XtremeSystems Forums
Reply
Old 10-17-2009, 07:27 AM   #1
rampton
Dehumidifier water?
Does anyone know if water from a dehumidifier would do as coolant with a silver coil in it as biocide?
I'm having difficulty getting distilled water in the UK without paying £3 a litre for it mail order. I could get deionized but that's "bad" for copper, isn't it?
I'm not a chemist and I've not tried it, just wondered if it was a poor idea, heh.
rampton is offline   Reply With Quote
Old 10-17-2009, 08:14 AM   #2
Conumdrum
Conumdrum's Avatar
Deionized is used in the UK for waterloops. It's just fine.
__________________
All stock for now
i7 965 ES D0 step
Corsair 1600 6 gig
GTX 280 x 2
Giga Xtreme mobo
Two 120x3 loops
DDC3.2 XSPC restops
XSPC 360RX and PA120.3 Rads
GTZ CPU and Tieton GPU blocks
Banchetto Tech Station
And the rest of the normal stuff
Conumdrum is offline   Reply With Quote
Old 10-17-2009, 10:04 AM   #3
dejanh
I am Xtreme
dejanh's Avatar
That would be some pretty dirty water on a microscopic level I'm sure so I doubt that the silver would help much over time...
dejanh is online now   Reply With Quote
Old 10-17-2009, 10:07 AM   #4
millertime359
Xtreme Guru
millertime359's Avatar
+1 I would use the deionized water.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-17-2009, 10:20 AM   #5
Mankz_91
Mankz_91's Avatar
Dude, a gallon of distilled is like £2 at Halfords, they call it battery top up water or something
__________________
Watery!
Mankz_91 is offline   Reply With Quote
Old 10-17-2009, 12:37 PM   #6
brammers
brammers's Avatar
I'm pretty sure the Halfords stuff is Deionised.
J
brammers is offline   Reply With Quote
Old 10-17-2009, 12:44 PM   #7
Ghost326267
Ghost326267's Avatar
Send a message via MSN to Ghost326267
J
Yeah it is. Haven't actually seen distilled water in the UK myself. Been using deionised water ever since I've been water cooling and never had a problem with it.
__________________
Intel I7 940 @4Ghz - water cooled
Corsair Domitator 12800 12GB
Asus Rampage II Extreme
HIS ATI HD 4870X2 - water cooled
Creative X-fi Xtreme Gamer Fatal1ty
Enermax Galaxy 1000W
3x Samsung F1 500GB HDD
OCZ Vertex 120GB
TJ07 Murdermod
LG W3000H 30" Monitor
Vista Home Premium x64
Ghost326267 is offline   Reply With Quote
Old 10-17-2009, 12:53 PM   #8
brammers
brammers's Avatar
Proper distilled is rare as hen's teeth.
www.sortlifeout.co.uk carry it - but it's about £20 a gallon!
I use Halfords stuff for flushing, rinsing etc, and the final fill with distilled.
J
Old 10-17-2009, 01:13 PM   #9
fallwind
Xtreme Cruncher
fallwind's Avatar
Dehumidifier water will be full of dust and bacteria, don't use it. Can't you guys get reverse osmosis drinking water? I've used it plenty of times and it works fine. It's not quite as pure as steam distilled but over 99% of the junk in the water will have been removed.
__________________
Gulftown@4200Mhz 1.360v
Gigabyte EX58-UD3R F8D
3x2GB Dominator GT 1600MHz 6-7-6-18 1T
BFG 8800GTX OC 640/1000 EK full-coverage WB
Windows 7 Ultimate x64
HK 3.0-MCP655-Massive car rad!
X-FI XtremeGamer
Silverstone Strider 850w
120GB OCZ Vertex - OS
2.5TB storage
TT Armor VA8003SWA
fallwind is offline   Reply With Quote
Old 10-17-2009, 01:25 PM   #10
OldChap
iCrunch iFold iGrid
OldChap's Avatar
It's about time one of us put together a cheap design for making this stuff...surely it can't be so difficult......I heard people living out in the woods do it all the time
__________________
9 cards Folding, 14cores Crunching
I think sex is better than logic, but I can't prove it.
I have kleptomania, but when it gets bad, I take something for it.
OldChap is offline   Reply With Quote
Old 10-17-2009, 01:39 PM   #11
rampton
Ok, so dehumidifier water : bad juju.
I'm just stunned no-one sells it. Walmart sells gallon containers of it but clearly that's not been transferred to Asda
Will the deionized eat my radiator? It's a 120.4; I think the tanks are brass but the pipes are copper.
Old 10-17-2009, 01:49 PM   #12
eponymous
eponymous's Avatar
You'll be fine with de-ionized.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 10-17-2009, 01:56 PM   #13
Johnmark
No. Deionized water is a bit misnomer. It would be better though of as demineralized water. Once it comes out of Cation/Anion unit it has the same ions it did when it went into it. In the unit the ions are exchanged causing the solids to drop out, when it comes out of the unit it's as safe as any other water. It just has VERY little solids left. Conductivity (amount of solids) of good demin water vs distilled is pretty much the same.
On the other hand if you tested the conductivity of dehumidifier water it would be off the chart HIGH containing all kinds of solids and crud.
