10-13-2009, 12:21 PM
#1
Need Help With i7 And Black Ice 560
So I just received the package with my liquid cooling system, my first.
I have an i7 920 and a Black Ice 560, To this radiator I'm gonna connect 4 120mm Scythe Ultra Kazes (3000) and only the CPU (For now).
Swiftech MCP655 (with controller).
HeatKiller LT.
Other than that, I just bought an Antec 1200 with 2 Silverstone FM121s, And for the GPU, For now I got a 9600GT (8800 Ultra RIP), on air.
MotherBoard: Gigabyte's GA-EX58-DS4.
Memory: Corsair Dominator 1600MHZ CL8.
So after all is tested and current case is replaced, I'll OC the CPU. Since It'll too be my first time at OCing, I learned what I should touch and not touch in my current MB's bios.
How far do you guys think I can go with OCing my CPU ?
4.0MHZ and my radiator won't talk to me. 5.0mhz? Only after I check everything is stable for a while, 6.0 ? 7.0?
10-13-2009, 12:46 PM
#2
Tygon Warrior
The 560 uses 140mm fans, not the 120mm. You may want to rethink strategy here.
10-13-2009, 12:55 PM
#3
From what i've seen around, you might be able to get to 4,5ghz if you do things right..
When you are trying for bigger clocks, like 5,6++ you need a chilled liquid cooled system (i dont know much about this), dry ice, liquid nitrogen and so on..
Btw, you need a D0 cpu to be able to reach those clocks without overvolting your cpu.
i know someone knows ALOT more about me on this, so please correct me if im wrong!
Good luck overclocking!
__________________
My mATX Awesome'ness
CPU - Intel i7 920
Motherboard - Asus Rampage Gene II
GPU - 5850
Ram - 6GB kingston 1333mhz
HDD - WD Green 1TB
PSU - Corsair HX 1000W
Case - Lian Li V351B - with Custom Backplate
10-13-2009, 01:07 PM
#4
I wanna say a 5.0 for 920 is a overpush for daily use but if u are building for benchmarking there is not a limit, but you do wanna a better cooling system than what you have now
10-13-2009, 03:03 PM
#5
Sorry, I forgot to say I bought 4 X 120mmto140mm.
10-13-2009, 03:09 PM
#6
CPUZ says C0/C1
Overvolting = Changing the core-voltage or did u mean not only doing that, but reaching above Intel's recommendations ?
10-13-2009, 03:10 PM
#7
How can I improve it even more without a chilled liquid cooled system, dry ice, liquid nitrogen and so on.. ?
10-13-2009, 03:12 PM
#8
Liquid nitrogen is the way to go but I don't have any knowledge on those.
10-13-2009, 03:36 PM
#9
I am Xtreme
You have a C0/C1 920.. and you are looking for a 24/7 overclock? If so, 4.0Ghz is decent, since this is your first time. 4.2Ghz is about all you should expect to get out of it, stable 24.7 operation.
__________________
Email/web browsing PC
MM Ascension case, 24/7 settings
Classified, 920 @ 4.7Ghz, HT on
(2) toxic 4890's @ 1025,
Mushkin redline ascents 6gb, 1784 Mhz 7-7-6-19
(8) intel x25m RAID 0 on LSI 9260
heat killer, 2 swiftech mcr 320's, feser 360, Xspc Rx360, EK full coverage MB WB. 655 with detroit top, 355 with Xspc top
plus many other rigs.
10-13-2009, 04:00 PM
#10
Thanks man..
10-13-2009, 04:02 PM
#11
Yeah I thought for going for a decent one like you said, But like I know my self, It will only hold like that for few months if not minutes
10-13-2009, 04:29 PM
#12
I am Xtreme
So what is your goal here??
__________________
10-13-2009, 07:21 PM
#13
Ya2
as others have said for a c0 on water anything over 4 is pretty good, for a d0 you might get a bit higher (once I swap waterblocks I should be able to get a couple hundred mhz extra). Your radiator will handle the heat-load fine, and you have one of the best waterblocks but for anything extreme (4.5, maybe 5 or higher) you need sub ambient cooling (which regular water cannot do) ie a chiller, liquid nitrogen (or for the insane, liquid helium)...
