10-13-2009, 03:50 PM
#1
Xtreme Cable Management Freak
how much kink is too much?
plain and simple, is there too much kink here? the tubing is 1/2" ID, 3/4" OD..
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
EVGA GTX 295 co-op | Swiftech Epsilon
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air
10-13-2009, 03:51 PM
#2
Xtreme Cruncher
You can eliminate that by putting a cable tie or three around the center section to reinforce the tube. That might get flatter over time.
__________________
10-13-2009, 03:56 PM
#3
see the thing is that i dont really want to ruin the look of the tubing.... unless they have cable ties that perfectly match this..
__________________
10-13-2009, 04:07 PM
#4
I am Xtreme
What about trying to find a spring to put inside the tube?
Something like this. . . http://www.mcmaster.com/#1986k23/=41qmdn
__________________
10-13-2009, 04:11 PM
#5
Broken Gainestown
i see mixing metals.. :X
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
10-13-2009, 04:12 PM
#6
am i really going to notice this kink THAT much? for some reason i have a really hard time removing this tubing from the barbs... so its a big pain to change it up..
__________________
10-13-2009, 04:13 PM
#7
Broken Gainestown
no its fine...
but what got me nervous is that ur using the stock NB, which if i remember correctly is made out of ALU.
Your block is copper.. + Alu = problems...
Or did they revise it?
__________________
10-13-2009, 04:17 PM
#8
I am Xtreme
Depending on your heat load, that section of tubing could warm up enough where it could start to flatten out on it's own. I can not stress the fact enough that it is only a possibility and is not guaranteed to happen.
__________________
10-13-2009, 04:25 PM
#9
from what ive seen on the nb block, its copper. and i dont think that there is a HUGE amount of heat going through here, ill see how it goes for a bit, if it looks bad ill switch it out. thanks for the quick responses guys!
__________________
10-13-2009, 04:28 PM
#10
Broken Gainestown
The top isnt alu?
The base i know is copper, but if i remember, the top should be alu.
Thats why bei fei was making replacements for it.
You see thats the problem.. once u start mixing metals and notice corrosion, its already too late.
__________________
10-13-2009, 04:48 PM
#11
ummmm im not sure then, thats the first that ive heard of it being an issue, or even aluminum existing in the block :S
__________________
10-13-2009, 07:31 PM
#12
I am Xtreme
I think I would wait it out and see what it does. That kink is only very slight and with thick walled tubing, I doubt you will have a problem.
10-13-2009, 07:39 PM
#13
I am Xtreme
use another straight barb on the block and make the loop longer
__________________
MSI GD-70|AMD 965C3
mushkin advanced 7-7-6-18 1600
XFX 5870
Coolermaster UCP 1100w.
Custom liquid cooled (CPU only)
Vista 64/ 7x64
10-13-2009, 08:00 PM
#14
I am Xtreme
+1
or just add an extender on your 45. That will give you more height and eliminate the kink. your kink is nothing to worry about now, but give it a little time and it might be more obvious.
__________________
10-13-2009, 11:10 PM
#15
exactly what I thought !
10-13-2009, 11:26 PM
#16
Originally Posted by NaeKuh
The top isnt alu?
dude i think your thinking of the black ops....
that block i belieev is all copper
__________________
Corsair HX1000
MOBO's
DFI UT X58
CPU's
I7 920 D0
Cooling
Chilled by chilly1 SS, or CUST W/C 3X120MM BIXII, Duniek DICE pot
Cases
Cooler master HAF 932
Ram
Kingston 2000 Cas8
Gpu's
GTX 285,
10-14-2009, 12:49 AM
#17
Broken Gainestown
oh thank you for clearing the confusion.
__________________
10-14-2009, 04:32 AM
#18
ah well that makes it alot better for me  , thanks for clearing that up!
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
