Here is a pic: no fancy tubing or any hard corners, pump is @ full speed (5)
Should the temps be this high??
Edit: There are 0 air bubbles, flow is very nice, the system is clean i am pretty sure, because i did have air before, tapped the rad etc, tilted the case and everything, and then it all became clean solid flow.
system is running for about 2 weeks now 24/7. with a bit of turning off sometimes.
So you think these temps are good? for i7 at just 1.25V? Don't forget, nothing else is hooked up to the loop, just the cpu, and air flow is very good .
Edit: and check this out, from another thread below:
Originally Posted by Johnmark
i7920 4.2Mhz @ 1.38v, the rest is in my sig.
Rad mounted inside on the top of the case, and I have the side panel off right now.
At idle ambient air in the case is 22c, Res. water temp. is 24.5c, CPU cores are 37,37,40,40 and CPU is 28c.
This isn't much better than the fusion v2 I stuck on in the first place.
The rad fans are turned way down so I can get the water much cooler.
Under load and water at 25c temps are around 67c
res>cpu>nb>gpu>rad>res
he is running the i7 at way more volts, and his loop has NB and GPU as well
true he is running a thicker feser 360 :\
there is room for improvement....
1. remount..it could be a bad mount
2. increase fans...increase noise
3 increase rads...increase noise coz you need fans
but the temps on the i7 has been above 60C with ht on. thats with water..and abit of oc
Yes HT is on. Also, what do you mean by bad mount? like the placing??
Sounds maybe just a tad on the high side, but actually looks pretty good to me, escpecially since you are running relatively low speed fans. Nice OC at 1.25 Vcore.
Can't quite figure out how your fans are setup. You're pushing air from the outside to the radiator? And then how is the air being exhausted? Have you tried running with all sides and top off the computer? I know you said you have good airflow, but it's hard to see just where the air is flowing in your photo.
Yeah got more pics:
This is the back side of the case:
So basically its that, on top of the case are 2 x 140mm low rpm fans, sorry i cant take pics, camera is not here
oh and thanks for the OC
Air is sucked in from outside, pushed through the radiator into the case, then sucked out by those 2 x 140mm fans, up from top.
Also about that fan speed, everybody said to get low RPM fans because they are the best with the MCR320.
My setup is in my sig. Using an MCP655-B with a Primochill Typhoon III, CPU subloop is MCR320 with Scythe S-Flex's ("F" models) at about 4-5V (minimum starting using various resistors soldered inline - fan controller coming soon), EK-Supreme, mobo (and VGA loop when I get the block from Eddy) subloop is 2* MCR120 with the same fans, EK-FC Classified mobo block. Temps are at mid-40s at idle, high 60s at load, using 1.3V for 3.4GHz (I have the worst 920 ever). When I used to be running 3.8GHz out of this chip, 1.4V was required, and I had to turn the fans up to a full 12V - load temps were high 60s again.
So yes, these chips run damn toasty, but they can take it - I value silence, so my fans are at the moment weaker than a gnat's fart, but that's enough airflow to keep things under control.
__________________
Rig specs
CPU: i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64 Liquid-cooled
Sub-loop One: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III Peripherals
-=- Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
A bad mount is when you either put down too much TIM or not enough. Also the TIM may have not set properly. I recall guys haveing that issue with the MX-3.
Also you may not have tightened the block down properly. Seeing you are running a GTZ, I doubt that is the problem.
What TIM did you use? You could also try switching your fans to a pull config. According to Martian's test, slower fans did work a bit better in pull.
Overall, your temps don't look bad. Doing all that might only net you a degree or 2, so its up to you if that is worth it to you.
Temps seems normal to me...there might be some small room for improvement though. I see your GTZ isn't mounted properly, it should be rotated 90 degrees counter clockwise according to the directions.
Yeah got more pics:
Just a bit off topic, but are those shrouds on the top of your case? If so are they aftermarket or did they come with the case?
On subject, I had an MCR220 with some good 1200 rpm fans. When I put the GT 1850's on it made a HUGE difference (several deg.), granted that little rad was loaded up pretty good.
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
Yea, those shrouds are stock with the case (Xclio 1000, check it out, real huge case + very cheap).
The GT's are Scythe GentleTyphoons. They push more air and are quieter at the same time, however the 1850s are out of stock everywhere right now. There should be more coming to retailers in a few weeks. The next fastest are 1450s and are readily available if you want to give them a try, but I'm not sure there will be a significant change over your 1200s.
misho: Why do have dog nail clippers in your case?
I have Kind of similar setup, MCP655 + GTX360 rad, 1/2" Tygon tubing, Apogee GTX, 3x Silverstone FM121 fans.
CPU is running 4.2GHz and HT on, 1.365V Vcore, idling at 42-46C (ambient 24-30C), 24/7 WCG load on all cores = 78 - 86C.
