XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-15-2009, 07:57 AM   #1
sdumper
-100c club
sdumper's Avatar
R14 Price Tag Shock....
Just called AirGas on Dixie road in Atlanta to confirm they could source some r14 for me.
Price for 1 5lb cylinder...
Drum roll...$493.00
Chris maybe we can split the cost I hope
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 10-15-2009, 08:12 AM   #2
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Drum roll...$493.00
Will have to pass, I have no need for R14, I'm going straight to R50(methane).
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 10-15-2009, 08:17 AM   #3
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
Shop around, it does pay too
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 10-15-2009, 08:27 AM   #4
sdumper
-100c club
sdumper's Avatar
Seriously? Can you call me because I must have missed something somewhere but then again what else is new
What are the condensing requirements for r50?
__________________
Old 10-15-2009, 11:18 AM   #5
bazx
-100c Club Member
bazx's Avatar
r14 is a killer on cost
__________________
1. The first rule of Bench Club is, you do not talk about Bench Club
2. The second rule of Bench Club is, you do not talk about Bench Club
3. If someone says stop, goes limp, taps out, the the benching is over
4. No bummers in the batcave, apart from unkie dave
5. One Bench at a time
6. No air, no water
7. Benching will go on as long as they have to
8. If this is your first night at Bench Club, you have to Bench
bazx is offline   Reply With Quote
Old 10-15-2009, 12:12 PM   #6
Patrickclouds
Patrickclouds's Avatar
Send a message via ICQ to Patrickclouds
-110°C should be lowest liquid temp of r50
thats about 18 bara
http://www.extremecooling.de/forum/a...k-diagramm.pdf
r50 in a third stage if you use r1150 in the second stage only is realy hard i think. the pressure ration between high- and lowpressure is huge so the compressor temp will rise in very high regions. impossible is nothing
Patrickclouds is offline   Reply With Quote
Old 10-15-2009, 12:38 PM   #7
sdumper
-100c club
sdumper's Avatar
thats about 18 bara
It looks like im stuck with the high price of r14
__________________
Old 10-15-2009, 12:59 PM   #8
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
You could auto-cascade the third stage and condense R50 at more reasonable pressures.
tiborrr is offline   Reply With Quote
Old 10-15-2009, 01:11 PM   #9
quintus
quintus's Avatar
You could mix r50 with one of these: r1150 / r23 / r170 to create a much easier freon for the compressor of the last stage or something to replace r14. I guess
Will try myself a mixture of r50 with r22 for a bp of -90, maybe make a thread with my cascade soon.
quintus is offline   Reply With Quote
Old 10-15-2009, 01:15 PM   #10
[XC] gomeler
This is the hope.
__________________
Old 10-15-2009, 01:27 PM   #11
Patrickclouds
but auocascades have the problem to handle a big load. most of us tune the cascades for 300watts cpu heat.
Old 10-15-2009, 01:37 PM   #12
sdumper
-100c club
sdumper's Avatar
I will try an autocascade for a personal project but this build I need to build, test, and sell quickly before Christmas to help out with Holiday expenses ...
I think I will try to blend some r1150 and r50 if it works for quintus.
__________________
Old 10-15-2009, 01:44 PM   #13
[XC] gomeler
Not a problem if your autocascade compressor is sized correctly. Naturally you will need a larger compressor to maintain the same load but you'll maintain that load at a lower temperature and with a much better compression ratio.
__________________
Old 10-15-2009, 02:02 PM   #14
Patrickclouds
i think that would be a lot of work to get an autocascade working with 700 watt cooling capacity in a second stage.
is anybody of you going to build such a unit? pics?
Old 10-15-2009, 05:44 PM   #15
ultralo1
ultralo1's Avatar
Try searching for its chemical name, tetrafluoromethane (carbon tetrafluoride) . I have found other refrigerants this way in smaller quantities and lesser prices
__________________
Quoted from SoddemFX:
"I frankly have no idea what you are trying to do. I have received more comprehensible correspondence from Mr Obuwonga Mwahahu, who i believe wishes to give me a 10% share of his $12M fortune held in the royal bank of Nigeria."
ultralo1 is offline   Reply With Quote
Old 10-15-2009, 07:53 PM   #16
teyber
Xtreme Mentor
teyber's Avatar
Drum roll...$493.00
that would be like $100 per 3 stage for 5 cascades right? its manageable at that price... still expensive as shyte though
teyber is offline   Reply With Quote
Old 10-16-2009, 04:35 AM   #17
sdumper
-100c club
sdumper's Avatar
Teyber, I think I might get better temps if I can blend stage 3 with r50/r1150 and achieve condensing temps at a respectable level.
It would certainly be easier to come by since Ethelyn and Methane are plentiful.
__________________
Old 10-16-2009, 07:19 AM   #18
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
However, mixing the two doesn't just give you a PT chart between the two.
You'll still simply just condense the r1150, and it will happen at a very low pressure so the R50 will be even less likely to condense.
What will then happen is called saturation, the R50 will be absorbed by the low temperature ethylene. And then the boiling point will drop a little.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 10-16-2009, 08:52 AM   #19
[XC] gomeler
I'd say before you buy the R14 build the 3 stage cascade and get it functional with R1150 on the 3rd stage. By the time you have that 3 stage built I'll have methane and you are welcome to experiment with it. If it goes catastrophically wrong then buy the R14. Still not sure how well using R50/R1150 in a regular cascade will go, Adam has a valid point with condensation versus saturation.
If you can contract out 5 3 stage cascades in a reasonable time frame
__________________
Old 10-16-2009, 08:59 AM   #20
sdumper
-100c club
sdumper's Avatar
Thanks guys...
Looking for a braided stainless steel flex line and wanted just 60 inches of.
http://cgi.ebay.com/1-X-96-BRAIDED-S...item209ed7e01f
Anyway I came across this and am wondering if it can be trimmed down to 60 inches.
Im hesitant to use braided copper flex with temps as cold as Im targeting but thats an option as well.
__________________
Old 10-16-2009, 03:20 PM   #21
Sweeper
Sweeper's Avatar
I have 60" Stainless Braided flex hose. They are 5/8" I.D. and rated for high pressure. if your interested, PM me.
Sweeper is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
