XtremeSystems Forums
Reply
Old 10-17-2009, 06:47 AM   #1
dantrona
Newb to Liquid Cooling
Hey there guys, So, I am pricing out this computer and originally when I thought out the computer in my head, I told myself "I am going to only do Air Cooling!" so I built this computer for air cooling, super effecient, massive heatsync. The build will be in this post. This will be my first computer build ever and the deadline is about December 1-2 so I have time to order it, put it together, and put it under the tree with a nice big bow on top!
What I would like to know, is if I choose the Watercooling route, What sort of upkeep do I need to do? A daily checklist for example, what I should look out for, If there is a specific kit I should get or if you could suggest parts (Including clamps, fans, radiators, ect) that I can buy seperately that will be very effecient.
My budget is $2000.
Case x1 [Total Price: 159.99] Antec Twelve Hundred
http://www.newegg.com/Product/Produc...82E16811129043
Processor x1 [Total Price: 199.99] Intel i7 920
http://microcenter.com/single_produc...uct_id=0302727
Motherboard x1 [Total Price: 299.99] EVGA E758-A1
http://www.newegg.com/Product/Produc...82E16813188039
Ram x1 [Total Price: 184.99] Mushkin 6-7-6-18 DDR3 1600
http://www.newegg.com/Product/Produc...82E16820226050
Video Card x1 [Total Price: 389.99] XFX HD5870
http://www.newegg.com/Product/Produc...82E16814150443
Hard Drive1 x1 [Total Price: $289.00] Intel x25 G2
http://www.newegg.com/Product/Produc...82E16820167016
Hard Drive2 x1 [Total Price: $74.99] Samsung Spinpoint F3
http://www.newegg.com/Product/Produc...82E16822152185
CD-Drive x1 [Total Price: $32.99] Don't worry about it
http://www.newegg.com/Product/Produc...82E16827118030
Power Supply x1 [Total Price: $119.99] Antec CP-850
http://www.newegg.com/Product/Produc...82E16817371024
Heat Sink x1 [Total Price: $62.95] Prolimatech Megahalem
http://www.jab-tech.com/Prolimatech-...B-pr-4557.html
CPU Fan x2 [Total Price: $7.20] Yate Loon 120mm High-Speed Fan (88 CFM@ 40DB)
http://www.jab-tech.com/YATE-LOON-12...d-pr-3771.html
Thermal Compound x1 [Total Price: $19.95] Indigo Extreme for i7
http://www.jab-tech.com/Indigo-Xtrem...6-pr-4544.html
Total added up: $1802.02
Thank you in advance for your suggestions and help.
If you guys don't think I should do Liquid Cooling, please don't just not reply, say so!
dantrona is offline   Reply With Quote
Old 10-17-2009, 06:50 AM   #2
jadeskye
jadeskye's Avatar
There is no 'daily checklist' so to speak, Once it's set up it's usually good for months at a time (a year or so) then usually all you need is a water top up or a drain then top up.
If it's done right, then the maintenence is very little.
As for parts generally you'll want to avoid kits, they're not very high quality generally although there are exceptions. In general a CPU block, such as the heatkiller, Radiator, pump and some form of reservoir or T-line is all you need.
__________________
"If we hit that bullseye, the rest of the dominos will fall like a house of cards. Checkmate."
jadeskye is offline   Reply With Quote
Old 10-17-2009, 06:52 AM   #3
Caoder
Caoder's Avatar
Send a message via MSN to Caoder
eh.. 200 for a decent liquid system's a bit tight.......also don't but a premade system custom is just about the only way to go
Caoder is offline   Reply With Quote
Old 10-17-2009, 07:00 AM   #4
dantrona
If course, It would be more room without the $63 heatsync. so think more $260 ish, What about the Swiftech H20-22- Apex Ultima ? I have a buddy that has one of those and likes it, I would also like to be quoted a decent list, I'll probably have more room to play with after Black Friday as well, so lets say budget is $2050?