Since this is your first overclock you should take it slow and be careful, maybe try 3.2 at stock voltage, then move to 3.4, 3.6, then 3.7, 3.8 ..., when it is no longer stable at stock start adding a little extra voltage (be careful you can kill the processor if you give it to much, even if you keep temperatures in check).
__________________
Tj10
i7 920, 4.2 at 1.32v 72C after 24 hours prime 95 (time to move to a new block)?
asus p6t6 ws revolution
4870 1gb
6gigs ddr3 1600
x25-160 g2, velociraptor 300gig, 4x 1.5tb wd green in raid 5 on highpoint 4320
lg bd/hdvd combo
dtek fuizion, swiftech 360, 240 with 3 sanyo denki's
and 2 scythe (25mm didnt have space for another 38)
swiftech 655 pump,
10-13-2009, 08:59 PM
#14
You don't buy a $2,000,000 dragster and expect to race it at 300 MPH on your first time you get in the dragster.
Start slow.
__________________
All stock for now
i7 965 ES D0 step
Corsair 1600 6 gig
GTX 280 x 2
Giga Xtreme mobo
Two 120x3 loops
DDC3.2 XSPC restops
XSPC 360RX and PA120.3 Rads
GTZ CPU and Tieton GPU blocks
Banchetto Tech Station
And the rest of the normal stuff
10-14-2009, 02:50 AM
#15
Originally Posted by jkresh
Ya2
Start slow.
Thanks guys.
http://www.youtube.com/watch?v=JAzz4oOWA3E
I just found this video which has both 920 and gigabyte's MB, He pretty much explains all 1 should know, Or will I think badly about this guy in few months ?
10-14-2009, 02:53 AM
#16
My goal is to make my computer faster than me.
And be great for big games, like Arma2 (I like the jets), Anno 1404 (takes me 2 minutes to load a map, ridiculous), future Battlefield series (jets/choppers whore)..
10-14-2009, 04:04 AM
#17
You won't see a big difference between the same 920 at 4.5 and 5.0 for actural use, your game will still load slow unless you use SSD.
10-14-2009, 06:18 AM
#18
I am Xtreme
you are buying a chip that is rated at 2.66Ghz stock, so if you can get a rock solid OC @ 3.6Ghz you have gained a full 1000 Mhz.. on 8 threads, that is a huge gain. 140%.. if you can get 3.8 then great, 4.0 even better, but I am just letting you know up front you are not going to get much higher, stable overclock than 4.0-4.2
__________________
10-14-2009, 06:23 AM
#19
+1
lol you killed his hopes
__________________
10-14-2009, 08:43 AM
#20
Yeah I was lucky to find about SSD a month ago, Before I was gonna buy 2 Velociraptors, But now when u can't get a decent SSD for less than 600$-700$, I'll just have to wait, probably half a year.
10-14-2009, 08:47 AM
#21
What would cause instability over 4.2?
Temps won't matter as said (I assume that with an Antec1200 the MB will be chilled enough at low RPM of the case fans).
If I manually change the vcore to the maximum recommended (I'm just taking the "extreme" case) , Will that be stable only for 4.2+- because I have C0/C1 ?
10-14-2009, 08:49 AM
#22
Originally Posted by Hondacity
+1
i7 920, Only today, First hand, Wasn't OCed
There must be a way
10-14-2009, 10:27 AM
#23
I am Xtreme
do your best to get as much as you can stable, but most C0/C1's are not able to run much more than 4.0-4.2Ghz 24/7 stable, and from what I have done, and seen with others most 920 D0's are not much higher, 4.2Ghz-4.5Ghz is about all you can realistically expect.
A 4.0Ghz 24/7 rock stable 8 thread, tripple channel setup is very good, way more power than your 9600Gt will ever need.
__________________
10-14-2009, 10:38 AM
#24
Thanks man.
Now I came to a Black Ice 560 problem, It has corrosion (whity-green) on the inside.
What can I do about it?
I read I can add to the distilled water - Those silver-made liquids, If that is true, Should I run the system with distilled water+silver for a month, Get all the liquids out and refill with distilled water+silver and I'll be fine for a year ?
10-14-2009, 10:43 AM
#25
Yes you can, I am runing 2*X25 80G RAID 0, they work great and together they are 500 plus shipping, you don't need that much big of space on your ssd anyway. I do have raptors running on my rig, but the SSD blows them away to the other side of the ocean.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
