10-16-2009, 06:29 AM
#1
Gently Typhoon 1850 or 1450 RPM
I am trying to obtain the 1850 version from several local dealers, however, nobody is able to get them in stock.
The 1450 version, however, is available. Is the 1450 version
as good as 1850 (will be used on a MCR320 + shroud). Or should I wait for 1850?
Other option is to use Zalmans F3.
__________________
Gigabyte 790XT-UD4P / X3 720 BE / 4GB OCZ Reaper HPC / Sapphire HD 4770 / Samsung F3 500GB & F1 640GB / Corsair HX750 / CPU / GPU H2O / Sharkoon Seraphim rev.ATX
10-16-2009, 06:40 AM
#2
Xtreme Guru
The 1450s are fine. IIRC, someone checked into the status of the 1850s and they were suppose to be back on shelves very soon, but I haven't heard anymore information on that.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
10-16-2009, 07:08 AM
#3
10-16-2009, 07:14 AM
#4
Xtreme Guru
Thanks Ketzer, you were who I was thinking of. Any chance you have gotten so updated info? It is pretty much mid-October now. I do need another 1850 myself.
__________________
10-16-2009, 07:42 AM
#5
The only clue I've seen is that Newegg has an ETA listed of 11/2/09 for availability on -15 1850 GTs which is about in line with what I was hearing from the other guys, so maybe in another couple of weeks they'll be back.
10-16-2009, 07:44 AM
#6
I just talked to one of the dealers ...seems there should be pa supply coming his vay in about two weeks.
This fans are hot stuff
__________________
10-16-2009, 07:52 AM
#7
Xtreme Guru
Sweet, I should be able to hold off for a couple of weeks.
__________________
10-16-2009, 08:17 AM
#8
Xtreme Fan
If you are running the components listed in your sig, the 1450s should be fine. I ran a 955 and 4770, both water-cooled, on a dual radiator with Yate Loon 1000 RPM fans and temps were good (40 degrees for Core temps at load).
Advantage of the GTs at 1850 is the extra headroom should you change out components (waiting for some myself).
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
10-16-2009, 08:20 AM
#9
Good news, I've been looking to snag a bunch. And thanks for that info Ketzer.
10-16-2009, 01:27 PM
#10
If you don't HAVE TO have the fans now I'd wait for the 1850's. The MCR rads do perform better with more air flow.
Found some at a estore in Canada a few weeks back (after buying a bunch of other fans) and just love them. Even at 1850 rpm the sound is a sweet hum.
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
10-16-2009, 02:25 PM
#11
I am Xtreme
Ppcs will have them mid next month .
__________________
rig1
q9650@4.3 ~ EK Supreme
Asus RE ~ BP chipset block
4GB OCZ PC3-14400 Reaper@1600Mhz
HD 4870x2 ~ DD waterblock
DELL 3007HC
rig2:
i7 920@4 ~ HK3 CU
EVGA Classified 760 ~ EK chipset block
6GB Dominator GT@1866MHz, 7-8-7-20
HD 5870 ~ EK waterblock
10-16-2009, 03:11 PM
#12
I have been waiting for a few months already!
__________________
i7 920 @ 4.2
Bloodrage
GTX 285
OCZ Blade 2133
PC&P Turbo-Cool 860
Custom Case
- Koolance AC-350 - Typhoon III - XSPC-360 -
USA National Debt
10-16-2009, 05:12 PM
#13
How loud are the 1450rpm's?
10-18-2009, 11:53 AM
#14
Best to read this link on Fan Testing http://www.xtremesystems.org/forums/...d.php?t=223391
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
10-18-2009, 07:01 PM
#15
Zombie Assassin
TBH, the 1450's are a LOT quieter, but not all that much less airflow.
I own all 1850's, and I usually run them somewhere between 1200-1400 for best airflow/noise
__________________
i5 750
Asus Maximus III Gene
Patriot Viper II Sector 5 DDR3-1600 4Gb
XFX 5850 1Gb
Antec NSK3480/Seasonic SS-500HT
10-18-2009, 07:26 PM
#16
Xtreme Fan
Great info, iandh. I'm really impressed with the 1450s ... may just skip the 1850s (leaves more for the rest of y'all).
__________________
10-19-2009, 03:04 AM
#17
Xtreme kickass
Waiting for two months now.
Still gonna go with the 1850's since they'll be hooked up on my fancontroller.
It's a good thing to have some cooling power to spare for benching.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
10-19-2009, 04:28 AM
#18
Too bad you don't live here in Japan, they are everywhere
__________________
Motherboard: ASUS Rampage Extreme//Processor:E8600 //Cooling:Corsair CWCH50-1//Memory:Patriot DDR3 PVS34G1600LLK 8GB//Video Card: Sapphire VAPOR-X HD 4890 OC Edition //HDD/Intel X25-M G2 80 GB & WD 74 GB VelociRaptor//Sound Card & Nic Card: PCI-e X-Fi Titanium Fatal1ty/EVGA Killer Xeno Pro //Case:SilverStone Raven RV02//Power Supply: Corsair HX 850 //Monitor:Samsung P2770H 27"
10-21-2009, 03:43 AM
#19
1850rpm. Get them while they're hot (from SW).
Selfishly I ordered what I need before posting here.
10-21-2009, 04:01 AM
#20
I harvested a total of 10 of these golden fans 1450rpm models, best fans I've used up to date
__________________
Intel Q6600 @ 3.6Ghz
Maximus Formula X38
4gb Corsair Dominator DHX
4870X2
Intel X-25M 80gb + 300gb VR
Corsair HX1000w
Samsung 305T+
10-21-2009, 04:33 AM
#21
8x 1850rpm's running full speed on my rig too...dramatic improvement over the D12SL-12 YLoon's...
10-21-2009, 06:32 AM
#22
Xtreme Guru
Nice, looks like Gary did find some: http://www.sidewindercomputers.com/scge120mmsic2.html
Just got the one I was waiting on.
__________________
10-21-2009, 06:46 AM
#23
Huzzah! Got the three I needed for my rebuild. Now just waiting for the top ported typhoon iii to come back into stock. Thanks for the headsup. \m/ ^_^ \m/
10-21-2009, 09:17 AM
#24
Yes, thanks just picked up the 10 I was looking for.
__________________
EP45-UD3P f8
Q9650 (510x8.5=4335) Q845B522
Swiftech 355 w/ ek X-Top v2
XSPC RX360 w/ (3) Scythe Gentle Typhoon AP-15 (1850 RPM)
Heatkiller LT 3.0
Swiftech Micro res v2
Swiftech Radbox v2
Mips NB block
Bitspower compression fittings
PC P&C 750 silencer
(2) 2GB G.skill F2-9600CL5D-4GBPI
(3) Vertex 30GB RAID 0
(2) WD Black 1TB
10-21-2009, 09:21 AM
#25
damn you!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
