lower RPM overall, and if you are really into the hobby, water cooling can be made to simply look great inside a good case.
However, the investment is, of course, much greater and unless it meets one of your needs then it is not worth the investment. Just seeing lower temps is not a good enough reason, in my opinion, to engage in water cooling. If your desire is getting that last extra stability at the highest sustainable clock speed, a silent running PC, and/or the asthetics then go for it otherwise, a good air cooler will suit you fine.
Word of caution, these simple all-in-one water cooling solutions that come pre-packaged and clamp on to the CPU/back plane (like the Domino A.L.C.) are not real water cooling and do not perform any better than a high end air cooler.
__________________
".. an ounce of honest data is worth a pound of marketing hype." - Spec.Org
10-18-2009, 08:39 AM
#6
Thanks guys, ya i mean i have a list of the good products for WCing , i will get it setup next month or so then
10-18-2009, 08:50 AM
#7
Two points: water cooling is point cooling (ie only cools where there are water blacks) but air cooling is general. You will need some air cooling on a WC rig.
Done properly WC is a lot quieter than air cooling
10-18-2009, 09:51 AM
#8
Silence is by far the best feature imo. It allows you the capability of pushing your system as hard as you'd like, beyond air, without running fans that sound like turbines at 3000+ rpm or opening up the case and putting a box fan in front. It's efficient and allows a lot of flexibility
And as previously stated it does look cool. The con is that it can get expensive depending on what you do and it's addicting as hell. It's also significantly more effort. You can't just throw together a system in an hour anymore. Also, you'll start with a cpu only box and then end up throwing blocks on everything, then you'll start buying more blocks, then the newest blocks, more radiators, hacking up cases for the new radiators, sleeving psus, watercooling the ps3 and the xbox and then spend the rest of your time trying to figure out how to do it better. Definitely a can of worms. (or maybe I'm just a bit obsessive, but then it seems I'm in the right place)
For a starter, cpu only system, the swiftech kits contain good components and are easier on the wallet. Others may disagree and they're not top performers, but I think they're great and I have a water block/pump combo with a 120 rad/res combo on an htpc in my living room. Also on the cheap and simple side, it's also hard to beat an enzotech saphire+DDC350+EKtop+MCR220 and T-line with fill port.
Eventually, if you go down this road, you'll have a block on your ram, I'm not there yet, and I don't know why'd you'd do it, but I have every bit of confidence that eventually I'll have one. Again, maybe this is just me.
__________________
upgrading...
10-18-2009, 09:54 AM
#9
block your cpu and gpu/s and get some low rpm fans and bam, silence, much cooler then air and much cooler looking.
What more do you need? ^^
__________________
"If we hit that bullseye, the rest of the dominos will fall like a house of cards. Checkmate."
10-18-2009, 10:12 AM
#10
I would run that list by us
I'd hate to see you end up with a TT system.
10-18-2009, 10:20 AM
#11
Well i forget who it was on here that gave me a sweet setup, it was pretty much the best, i was suggested to run 2 rads 1 for the cpu and 1 for the graphics card. Then run a nice reservoir with dual pumps and to go with distilled water setup.I will get the list here in just a sec
10-18-2009, 10:24 AM
#12
dual loops with 2 DDCs and a XSPC dual bay res. Use a 120x3 rad for your cpu and a 120x2 for your GPU. <--- Millertime gave me this info and i forget the companies name that makes the more effeciant rads that requie low rpm fans but those would be the ones i would run. I have the Koolance WC block already for my graphics card sitting here.
10-18-2009, 10:41 AM
#13
Xtreme Fan
Just wanted to comment on this, as it's popped up a couple of times lately. Some radiators perform "better" with low RPM fans than other radiators - doesn't mean they need to be used with low RPM fans. You can generally improve your cooling performance by putting higher speed fans on your radiator (totally depends on your desire for noise/performance).
Check out the reviews in the sticky for Information/Guides to Liquid Cooling at the top of the page - there you can look at the data provided by HESmelaugh and skinnee to see how different radiator/fan combos.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
10-18-2009, 11:08 AM
#14
Xtreme Guru
+1
Swiftech, XSPC, TFC, TC, and HWlabs SR1s all work well with low RPM fans, but it doesn't mean you can't use higher speed fans on them.
The HWLabs high FPI rads work fine with slower fans, but will work better with higher speed fans compared to lower FPI rads.
Also, careful with the comparision between water-cooled and air-cooled temps. There are a lot of variables involved in getting low temps.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-18-2009, 11:59 AM
#15
Yes miller will do..
10-18-2009, 01:02 PM
#16
By chance I did some testing this weekend regarding air vs. liquid:
http://www.hardwareluxx.de/community...d.php?t=653427
If necessary use a translating tool, but I hope facts are clear enough in german language, too:
10-18-2009, 04:05 PM
#17
Ya i see that, not bad at all
10-18-2009, 07:06 PM
#18
Zombie Assassin
It's kinda hard to justify in some cases, like mine. I run a 720BE fully passive air on a mugen II, so it wins in the silence category, and it wins in the price category.
My chip tops out at 3.8-ish regardless of cooling, so it's a waste for me... if I had a golden chip or better binned chip such as a 965, I would probably have it under liquid.
__________________
i5 750
Asus Maximus III Gene
Patriot Viper II Sector 5 DDR3-1600 4Gb
XFX 5850 1Gb
Antec NSK3480/Seasonic SS-500HT
10-18-2009, 08:24 PM
#19
Well me and Miller just went on a rampage and bought 95% of everything lol... Good way to spend about 700 bucks in 1 night
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
