XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 10-14-2009, 09:56 AM   #1
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
Flexy pipe to replace Captube/Pressure Couplers
I swear i saw Unseen use it on one of his monster cascades to join a presure gauge but can't find it now.
Basicly i want to have the gages off the case, desk mounted on a stand as it would be. Showing high and low presures.
Anyone know of anything that i can use?
I don't want to use my manafold as i want to keep the unit shut but will have an outlet for them!
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 10-14-2009, 11:07 AM   #2
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
You can buy such a capilarity tubing with SAE G1/4 threaded nuts, it's made of teflon but I wouldn't recommend it.
tiborrr is offline   Reply With Quote
Old 10-14-2009, 11:25 AM   #3
MeltedDuron
Dothan FTW!
Why is that then?
Wouls i just be better off using the hoses off a manifold to the manometes then?
Unseens just looks smaller and neater
__________________
Old 10-14-2009, 11:35 AM   #4
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Just run capillary to the gauges and braze the capillary to brass fittings. Use loctite to help seal the threads on the fittings.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 10-14-2009, 12:03 PM   #5
MeltedDuron
Dothan FTW!
It's not gonna be that safe or stable though is it, the cap could easyerly be ebnt, criimped or snaped!!
__________________
Old 10-14-2009, 12:10 PM   #6
sdumper
-100c club
sdumper's Avatar
Not easily and not if you coil and stretch...
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 10-14-2009, 01:39 PM   #7
MeltedDuron
Dothan FTW!
Nah nah it's more than that. Kinda need the flex we have with the suction line and hoses that we use on the manifolds.
Here is the topic where Unseen had the hose/pipe
http://www.xtremesystems.org/forums/...d.php?t=163617
Originally Posted by Unseen View Post
The pipe to the gause is a teflon pipe especialy made for refrigeration. The code name is "Reflex" and the connects is pressurised with a special tool.I made them.It is very easy. It can hold 45bar pressure. Bitzer is the company that uses them. I can find 3/8 pipe too which is also very flexible for using them as flex hose from the evap.
@sweeper In any refrigeration shop,else tell me to send you some.
I can't find it anywhere online! It's perfect for what i want to do!
__________________
Old 10-14-2009, 02:25 PM   #8
yngndrw
yngndrw's Avatar
Send a message via MSN to yngndrw
This is where he got it from:
http://www.psiktiki.gr/
Unfortunately I never got around to sending them an Email.
__________________
yngndrw is offline   Reply With Quote
Old 10-14-2009, 02:27 PM   #9
[XC] gomeler
Never had a problem with that and I have 4 gauges just hanging there from my cascade You can snap any thin hose if you bend it excessively. If you are afraid of bending the cap tube you could always sheath it in something thicker like the stainless steel and bronze we use for suction lines.
__________________
Old 10-14-2009, 02:42 PM   #10
sdumper
-100c club
sdumper's Avatar
dito
__________________
Old 10-14-2009, 06:45 PM   #11
ruffus
or u could run the cap tube through a clear plastic hose like used on pop machines they are some what hard plastic and will kink if u bend it run your cap tube through that then it should never brake less u bend it a hole lot
ruffus is offline   Reply With Quote
Old 10-14-2009, 07:13 PM   #12
ruffus
use something like this stuff
http://cgi.ebay.ca/1-4-Polyethylene-...d=p3286.c0.m14
Old 10-14-2009, 07:18 PM   #13
sdumper
-100c club
sdumper's Avatar
Originally Posted by ruffus View Post
Dude thats a neat idea and will dress up the looks...
__________________
Old 10-14-2009, 09:14 PM   #14
quintus
quintus's Avatar
quintus is offline   Reply With Quote
Old 10-15-2009, 12:43 AM   #15
MeltedDuron
Dothan FTW!
The gauges will be moves about and on a desk and say the unit is on the floor or other end of the desk. I want something robust and flexy. Cap will not just cut it! If the flexy stuff Unseen used ois anything like say a Goodridge break line on a motor bike then ideal! Thats what i want.
__________________
Old 10-15-2009, 04:07 AM   #16
sdumper
-100c club
sdumper's Avatar
Originally Posted by quintus View Post
He meant to cover the captube
It would go over it like a sleeve....
__________________
Old 10-15-2009, 04:30 AM   #17
august123
Send a message via ICQ to august123
you mean a system like this: http://www.kaeltefischer.de/gomax.0.html
Should be ideal for your application. They are flexible and can be bent lots of times and are absolutely leak-free when they are made with the correct tool.
But not cheap, thats the disadvantage.
I have a Set of these hoses in my workshop: http://www.august123.de/index.php?ga...ageform&page=1
august123 is offline   Reply With Quote
Old 10-15-2009, 06:54 AM   #18
MeltedDuron
Dothan FTW!
Exactly that August! How much and where? Thinking 2 meters in length for each!
__________________
Old 10-15-2009, 10:54 AM   #19
Unseen
insomnia...
Unseen's Avatar
Send a message via MSN to Unseen
Hi there,
I am not in phase change any more so i cant help you with that but if you want you can send an email to those guys about it. I am sure they will be happy to help you.
Unseen is offline   Reply With Quote
Old 10-15-2009, 01:02 PM   #20
MeltedDuron
Dothan FTW!
Hi there,
Might take you up on that
__________________
Old 10-15-2009, 03:48 PM   #21
piotres
-100c Club Member
piotres's Avatar
Send a message via ICQ to piotres Send a message via MSN to piotres
Can You write in public how much exactly it cost ?
piotres is offline   Reply With Quote
Old 10-16-2009, 12:54 AM   #22
quintus
quintus's Avatar
@sdumper: yepp, I realize that after rereading the posts.
Old 10-16-2009, 01:50 AM   #23
MeltedDuron
Dothan FTW!
Good news, i've found a place in the UK for it and it's cheap so it seams.
We can supply the Gomax 4mm hose made up with 1/4" flare connectors, is this suitable? What pipe size do you require, what fluid are you passing through it? We can supply
Our code Description Net price each
HOSP075 2m Hose with 1/4" Flare Conns £10.74
Got delivery and VAT more than likely on that! 1/4'' flare is right conections?
__________________
Old 10-16-2009, 06:23 AM   #24
yngndrw
yngndrw's Avatar
I think the full name is 1/4" SAE if I remember correctly.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
