XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 10-17-2009, 12:17 AM   #1
dexman
dexman's Avatar
Artic Silver 5. How many hours to settle in?
hi, i was wondering how many hours it takes for AS5 to settle in, so the cpu temp won't improve anymore.
dexman is offline   Reply With Quote
Old 10-17-2009, 12:25 AM   #2
zanzabar
I am Xtreme
zanzabar's Avatar
12-48hours
__________________
warning i use sarcasm, alot
coming soon duel dual rad p180 the reckoning, 720BE 0912epmw, gd70 and a new liquid revamp
give a man some juice and he has juice for a day, give him a juicer and he will have juice for life if he has something to juice
zanzabar is offline   Reply With Quote
Old 10-17-2009, 01:34 AM   #3
dexman
dexman's Avatar
thanks
Old 10-17-2009, 02:15 AM   #4
Bold Eagle
From their site:
http://www.arcticsilver.com/as5.htm
"Due to the unique shape and sizes of the particles in Arctic Silver 5's conductive matrix, it will take a up to 200 hours and several thermal cycles to achieve maximum particle to particle thermal conduction and for the heatsink to CPU interface to reach maximum conductivity."
So optimum thermal potential may take "upto 200 hours", you will see differences after 2-3 hours but!
Bold Eagle is offline   Reply With Quote
Old 10-17-2009, 09:13 AM   #5
Andrea deluxe
Andrea deluxe's Avatar
try this, and artic silver..... bye bye...
__________________
[My RIG Spec.][My RIG Photo][My CPU OC]
Andrea deluxe is offline   Reply With Quote
Old 10-17-2009, 09:30 AM   #6
dexman
dexman's Avatar
^^i think i'll finish my AS5 before moving to something else
200 hours is too long. i was asking because i want to compare two coolers, and i want to do it fair because one them is being used for long time. so i guess i will give the other one 48 hrs of burn in and call it a day
Old 10-17-2009, 10:32 AM   #7
rusty
Try Mx-2 /Mx-3 and zm stg-1 this bye bye
rusty is offline   Reply With Quote
Old 10-17-2009, 10:40 AM   #8
Andrea deluxe
__________________
Old 10-17-2009, 10:46 AM   #9
gatecrasherlok
gatecrasherlok's Avatar
Eww
__________________
EVGA X58 Classified
Intel Core i7 920 @ 3.8ghz
EVGA 295 GTX x2 Quad SLI (0.C)
Corsair Dominator DDR3 6GB PC3-12800C8
Western Digital 150 GB Velociraptor
Thermaltake Toughpower 1200 watt
Asus Xonar d2x
Prolimatech Megashadow(Push/Pull Config)
Lian Li Pc-P80 Armoursuit
Scythe Kaze Master Fan Control
Imon VFD Display and Control
gatecrasherlok is online now   Reply With Quote
Old 10-17-2009, 11:50 AM   #10
rusty
Originally Posted by gatecrasherlok View Post
Eww
wtf is that ? suggest something or don't say anything.
Old 10-17-2009, 11:53 AM   #11
gatecrasherlok
Eww referring to this suggestion being a no go and just for you Mx2, tried and tested being a great thermal compound. Oh and also try shinetsu too I've had some good results with them.
__________________
EVGA X58 Classified
Asus Xonar d2x
Old 10-17-2009, 02:29 PM   #12
zanzabar
I am Xtreme
zanzabar's Avatar
affter 12hours its normally as good as gets and its better than the zalman stuff when its fresh.
but get mx2 or mx3, they are better than as5. mx2 is easier to use but runs a little hotter
on a side note dont buy paste in a jar it will oxidize and degrade affter 1 or 2 uses
__________________
Old 10-17-2009, 04:25 PM   #13
rusty
how's mx-2 a no go ? mx-2 is one of the good TIMs out there. Zalman Tims temps are higher. Oh and shinetsu is kind of a mess after when you need to clean a cpu.