Old 10-17-2009, 07:30 AM   #5
jadeskye
jadeskye's Avatar
i'm assuming you only want to cool the cpu. I'm not american so i don't know prices in dollars so i apologise if i'm over your budget ^_^
Generally the accepted components are
The Laing DDC pump (with a top)
Heatkiller Rev. 3 CPU block
1/2 inch inner diameter tubing
Radiators are still split alot, personally i use thermochill PA series rads (for just the cpu you could possibly get away with a single 120mm rad but you might want a double 240mm just to be sure).
this is all subject to opinion and requirements of course but i personally wouldn't settle for anything less.
__________________
Old 10-17-2009, 07:39 AM   #6
dingdong555
Send a message via MSN to dingdong555
All prices from www.jab-tech.com
Swiftech Apogee GTZ Extreme Performance CPU Waterblock - Core i7
XSPC RX360 - Triple 120mm high performance radiator
Swiftech MCP 355 12v DC Pump
XSPC - Acrylic Reservoir for Laing DDC
8x PrimoFlex Pro LRT UV Blue Tubing - 7/16in. ID X 5/8in. OD - Colour as a price reference only, you can choose whatever you want aslong as it's the same size, this will be a tight fit over the 1/2" barbs so no clamps are needed.
6x Bitspower True Silver G1/4 High Flow 1/2" Barb - BP-SLWP-C01 Will stop growth in your loop.
3x YATE LOON 120mm Case Fan - D12SL-12
Total: $292.20 ex. Shipping (Starts from $10 in the US for 3 days)
dingdong555 is offline   Reply With Quote
Old 10-17-2009, 07:42 AM   #7
dantrona
What barb size do I want? 1/2" plastic? 3/8" plastic? 1/2" EK barb? or 3/8" EK barb?
Edit://
I love your suggestions Dingdong555, that pushes the build to $2031.27 which I can cut down to allow the price to happen, I will definately be looking at that as a possibility. What sort of temps do you think I would be able to achieve?
Old 10-17-2009, 07:46 AM   #8
dingdong555
Edit://
VERY VERY good temps, especially since you're only running the CPU under water. I can't tell you exact temps but if you're not overclocking expect to be BLOWN away by the results
Old 10-17-2009, 07:50 AM   #9
jadeskye
jadeskye's Avatar
Thats a very economical, yet high performance set up there dingdong, i approve!
__________________
Old 10-17-2009, 07:55 AM   #10
dantrona
Hmm.. now, how to shave off $35... Perhaps get a different case that supports liquid cooling since I don't need all that much air cooling anymore, What do you guys think about the Xclio Blackhawk ?
Old 10-17-2009, 08:01 AM   #11
Vapor
Admin
Vapor's Avatar
You can get your SSD from mwave...$240 iirc.
Or you can move to an MCR320 radiator, it's $43 less, but roughly the same performance: http://www.jab-tech.com/Swiftech-MCR...r-pr-3320.html
EDIT: if you do both, you can go to the Apogee XT waterblock, which is even better than the GTZ
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 10-17-2009, 08:03 AM   #12
dingdong555
Looking through your hardware list, I'd change a few things
Change the motherboard to a newer version - EVGA SLI LE $239
Change the Power Supply to a Corsair (top quality + more reliable) - Corsair HX750watt $169
Change the case to one that can handle a triple radiator internally with NO modding - Coolermaster HAF RC932 $139
Change the Thermal paste, why pay $19 for something when you can pay $5 for a TUBE of paste that does the same thing? (Maybe 1*C less efficient!) - http://www.jab-tech.com/Arctic-Cooli...d-pr-3863.html $5
Old 10-17-2009, 08:13 AM   #13
dantrona
Does that Mobo support Xfire? I don't see anything about it inside of the specs, only SLI.
The only reason I picked the power supply is it is suppost to be one of the best 850 watt PSU's around, and it fits in the Antec, My previous choice was the Corsair 850TX Which I will revert back to.
I personally don't mind having the radiator on the back, it just is kinda one of those things where its like "Woah, thats a high preformance computer! look at the tubes!" Where would I put the radiator in the Haf? I can't see anywhere to put it except for laying on its back behind the PSU.
