XtremeSystems Forums
Reply
Old 10-17-2009, 08:14 PM   #1
dingdong555
Send a message via MSN to dingdong555
Nulon Ultra Cool or Nulon Long Life?
Hey guys.
Got some of the radiator coolant, I've seen it used before but I can't remember if it was Long life (Anti-Freeze/Anti-Boil) or Ultra Cool (NON - Anti-Freeze/Anti-Boil), I got some Ultra cool the other day, I must say, the green is WICKED!!!
I'm just not sure which one to use?
Ultra Cool - http://www.nulon.com.au/products/Ultra_Cool/
Long Life - http://www.nulon.com.au/products/Lon...rated_Coolant/
The awesomeness.
dingdong555 is online now   Reply With Quote
Old 10-17-2009, 10:12 PM   #2
nipper575
nipper575's Avatar
I use ultra cool in my loop. I came to using it after reading countless threads where it kept on coming up. It's not an anti-freeze, but a radiator treatment to stop corrosion if my memory serves me. I've used it for > 12 months and have not had any sort of gunk build up in the block at all. I mixed it as per the bottle instructions which I think was a 5% mix.
The long life product is an anti - freeze/boil which is not needed in a regular WC loop imo.
If you like the colour, you'd probably also be pleased to know that the nulon ultra cool is also UV reactive.
__________________
~ Core i7 940 @ 4.00 ~ Gigabyte EX58-Extreme ~ Patriot Viper Series DDR3 6GB 1600 ~ Gigabyte GTX 260 SLi ~ Swiftech Apogee XT ~
nipper575 is offline   Reply With Quote
Old 10-17-2009, 10:45 PM   #3
dingdong555
Thanks mate, yeah, I saw it was UV reactive when I tested it, looks like an awesome coolant! Cheers.
Old 10-17-2009, 11:16 PM   #4
Hondacity
don't use near kids or pets
__________________
Hondacity is online now   Reply With Quote
Old 10-18-2009, 03:10 AM   #5
nipper575
nipper575's Avatar
haha, looks like lime cordial.
Probably won't have many on this forum knowing of mixing Nulon with distilled in their loops as it is an Australian product, not too many Aussie's on here afaik, you'd get more of a response over at the OCAU.
Edit: Wasn't aware you had started building a second system, I will have to check out the build log, I rated your last system highly.
__________________
Old 10-18-2009, 03:20 AM   #6
dingdong555
Thanks mate!!!
No new build log yet as It'll be a couple of weeks away
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
