XtremeSystems Forums
Reply
Old 10-14-2009, 09:42 AM   #1
Nem
CPU + Mosfets or CPU + GFX under water?
I've just bought (so already have these parts) the Asus Rampage II Extreme, Core i7 920 DO, Asus Ati 5870, + the rest of the system.
I've got the Swiftec GTZ SE block for the CPU, along with the Swiftec pump, and XSPC RX360 radiator.
I've also got the EK mosfet water blocks for the motherboard, but am wanting the GFX card water cooled as well. Am I best leaving the mosfet blocks out all together and just going for CPU and GFX with the parts above? Would adding the GFX block to the CPU and Mosfets compromise the temperatures too much.
Obviously this should have been asked before buying the parts, but it's done now
Any suggestions would be great. Also I've not got budget for a second loop for the gfx card alone.
Cheers
Nick
Nem is offline   Reply With Quote
Old 10-14-2009, 09:50 AM   #2
Hondacity
with gaming ..all(in one loop) of those shouldn't be a problem if you have fans..and decent ambients..and your oc'd i920 isn't pushed too hard
__________________
Hondacity is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
