XtremeSystems Forums
Reply
Old 10-13-2009, 11:04 PM   #1
Johnmark
Water Blocks that fit Asus P6T?
I want to buy an i7 board as a backup, as mine needs to go the Asus hospital for a little stay.
I've searched hi and lo for north/south bridge, mosfet blocks for this board and can only find hardware for the Deluxe and Extreme boards.
Does anyone know of any blocks for the plain jane P6T or if any of the other current offers will fit a P6T?
TIA
__________________
Mobo: Asus Rampage Gene II
CPU: i7 920 at 3700 Mhz, NO increased volts anywhere.
GPU: Sapphire 4890 Vapor-X
RAM: G.SKILL Trident DDR3 2000 (PC3 16000) 6x2GB
HD's: 2 Velioci Raptor 300 gig + several others
Blu-Ray Writer: Pioneer BDR-203BK
DVD Scanner: Liteon SHW-165H6S DVD
PSU: Corsair HX1000
Case: Obsidian 800D
GPU Cooling: Ek Water Block CF Acetal Full Cover GPU Block 1/2IN G1/4
CPU Cooling: Heatkiller v3
Water Res: Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Radiator: Feser 360
Pump: Swiftech MCP350 with XSPC top
Fittings: Danger Den G1/4 to 3/8IN High Flow Barb Chrome Fittings
Tubing: 3/8" I.D. Tygon
Cooling Water Conditioning: Petra's Tech Shop ,PT-Nuke and Pentosin G11
OS: Windows Vista Ultimate x64
Johnmark is offline   Reply With Quote
Old 10-13-2009, 11:18 PM   #2
Salamndar
Salamndar's Avatar
TIA
if you are going to get an i7 board as a backup then why not get a Rampage 2 Extreme and fit it with some nice sexy waterblocks from EK or bitspower!!!
Salamndar is offline   Reply With Quote
Old 10-14-2009, 12:10 AM   #3
eponymous
eponymous's Avatar
http://www.performance-pcs.com/catal...ducts_id=25064
http://www.performance-pcs.com/catal...ducts_id=25065
http://www.performance-pcs.com/catal...ducts_id=25240
I'm getting these for my P6T Deluxe and it looks like they may fit the P6T as well, but I'd double check this.
I'm really just comparing the layout of the P6T I can see online with what I know about the P6T Deluxe v2 so this is at best, an educated guess.
P6T
P6T Deluxe v2
Looking at those pics, I think the P6T may have SATA ports that would block the NB/SB block, but you may be ok with the MOSFET blocks and you could just use individual blocks for the NB/SB such as those made by EK and Koolance.
Again, please double check this. I would hate to think you went out and bought these and they didn't fit.
Hope this helps.
__________________
[Project] : Altair | A Lian-Li PC-P80, dual loop, all internal build.
Hardware
Core i7 920 D0 | 12GB Corsair Dominator 1600MHz CL8 RAM | 2x EVGA GTX 285 SLI | ASUS P6T Deluxe V2 | ASUS Xonar D2X
2x Intel X-25M SSD | Corsair HX-1000W | Lian-Li PC-P80 | Dell 3008WFP 30"
Watercooling Gear (Dual Loop)
Koolance 350AT (CPU Loop) | 2x Koolance VID-NX285 (GPU Loop) | 2x Laing DDC 3.2 / XSPC Acrylic top Rev. 3 | 2x EK Multioption 150 Res Ver. 2 | 2x Thermochill PA 120.3 |
6x Scythe S-Flex 1200 RPM Fans | 7/16" Primochill Pro Green LRT | 7/16" Primochill Pro Blue LRT | B.P. Silver Shiny 1\2" Barbs | Alphacool Ball Valve / B.P. M-M Rotary fill-port / drain | Bitspower Black Freezer AIX58NS NB/SB (GPU Loop)| Black Freezer MOS AMOSII POM Version (GPU Loop)| Bitspower Black Freezer MOS AMOSIII POM Version (GPU Loop)
eponymous is offline   Reply With Quote
Old 10-14-2009, 08:17 AM   #4
CodeNinja
CodeNinja's Avatar
I believe it's only the MOSFETs that are trouble to find waterblocks for. At one point EK had a kit that supposedly fit, but only one of the MOSFET coolers fit, the other wouldn't bolt to the board.
Shame, too. I have this board, it doesn't behave like a 'low end' board at all, very stable with a ton of OC options.
Here's some more info: http://www.xtremesystems.org/forums/...d.php?t=221848
And... looks like he got it working, not sure on what blocks he has though. They look like EKs, so maybe email them? http://www.xtremesystems.org/forums/...d.php?t=222051
__________________
Asus P6T | TRUE Extreme Edition | i7 920 @ 3.8Ghz (19x200) | 6GB Corsair DDR3 1600Mhz |
XFX GTX285 Black Edition | 4x WD Caviar Black 640GB RAID10 Array | CoolerMaster Centurion 590 |
Corsair 620HX Modular PSU | Lots and Lots of Fans!
CodeNinja is offline   Reply With Quote
Old 10-14-2009, 10:13 AM   #5
NaeKuh
Broken Gainestown
NaeKuh's Avatar
TIA
fail ASUS doesnt accept obamacare.
But to answer your question id say no because the p6t went though board revisions though hell and back.
Ask bei fei, he'll tell you first hand.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 10-14-2009, 12:37 PM   #6
Johnmark
I've searched the WWW for pictures that might show the mounting holes and a clear layout and nothing, as well as all the vendor sites and stores. So I figured someone on this forum would have surely investigated this already. As has been stated the P6T seems like a very nice board for Ocing and I don't need SLI.
Sounds like the manufactures may have given up on this board due to all the revs.
Thanks for the link CodeNinja I'll follow up with him.
Cheers
__________________
PSU: Corsair HX1000
Case: Obsidian 800D
Radiator: Feser 360
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
