I just bought a Swiftech MCP-655 (vario) one month ago. When I first build the rig, I didn't take it apart as it was working fine.
Today, I had to take my loop apart as I had algae in my loop. I have also taken the block apart and the pump to clean it inside. It was actually not too bad as I think the algae mostly grew in the tube where it found light.
Anyway, the problem when I open the pump is that the magnetic thing (half ball) inside (sorry, I don't know the name) seems to have taken a small hit.
* click on the picture for high resolutions *
It looks more like chipped paint, except for the black circle part where there is a little dent in it.
Is it bad ?
Could be due to the fact that I have made a bracket to hold the pump with the inlet up and the outlet on the side ?
The pump was slightly tilted as it was removing some stress on the tubing (see picture).
I have read the manual and did some research on internet and it seems the pump orientation doesn't matter right ?
If it is the case, it means it is a defect of fabrication I guess. It looks like it also because in the outer part of the pump, there is no mark at all. Th problem is I am staying in Malaysia, and shipping the pump back for RMA will cost me almost half the price of the pump, so if this doesn't affect the reliability of the pump I can leave it with it ...
Please let me know what you think