The reason I went with the $20 stuff is I read several reviews that submitted the same info, The thermal unit there is significantly cooler than even shin-etsu, here is a review right off the top of my head by Vapor himself (Hi vapor! <3 the review!) http://www.xtremesystems.org/forums/...d.php?t=232141
Old 10-17-2009, 08:19 AM   #14
Conumdrum
Conumdrum's Avatar
It's the Corsair HX series, not the TX series that is great.
A good place for PSU reviews is here:
http://www.jonnyguru.com/
And since you jumping in this so quickly and asking about barbs which is usually understood already, you should step back and read here for a while, all the guides etc.
http://www.tomshardware.com/forum/25...rcooling-guide
__________________
All stock for now
i7 965 ES D0 step
Corsair 1600 6 gig
GTX 280 x 2
Giga Xtreme mobo
Two 120x3 loops
DDC3.2 XSPC restops
XSPC 360RX and PA120.3 Rads
GTZ CPU and Tieton GPU blocks
Banchetto Tech Station
And the rest of the normal stuff
Conumdrum is offline   Reply With Quote
Old 10-17-2009, 08:22 AM   #15
dantrona
That is baisically what this thread is for, I need info on some of the lingo, I will definately be reading your thread Conumdrum. I was just trying to get price and didn't know what is an optimal size for a build like mine.
Old 10-17-2009, 08:26 AM   #16
Conumdrum
Conumdrum's Avatar
Good! Once you understand the lingo and the basics in wattage and flow rates (don't have to be a scientist to figure it out) then you'll be ready to start selecting parts. And you won't have to ask so many questions.
The fancy Tpaste is really nice, but you'd be better served with a tube of MX-2 for now. Don't need any complexities for the first WC build.
__________________
All stock for now
i7 965 ES D0 step
Corsair 1600 6 gig
GTX 280 x 2
Giga Xtreme mobo
Two 120x3 loops
DDC3.2 XSPC restops
Old 10-17-2009, 08:30 AM   #17
dantrona
Okay, I'll do that then, I would like my HAF question answered, or another case suggested so I can start planning out placement for things.
Old 10-17-2009, 08:54 AM   #18
RADCOM
Xtreme Waterbaby
RADCOM's Avatar
Artique ceramique TIM is good quality,cheap and easy to use. You should have a very nice system with revised spec above. be warned water cooling is addictive and will cost you a fortune in the long run lol
__________________
Respec'
System:Bunch of crappy overclocked PC's that cost an arm and a leg
"A Caesarean Milks Stops Wort"-anagram
RADCOM is offline   Reply With Quote
Old 10-17-2009, 09:04 AM   #19
dantrona
Where can I buy the Apogee XT? Swiftech dosn't have it on their website store.. After that i'll post up a new list.
Old 10-17-2009, 09:04 AM   #20
M.Fixit
dantrona,
It fits in the top of the case (the mounting holes are already there for it) in place of the 230mm fan that is there (which you have to remove). I have this set up - it was my first w/c build too. For the rest see my sig. Temps at 4.2GHz and LinX are sub 65 degC at 24 degC ambient. HK 3.0 or the Swiftech XT is the way to go.
__________________
Main Rig:
Intel Core i7 920 D0 @ 21 x 200 (4.2GHz) 24x7 / Gigabyte GA-EX58-UD5 / Seasonic 600W PSU / Sapphire HD 4870 Vapor-X / OCZ Intel i7 6GB (3x2GB) DDR3 PC3-10666 / Heatkiller 3.0 Cu mounted vertically, XSPC RX360, XSPC Res Top on Swiftech mpc355 / Coolermaster HAF 932 / Vista Home Premium x64
M.Fixit is offline   Reply With Quote
Old 10-17-2009, 09:18 AM   #21
dantrona
Originally Posted by M.Fixit View Post
dantrona,
Great! Any idea where I can -buy- a Swiftech XT? I'm gonna start looking a little harder for it now, And any word on that MOBO that dingdong555 suggested? I am guessing its not crossfire avail?
