XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-17-2009, 10:04 AM   #1
nullface
Stock Lian Li fan's?
So i got a A05N, a realy nice little case, but i am wondering if it is worth it to change the stock Lian Li (LI121225SL-4) fans to my Noctua S12's?
I cant realy find any good info about the LI121225SL-4.
__________________
E8400 @ 425x9 1.168V
4GB D9MGH Mix (4x1GB) @ 510MHz 5-5-5-15 2.05V
HD4850 @ 730/1070
BFBC2 Beta
Addicted to dog tags!
nullface is online now   Reply With Quote
Old 10-20-2009, 02:27 PM   #2
64dragon
Xtreme Cruncher
64dragon's Avatar
Send a message via AIM to 64dragon
i believe they are the same ones that came with my v1200 (don't have them in or here at my gf's place) but i did find specs in the past. if i remember correctly, they are around 58cfm and 25dba. maybe it was just the way i had them setup in my case but i thought they were a little loud. i prefer my scythe s-flex f's
__________________
XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.9ghz @1.32v under load, corsair dominator ddr2 1066 4gigs, evga gtx260 core 216, pc p&c 750W, TRUE Black, Lian Li v1200b
silverstone tj07 build log
64dragon is offline   Reply With Quote
Old 10-20-2009, 04:48 PM   #3
Laine
Laine's Avatar
Send a message via MSN to Laine
Last time I checked, stock Lian Li fans are rebranded Adda fans.
I don't recall the additional name of the Adda so I'm not much help, sorry.
__________________
LianLi V1000
LC Worklog: Project Crystal Clear
LianLi A05
LC Worklog: Project Simplicity
Laine is offline   Reply With Quote
Old 10-20-2009, 07:24 PM   #4
Ar3s
Ar3s's Avatar
Send a message via Skype™ to Ar3s
Long ago they used to be rebranded ADDA fans but not after they started reducing their cost.
__________________
Everyday is a NiceDay
Ar3s is offline   Reply With Quote
Old 10-20-2009, 10:55 PM   #5
desnudopenguino
desnudopenguino's Avatar
The Lian-Li case fans are a little weak in my opinion, but I got the A70 case (came with 6 case fans), and that monster needed more air flow than they provided. It might be worth it to try them out. http://www.lian-li.com/v2/en/product...s_index=82&g=f Here's the current fans that are stock in Lian Li cases (or at least what I got in mine this summer).
desnudopenguino is offline   Reply With Quote
Old 10-20-2009, 11:07 PM   #6
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
While the stock Lian-Li fans are a bit low in flow and pressure for my tastes, they are high quality fans - dual ball bearing and pretty quiet considering you get them included with the case
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 10-22-2009, 10:53 PM   #7
PaRn ssR
PaRn ssR's Avatar
Send a message via MSN to PaRn ssR
+1
__________________
  • Core i5 750
  • ASUS Maximus III Gene
  • Kingston HyperX 4GB/1600
  • ASUS ENGTX275
  • WD1500HLFS, 2500AAKS, 2500YS, 2x 5000AADS
  • Thermaltake Toughpower 750W
  • Lian Li PC-V1110B
  • Dell 2208WFP
  • X-Fi Xtreme Music
  • Klipsch ProMedia 2.1 THX
  • Prolimatech Mega Shadow
  • SilverStone FM123
PaRn ssR is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