p.s.>
and the one to rule them all is Indigo Xtreme Thermal
Old 10-17-2009, 04:29 PM   #14
rusty
Old 10-17-2009, 04:54 PM   #15
zanzabar
I am Xtreme
zanzabar's Avatar
indigo is not exactly the same kind of thing, the indigo is made to adhere the HS and cpu together and u have to immediately burn it in or it wont work
__________________
Old 10-17-2009, 06:22 PM   #16
64dragon
Xtreme Cruncher
64dragon's Avatar
Send a message via AIM to 64dragon
personally, i've never seen temps lower over time with Artic Silver 5, what i had when i boot is how they stay
__________________
XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.9ghz @1.32v under load, corsair dominator ddr2 1066 4gigs, evga gtx260 core 216, pc p&c 750W, TRUE Black, Lian Li v1200b
silverstone tj07 build log
64dragon is offline   Reply With Quote
Old 10-17-2009, 08:51 PM   #17
wrangler
Same here. Anything else is placebo effect.
__________________
Asus R2G | i7 920 D0 @ 4.0 | Asus HD 5870 | 6GB Corsair DDR3-1600 C7 | OCZ Vertex 120GB | PC P&C Silencer 750 | Antec 900 | Liteon SATA DVD Burner | Win 7 Pro X64 | BenQ FP241VW |
No matter where you go, there you are.
wrangler is offline   Reply With Quote
Old 10-17-2009, 10:43 PM   #18
Darkboss
Yeah, I bought Arctic Silver 5 and now I'm regretting it. I always used to buy it but now I'm wishing I used mx-2 or something else. My temps are still too high for a TRUE with push/pull and idle core temps. I'm at 44-44-43-40 at idle @ 171x21 @ 1.232v in cpu-z. I cant seem to lower them at all even after reseating my TRUE and reapplying the thermal paste again.
__________________
920 @3.8GHz(181x20) CO/C1 @1.23-1.25V, Turbo on, HT-on, giga UD4P, 3x2GB Gskill, EVGA GTX 295, TRUE rev.B
Darkboss is offline   Reply With Quote
Old 10-18-2009, 02:35 AM   #19
FloofyFox
FloofyFox's Avatar
2 of my friends used Indigo Xtreme on their PCs, and the both got lower temps than their previous TIMs... (One being the Noctua NT-H1, and the other MX-2 I think.) That stuff is intense if you're really looking for the lowest temps since it actually contains metallic compounds. Only thing is it isn't compatible with direct heat pipe contact type heatsinks... Poor me and my ol' Vendetta 2
__________________
Intel Q9550 @4GHz | Asus P5Q PRO | Enermax Liberty 620W | Prolimatech Mega Shadow HS | OCZ ReaperX 2x2GB DDR2 | [BFG] GTX 260 | 2x WD SE16 500GB RAID-0
FloofyFox is offline   Reply With Quote
Old 10-18-2009, 07:11 AM   #20
Ar3s
Ar3s's Avatar
Send a message via Skype™ to Ar3s
yeah Indigo Xtreme is truly amazing stuff. Too bad ain't using Intel. MX-2 or Noctua NT-H1 are great. MX-3 is just not worth it for just 2 degs lower on load. Using Shin-etsu now.
__________________
Everyday is a NiceDay
Ar3s is offline   Reply With Quote
Old 10-18-2009, 10:34 AM   #21
rusty
how difficult is it to apply shin-etsu on cpu?
I hear it's pain to clean this stuff after.
Old 10-18-2009, 05:38 PM   #22
Jakethesnake011
Jakethesnake011's Avatar
I like the new MX-3, if not I use AS-5,a dn that takes something like 160 hours to settle fully, and the computer has to be shut off a few times to lower the temp of the grease to room temp.
Jakethesnake011 is offline   Reply With Quote
Old 10-18-2009, 05:47 PM   #23
gatecrasherlok
p.s.>
Err try reading that sentence again, I never said mx-2 being a no go
__________________
EVGA X58 Classified
Asus Xonar d2x
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