Old 10-17-2009, 09:30 AM   #22
M.Fixit
dantrona,
I suggest you check several recent threads in this forum. Its only available in the US so far, and then only just. Those of us in Europe will have to wait . Vapor is testing it so we will soon (hopefully) see if it is really better than the HK 3.0, and by how much (but probably only by ~1 degC).
I can't help with the mobo - I have Gigabyte UD5.
BTW - although the Indigo xtreme looks really good, you need to follow the re-flow process to the letter - see Vapor's review. So you will need to use another TIM first so you can get the OS installed. I am using Shin-Etsu X23-7783D - the next best TIM according to Vapor's results.
__________________
Main Rig:
Old 10-17-2009, 09:43 AM   #23
rmorse27
rmorse27's Avatar
I think you should get a higher rated power supply just for future upgrades.
__________________
Antec 1200 Case
E8500
Asus Rampage Formula
8 Gigs Mushkin 1066 Ram
2 x 640 Black WD Drives Raid 0
2 x Lightscribe Dvd Burners
2 x Ati 5870 xfire
EK 5870 Water Blocks
Corsair HX 1000 Watt Pws
Heatkiller 3.0 775 Water Block
Bitspower Nb/Sb Block
2 Xspc Dual Bay Pump/Res Combo
Xfi Sound Card
Black Ice 240mm Radiator
Antec 200mm Radiator
180mm Fan
rmorse27 is offline   Reply With Quote
Old 10-17-2009, 09:48 AM   #24
dantrona
Higher than 850??! I used to think about getting two 5870's and that would only come out to ~750 watts! I got rid of one, so I figured I should be more than fine to add in a Liquid Cooling system without upgrading it!
Also, Heres an updated list (Sorry, no names. Just a copy+paste of my document)
Case x1 [Total Price: $139.99] *Free Shipping*
http://www.newegg.com/Product/Produc...82E16811119160
Case Fan Color Change x1 [Total Price: $8.99]
http://www.newegg.com/Product/Produc...82E16835103060
Processor x1 [Total Price: $199.99] In-store pickup
Motherboard x1 [Total Price: $299.99] ($20 MIRB)*Free Shipping*
Ram x1 [Total Price: $184.99]
Video Card x1 [Total Price: $389.99]
Hard Drive1 x1 [Total Price: $289.00] *Free Shipping*
Hard Drive2 x1 [Total Price: $74.99]. *Free Shipping*
Power Supply x1 [Total Price: $139.99] ($30 MIRB)*Free Shipping*
http://www.newegg.com/Product/Produc...82E16817139009
Thermal Compound x1 [Total Price: $4.95]
CPU Waterblock x1 [Total Price: $89.99]
http://www.performance-pcs.com/catal...ducts_id=26480
Radiator x1 [Total Price: $51.95]
Pump x1 [Total Price: $64.95]
http://www.jab-tech.com/Swiftech-MCP...p-pr-3510.html
Reservoir x1 [Total Price: $39.95]
http://www.jab-tech.com/XSPC-Acrylic...C-pr-4123.html
Tubing x8 [Total Price: $14.80]
http://www.jab-tech.com/PrimoFlex-Pr...D-pr-4426.html
Barbs x6 [Total Price: $19.20]
http://www.jab-tech.com/Bitspower-Tr...1-pr-4397.html
Radiator Fans x3 [Total Price: $10.80]
http://www.jab-tech.com/YATE-LOON-12...2-pr-3009.html
$2057.50
-$ 50.00
$2007.50
so, $8 to shave off, Hmm.. I might be able to just ask for an $8 boost in budget
Old 10-17-2009, 09:59 AM   #25
M.Fixit
dantrona,
What is the Case Fan Color Change x1 for? The HAF has a 140mm fan at the rear (but you can fit a 120mm there).
You should go with the 850HX Corsair - http://www.newegg.com/Product/Produc...82E16817139011 - the TX is rubbish (in comparision - all the reviews say so).
The best fans for the rad are probably the Scythe Gentle Typhoons (1850 rpm) if you can get them (the 1450 rpms are OK too). Though you may want a fan controller to slow them down (more cost!).
__________________
Main Rig:
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
