10-16-2009, 03:30 PM
#1
does anyone have any info on the Bitspower D5 top
Better than the EK?
Quality?
__________________
__________________________________
[ EVGA X58 Classified ]
[ Intel i7 920 ] --- D0
[ Sapphire 4870x2 ]
[ BenQ G2400WD 24" Monitor]
[ 3 x 2GB G.Skill Trident DDR3 ]
[ Corsair 850HX 850 watt PSU ]
[ Auzentech Prelude ]
[ beyerdynamic MMX300]
[ Logitech G15, G9 , G7, MX518]
[ Saitek X52 ]
[ 4 x Samsung Spinpoint F3 500GB ]
[ 1 x WD 150GB Raptor ]
[ 1 x Seagate 500GB 7200.11(32mb) ]
[ Windows 7 64-bit]
Water Cooling Setup
U2-UFO Black Powder Coat - 3 Big Window
Swiftech MCP-655 aka Laing D5 Vario w/ EK Top
Thermochill PA 120.3
Swiftech XT CPU Block
EK Classified Full NB/SB Block
EK-MultiOption 4 Port RES 150 Rev. 2
NZXT Fan Controller + Sunbeam Multi Fan Port
7/16" ID (5/8" OD) Primochill Black Tubing
7 x Yate Loons-D12SM ‘s
Bitspower Compression barbs
10-16-2009, 04:14 PM
#2
Xtreme Cruncher
Link to particular product? The only BP D5 pump mod I know of is the "bling kit", which isn't a top mod at all.
10-16-2009, 04:33 PM
#3
__________________
[ Sapphire 4870x2 ]
[ Saitek X52 ]
[ Windows 7 64-bit]
Water Cooling Setup
10-16-2009, 04:34 PM
#4
Bitspower BP-D5TOP-BK - D5/MCP655 MOD Top - Acetal
__________________
[ Sapphire 4870x2 ]
[ Saitek X52 ]
[ Windows 7 64-bit]
Water Cooling Setup
10-16-2009, 05:10 PM
#5
I've got one, better than the EK? not sure, it should perform around the same though!
10-16-2009, 07:34 PM
#6
Obsessed Member
I've got one, it has a lot better flow than the stock top.
__________________
wEeViL
Browser: Intel QX9650 (3.0GHz) @ 3.6 | Water Cooled by Swiftech | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | eVGA GTX 285 SSC | Customized Lian Li B25B | Antec Signature SG850 PSU | Windows 7 64 RTM
Gamer: Intel i7 920 (2.66) @ 4.0 | Water Cooled by Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
10-16-2009, 08:13 PM
#7
good stuff and good quality. performance between the both should be a neglible difference but like the above said.. a lot of improvement over stock
just took a pic for my build
10-16-2009, 10:41 PM
#8
I own both. I like the bp one more as it's compatible with their "bling" housing and has more options. performance is negligible. bp comes with 2 bp screw stop fittings. It's a bit smaller than the ek v2. you can't go wrong with either.
__________________
CPU: Intel Core 2 Extreme QX9650 Yorkfield
Motherboard: Foxconn Blackops X48
Memory: 4G 2x2 OCZ Reaper DDR3 1800 (PC3 14400) 8-8-8-27 1.9v
Hard Drives: 2 x W.D Raptor 150GB (OS, games, apps) RAID0
Video Card: XFX Black Edition 9800GTX @ stock frequency (760 core / 2280 memory / 1900 shader)
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Optical Drives: Nec 3550 dvd burner
OS: Gentoo GNU/Linux amd64 | Windows Vista Ultimate 64-bit
Odds/Ends: Razer Diamondback Mouse - Happy Hacking Keyboad Pro2 - RME pro audio card. FreeBSD UNIX servers and laptop when I'm not gaming!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