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
Johnmark is offline   Reply With Quote
Old 10-17-2009, 06:10 PM   #14
JargonGR
It is funny that you can't find distilled in the UK when I can find it in Greece. However, I am using Water For Injection from any pharmacy store and I get it dirt cheap about 1 Euro per liter. It is actually many times distilled (8 I think) and I have never seen algae in it in my loops.
__________________
Hardware :Asus Rampage Extreme, 4870X2 (Crossfire X) EK FC Blocks, CPU Q9550@490FSB/4,180Ghz, RAM 4GB DDR3, Auzentech Prelude X-fi,PSU - Thermaltake Toughpower 1200 Watt,
3 Loops with TFCs360 and a PA.120.2/DDCs.
JargonGR is offline   Reply With Quote
Old 10-17-2009, 07:22 PM   #15
shazza
Xtreme Fan
shazza's Avatar
De-ionized will be fine.
If you run a search for distilled water here, you'll probably find a ton of threads ... it's a discussion that comes up at least once a month. It's interesting that distilled is so readily available in the US, but not in the UK. Wonder why??? I know one of the main reasons people in the US used to use distilled water was for steam irons - but can't believe that many people still iron their clothes!
Good luck with your project, rampton - and we'd love to see some pics or a work log!
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Old 10-17-2009, 08:17 PM   #16
zanzabar
I am Xtreme
zanzabar's Avatar
people in the UK dont iron their clothes ?
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
zanzabar is online now   Reply With Quote
Old 10-17-2009, 09:56 PM   #17
Equinediver
Equinediver's Avatar
Honestly can't see people buying distilled water just for their irons. We always just use tap water & iron is still going 5 yrs on. Well hubby irons, I always try to get stuff out the dryer in time, so it doesn't need ironing......I will always try and find something to wear that doesn't need ironing
Water quality in the UK is WAY better than here. When we 1st moved here we were on well water, everything smelt of sulphur Once we got city water I though great, no need for bottled water any longer. We both noticed the coffee tasting nasty, was about to complain to Costco, when a friend asked if we were using city water........need I say more?
What we get here in the US, labelled as distilled water is just the same as what you buy in the UK to fill your battery up. Actually, the UK stuff is probably purer
__________________
i7 975 EVGA X58 Classified 6Gb Corsair Dominator GT 2 x EVGA 285 FTW 2x 300Gb Velociraptor in RAID 0 WD Black 500Gb
WC loop 1: HK 3.0 Fesser 360 BP VREG BP NB D5 pump
loop 2: 2 x EVGA HC's Fesser 240 D5 pump
Equinediver is offline   Reply With Quote
Old 10-17-2009, 10:39 PM   #18
Waterlogged
I am Xtreme
Waterlogged's Avatar
Distilled water in the UK.
http://www.farmchem.co.uk/deionised-...tres-121-p.asp
__________________
Waterlogged is offline   Reply With Quote
Old 10-18-2009, 03:01 AM   #19
Jamesrt2004
Xtreme Mentor
Jamesrt2004's Avatar
Send a message via MSN to Jamesrt2004
Originally Posted by Waterlogged View Post
£9!! for water HATE THE UK
__________________
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
Jamesrt2004 is online now   Reply With Quote
Old 10-18-2009, 03:29 AM   #20
slamz
slamz's Avatar
Its like £2.99 or something for £5 litres of the stuff at halfords. How many more people have to say this?
__________________
Originally Posted by nikhsub1 View Post
Unfortunately some think that having uber high flow rates will increase the size of their penis.
slamz is offline   Reply With Quote
Old 10-18-2009, 09:03 AM   #21
shazza
Xtreme Fan
shazza's Avatar
I think the question with the Halford's water is whether it is distilled or de-ionized (which will still work fine). If it's distilled, that's great.
Been thinking about this question of why we can buy distilled at stores so easily in the US. One thing I noticed is that it is virtually everywhere here in Phoenix, AZ, but I remember having a heck of a time finding it in South Florida (actually used battery/de-ionized water for my first build). Is it that there are many more people using humidifiers in the hot dry climate?
And following equinediver's point about water quality in the US vs UK, found this comment about Distilled Water Usage:
Cooking is the most important distilled water use apart from drinking. Cooking which is done by distilled water is generally free from any harmful elements. Distilled water use is also recommended while making baby foods because babies are very sensitive to water borne diseases.
(No coffee yet, so apologies for my rambling - better used some of my distilled to make a fresh pot)
__________________
Old 10-18-2009, 10:06 AM   #22
meanmoe
do you guys have nursery water? I think that may be distilled.
get a worm and 'still you some water on the stove.
__________________
upgrading...
meanmoe is offline   Reply With Quote
Old 10-18-2009, 10:48 AM   #23
slamz
slamz's Avatar
It's de-ionised battery top up water (i know, i work there )
__________________
Old 10-18-2009, 12:05 PM   #24
Johnmark
It is intriguing to me that the Pharmacies don't carry distilled water for just the reason shazza pointed out. Some babies need it (I needed it, my son needed it), so where would you go to get it in the UK. Here in Canada pretty much every Pharmacy carries it in at least 1 gallon jugs.
P.S. Never drink demin water. Stong acid and casutic is used for the regeneration of the beds. It does happen that a valve fails and dumps some caustic/acid into the water.
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
Old 10-19-2009, 03:51 AM   #25
markpg28
markpg28's Avatar
You can get it in most Chemists
markpg28 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
